Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,932 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I would like to get rid of this double pulley on the crank of my 86 3.2 engine and replace it with a single pulley like the early engines.
Which year or engine single pulley would be compatible (same diameter) as a replacement? Would it have the same timing marks? Or, have people drilled the spot welds to get rid of the A/C pulley? (IMG:style_emoticons/default/confused24.gif) ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,990 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
74-89 crank pulley will work TDC and 120 deg. marks correct..
I have cut the ac pulley off in a lathe, Drilling spot welds works too. some 3.2 double pulleys have a balance weight spot welded on .. I think cutting off the AC negates the need for the balance weight....are least close enough for street. ![]() |
Lo-Fi Version | Time is now: 13th October 2025 - 10:53 PM |
