Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,932 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I would like to get rid of this double pulley on the crank of my 86 3.2 engine and replace it with a single pulley like the early engines.
Which year or engine single pulley would be compatible (same diameter) as a replacement? Would it have the same timing marks? Or, have people drilled the spot welds to get rid of the A/C pulley? (IMG:style_emoticons/default/confused24.gif) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,138 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Yes, people do remove the dual pulley on a 3.2, either with a single pulley or modifying the stock one. A lathe makes it easy. One advantage is you don't need to use the expensive and harder to find Carrera engine mount.
The Clewett pulley system does specify a Carrera mount so I'm guessing it's pully system is slightly wider than a single oem pulley. I don't know if the Clewett pulley fits in with the Maddog mount. It probably does but I haven't checked. Removing the a/c portion of the Carrera pulley or housing the correct earlier pulley is really the best and most cost effective way to insure it will fit perfectly for your six conversion. |
Lo-Fi Version | Time is now: 13th October 2025 - 10:53 PM |
