> left turn signal problems, feel like i have tried everything
jeff dodge
post Oct 10 2025, 04:37 PM
I am having trouble with my left turn signal. Let me detail; ground tested and is good, replaced , replaced column switch, new relays, new bulbs, swapped housings from left to right, new fuses. noticed that when I clicked the emergency flashers it blew that fuse. Right works fine, the left turn filament is very dim and the read does not do anything. I have spent two weeks trying to track this down. I have built entire harnesses for vintage race cars and this has me baffled. Please help! Thanks, Jeff
Dave_Darling
post Oct 11 2025, 01:49 AM
914 Idiot
A dim light says to me that you've got either a grounding problem, a high resistance connection, or a couple of wires swapped.
How sure are you that you've dealt with the grounds?
Have you matched up the wires on the front AND REAR turn signal buckets with Jeff Bowlsby's diagrams?
https://bowlsby.net/914/Classic/TechNotebook.htm
--DD
jeff dodge   left turn signal problems   Oct 10 2025, 04:37 PM
jim_hoyland   There’s a possibility the TS switch has a short ...   Oct 10 2025, 06:33 PM
Dave_Darling   A dim light says to me that you've got either ...   Oct 11 2025, 01:49 AM
jeff dodge   A dim light says to me that you've got either...   Oct 12 2025, 10:28 AM
Spoke   I am having trouble with my left turn signal. Let...   Oct 12 2025, 06:21 PM
scallyk9   I am having trouble with my left turn signal. Le...   Oct 16 2025, 03:10 PM
jeff dodge   [quote name='Spoke' post='3227996' date='Oct 12 2...   Oct 17 2025, 11:46 AM
jeff dodge   [quote name='Spoke' post='3227996' date='Oct 12 ...   Oct 20 2025, 03:02 PM
jeff dodge   [quote name='jeff dodge' post='3228695' date='Oct...   Oct 21 2025, 04:13 PM
Spoke   All of the housings checked out. every light work...   Oct 22 2025, 06:01 AM
jeff dodge   All of the housings checked out. every light wor...   Oct 22 2025, 02:22 PM
jeff dodge   All of the housings checked out. every light wor...   Oct 23 2025, 04:39 PM
jeff dodge   [quote name='Spoke' post='3229355' date='Oct 22 2...   Oct 23 2025, 04:50 PM
NARP74   I had some stuff in my rear trunk hit the tail lig...   Oct 16 2025, 04:34 PM
Spoke   OK, let me make sure I understand what's hap...   Oct 23 2025, 07:53 PM
jeff dodge   OK, let me make sure I understand what's ha...   Oct 25 2025, 08:23 PM
jeff dodge   I appreciate all of the help that I am get from fo...   Oct 24 2025, 08:17 PM
Ishley   You might want to check all the bulbs and fixture....   Oct 25 2025, 09:01 PM
jeff dodge   You might want to check all the bulbs and fixture...   Oct 30 2025, 10:22 AM
jeff dodge   You might want to check all the bulbs and fixtur...   Oct 30 2025, 11:27 AM
Superhawk996   You’re going to have to work with a wiring diagr...   Oct 30 2025, 11:44 AM
black73   Are the rear license plate lights in that circuit?...   Oct 31 2025, 03:40 AM
jeff dodge   Are the rear license plate lights in that circuit...   Oct 31 2025, 09:42 AM
Spoke   It might be useful to check the resistance in the ...   Oct 31 2025, 10:02 AM
NARP74   @jeff dodge Did this ever get resolved? I am hav...   Jul 20 2026, 11:55 AM
- Lo-Fi Version Time is now: 21st July 2026 - 05:29 AM
