| ctc911ctc |
Oct 10 2025, 12:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,397 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
914-6 all original - rebuilt the transmission
This is part of the rebuild thread - http://www.914world.com/bbs2/index.php?sho...3371&st=100 Transmission - Shifter -> This is my working theory, I am probably wrong.... (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/dry.gif) While I am chasing the 'carb-spitting' issue, I am also chasing the shifter being.....OFF This is manifesting itself as the DREADED 1st to reverse problem.......As to the condition of the 901, gears are all within spec, new syncs 1st and second, new slider for 1st reverse - new dog teeth for 1st and second. Let me explain, When I put the car into 1st or reverse, I (as well all of you) push the lever from RIGHT to LEFT and feel the spring pressure of the shift plate. About 1/4 of the way to the full extent of the spring compression the there is strong resistance. BUT i can CONTINUE to push to the left. I believe that I have reached the limit of the various linkage components and that what I am REALLY doing at this point is torquing the linkage. I can then continue to torque the linkage until I have reached the full travel of the shift lever spring plate ![]() What happens is; when the shift comes out of 1st, there is no SPRING BUMP to push the selector in the transmission from the 1st-reverse position to the 2nd-3rd or middle position. I have cut pictures from Clay Perrine's excellent 901 cut-away to depict what is happening Transmission is in Neutral on the other side of the selector bars is a vertical channel, there is a knob that is in ONE of the THREE channels - when moved the selected bar moves left to right ![]() Now, the knob is in the channel of the lowest bar AND the bar is slid to the left for FIRST GEAR ![]() My shift LINKAGE - not the shift lever - when moved forward never gets the BUMP from the spring and as a result STAYS in the LOWEST position THOUGH the shift lever HAS moved to the right and you think that the shift is in the correct place BUT NO, it ends up pushing the SAME slider BACKWARD into reverse ![]() OUCH!!!!! What should happen is the selector should get a bump to the next position from the spring and end up here. ![]() MY PLAN I am going to adjust the Shift bar about 20 degrees to I do not get any mechanical loading, not sure if 20 degrees is correct......feels right....... |
| brant |
Oct 10 2025, 05:58 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,295 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Is this the same box you found in gear when you installed the shift linkage?
| ctc911ctc |
Oct 10 2025, 08:09 PM
ctc911ctc The DREADED 1st-to-reverse Oct 10 2025, 12:28 PM
Front yard mechanic Just remember it’s not gear grinding it’s gear... Oct 10 2025, 05:39 PM
ctc911ctc There may be a short shift kit in the car - more t... Oct 10 2025, 08:13 PM
ctc911ctc Trying this tomorrow
https://www.pelicanparts.co... Oct 11 2025, 07:24 PM
ctc911ctc *******UPDATE***********
Did you ever have the fe... Oct 17 2025, 09:20 AM
ctc911ctc *****UPDATE ********
I have spent about 6-8 hours... Oct 19 2025, 03:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 03:22 PM |
