| JeffBowlsby |
Apr 16 2025, 03:29 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,245 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
"Ignition switches are junk"
Regularly hear this and similar consternation. I have continuously owned one or more 914s since 1998...think I have replaced only 1 ignition switches over that time, in one car. My current primary car I have had for over twenty years, still on the original switch as far as I know, I have not replaced it during my ownership. None my cars have ever had the added relay although I'm not against it. For those switches removed and in other key ignition switches I have opened up, what I see is part of the housing is cracked in similar locations. Maybe from years of torquing the key over? Not sure. I don't see melted housings (believe they are nylon), no smoke residue or anything out of line, just the cracked housing. Suspect the cracked housing causes some internal misalignment of the internal contacts...i.e. the switch goes bad and needs replacement. I am thinking the problem is the switch housings that break, not anything to do with excessive current flow through the switch. Educate me please. |
| Ishley |
Sep 30 2025, 10:32 AM
Member ![]() ![]() Group: Members Posts: 342 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
I've had several go out in 2 years...
The issues I have seen with the new ones is that something breaks inside the switch. The plastic is not strong enough. I am not seeing any electrical issue... it's a mechanical problem... and once it internally fails... it won't make connection to engage the starter. I spoke to George at Auto Atlanta to complain about it and I mentioned how many I've seen on this forum and others all having the same problem. He told me he rarely sees any come back... he had numbers... and his data showed that indeed very few come back. I suspect that the issue is the cost of shipping. If you order from anyone now days it cost $10 to get it... another $10 to return it and if they ship it free... you wait 2 weeks to get it. I'm impatient... and honestly I'd just go to PMB or somewhere else...for a $16 switch. They at least ship faster then AA. I've ordered from several suppliers... and keep 2 on the shelf. They are all the same. Since non of our suppliers are standing up and demanding better quality... and with only one manufacturer... nothing is going to change. Were doomed by a monopoly. I do plan to install a secondary push button switch in the engine bay as a a backup if I get stuck on the road. |
| tomeric914 |
Oct 11 2025, 06:39 AM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,323 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
I spoke to George at Auto Atlanta to complain about it and I mentioned how many I've seen on this forum and others all having the same problem. He told me he rarely sees any come back... There are reasons many of us don't go back to AA. About 10 years ago, my switch failed. I was on a business trip in Atlanta and stopped by AA to pick up a switch. Spoke to their parts guy who said that the trick was to shim the switch with a small piece of paper. Paid $30 Flew home and installed the switch and it didn't work. Ordered a new switch off evilBay for $3 plus $6 shipping. When it arrived, I found that it was the identical switch in an identical marked box as the AA switch. Installed that switch and it didn't work either. Final solution was to purchase a used original German switch from a VW Bug off evilBay for $10. That switch has been in place with no issues for the last 10+ years. My original switch was cracked and worn and just not making contact. For those that have melted switches, one thing that hasn't been mentioned is what happens under continuous cranking, when the engine won't start. While the amp draw may by ~25 amps on a fully charged battery, keep in mind that the amps will go up as the volts go down. |
| Olympic 914 |
Oct 11 2025, 07:03 AM
![]() ![]() ![]() Group: Members Posts: 1,772 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
About 10 years ago, my switch failed. I was on a business trip in Atlanta and stopped by AA to pick up a switch. Spoke to their parts guy who said that the trick was to shim the switch with a small piece of paper. Flew home and installed the switch and it didn't work. Somewhere else I saw a post about shimming the switch with a piece of paper, I can't find that now. I just replaced my switch with a OEM Porsche switch, made in Germany. And sometimes it will only crank for a second then quit. Turn it off and on again and will crank longer. Might try this shim thing. My old original switch wouldn't do this. |
JeffBowlsby Whats wrong with our ignition switches? Apr 16 2025, 03:29 PM
wonkipop
Regularly... Apr 16 2025, 03:51 PM
Root_Werks Similar here, replaced only one in a 914 over 35+ ... Apr 16 2025, 04:05 PM
wonkipop @JeffBowlsby
just asked mike#1.
911 switches pro... Apr 16 2025, 04:25 PM
JeffBowlsby Without excessive current, then why the regular pr... Apr 16 2025, 04:37 PM
Superhawk996
Without excessive current, then why the regular p... Apr 16 2025, 04:56 PM
ctc911ctc Just thinking outloud.... there is no current limi... Apr 16 2025, 05:14 PM
Superhawk996
Not sure what the impulse current is on the Solin... Apr 16 2025, 08:13 PM
bdstone914
[quote name='ctc911ctc' post='3201402' date='Apr ... Apr 17 2025, 04:26 AM
Superhawk996
If it draws 25 amps you don't tonk it needs... Apr 17 2025, 07:14 AM
GregAmy
On the first point - I don’t think it’s fair ... Apr 17 2025, 07:27 AM
ctc911ctc I only have my personal experience
1970 1.7 - in... Apr 16 2025, 05:05 PM
bkrantz My car came with a relay added to the starter, a p... Apr 16 2025, 07:39 PM
Jgilliam914
My car came with a relay added to the starter, a ... Apr 17 2025, 03:28 PM
Dlee6205 Replacing ignition switches has become standard pr... Apr 16 2025, 07:50 PM
Superhawk996 Well know fact . . . When it doesn’t start if yo... Apr 16 2025, 08:08 PM
davep It was about 1975 that I purchased a used 73 914. ... Apr 16 2025, 08:22 PM
Justinp71 I added a relay because even after a new switch, o... Apr 16 2025, 09:40 PM
Superhawk996 Greg - You’re right about the roadside “relay... Apr 17 2025, 07:36 AM
GregAmy Far too often it is used to Band-Aid underlying is... Apr 17 2025, 08:34 AM
Dave97 I have another problem I’ve been chasing. 1975 ... Apr 17 2025, 08:26 AM
Superhawk996
I have another problem I’ve been chasing. 1975... Apr 17 2025, 09:18 AM
TheCabinetmaker
I have another problem I’ve been chasing. 1975... Oct 3 2025, 04:37 AM
JeffBowlsby I have not had the electrical portion of the switc... Apr 17 2025, 09:24 AM
Dave97 I tried jb weld, let it dry and then put it togeth... Apr 17 2025, 09:31 AM
Superhawk996
I tried jb weld, let it dry and then put it toget... Apr 17 2025, 10:05 AM
Ishley I’ m on my 3rd switch in 2 yrs. The first one th... Apr 17 2025, 08:51 PM
orthobiz When I bought my 1974 1.8 in 2007, the ignition sw... Apr 18 2025, 06:55 AM
ConeDodger
Regularly... Apr 18 2025, 07:46 AM
chmillman Mine went out yesterday... There are a bunch of r... Sep 30 2025, 08:52 AM
Superhawk996
For those that have melted switches, one thing th... Oct 11 2025, 07:27 AM
tomeric914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 11 2025, 06:20 PM
Superhawk996
[b]@[url=http://www.914world.com/bbs2/index.php?... Oct 12 2025, 11:31 AM
chmillman Local Porsche dealer just called and said my repla... Oct 2 2025, 04:52 AM
JeffBowlsby Avoid cutting any wires. Just remove the 50 wire ... Oct 2 2025, 09:02 AM
chmillman Thanks @JeffBowlsby , will do...
Here is the par... Oct 2 2025, 11:31 AM
trojanhorsepower I'll add my experience. Hugh and I tried to s... Oct 2 2025, 05:41 PM
DRPHIL914 my 2cents worth and experience with my 15 years of... Oct 8 2025, 12:45 PM
chmillman So got the Partworks switch in a couple of days ag... Oct 9 2025, 02:50 AM
DRPHIL914
So got the Partworks switch in a couple of days a... Oct 9 2025, 06:10 AM
chmillman
so one difference that I see is that the top pic... Oct 9 2025, 08:20 AM
DRPHIL914
[quote name='DRPHIL914' post='3227384' date='Oct ... Oct 10 2025, 11:03 AM
chmillman So, following the excellent Pelican Parts instruct... Oct 11 2025, 02:41 AM
chmillman So, since I had everything mostly apart anyway, ju... Oct 11 2025, 11:33 AM
Superhawk996
Wondering if I shouldn’t wire a relay from batt... Oct 11 2025, 12:10 PM
chmillman
Your problem and symptoms are indicating you hav... Oct 11 2025, 03:12 PM
Dave_Darling Your car is a 74, I see. I didn't read throug... Oct 11 2025, 03:43 PM
Superhawk996
Your car is a 74, I see. I didn't read throu... Oct 12 2025, 11:32 AM
chmillman IT'S FIXED...
OK, you guys are going to have ... Oct 12 2025, 11:35 AM
Superhawk996 Glad you’re back :driving: :Qarl: Oct 12 2025, 12:12 PM
StarBear Lesson learned and noted. Thanks!! Oct 12 2025, 02:23 PM
JamesJ So has it been determined that the $50 Porsch... Oct 20 2025, 07:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th April 2026 - 04:32 PM |
