> Finally running great and then, alternator wiring fire ,recommendations
Ron914
post Oct 8 2025, 02:30 PM
Well I finally got my car up and running great . After the static timing I got someone to sit in the car and hold the throttle @3500rpm so I could set dynamic timing to 27 degrees . This went well and the car again never ran better since motor rebuild . I drove it a bit and then decided to install the Bursch header ( given to me by@ drem914 )after having the muffler replaced . Thanks Franz .
I need to get a bung welded in to it so I could finish the hookup of my AFR and start tuning my MPS .
I first put my rear sway bar back in with new bushings as this requires the muffler to be removed for access.
I installed the Bursch and started the car , Muffler sounded a lot better. than my original 914 muffler that I found holes in.
Decided to take my buddy for a drive to show him how great the car sounded and ran .
Made it to the corner and then proceeded down the street and when shifting from 2-3rd I heard some type of noise( maybe a crack/pop/snap ) and noticed the car losing power ,glanced up in the rear view mirror to see if anyone was behind me and a ton of smoke was coming out of the engine compartment .Immediately shut of the key and put in neutral so I could coast into the tract next to me in a panic . I thought I was going to lose my car to a fire but luckily it was an electrical fire instead of gas , what a lot of smoke though . Pushed the car back home and a quick investigation revealed the 10 ga wire in the alternator wiring harness completely melted down revealing bare copper wire that goes from the alternator to the + starter post where the battery cable attaches for charging . Any ideas or suggestions would be appreciated .
Why did this happen?
Should I replace the alternator ?
What about the starter?
The voltage regulator?
I see that 914Rubber sells a wiring harness, the three pin plug that goes between the alternator and Voltage regulator did not get much damage and looks ok to me .
I can order new charger wire and repair the harness.
Also thinking of adding a breaker , I attached a photo of what I am considering but before purchase I have learned to ask the forum first .
I must say it does not look easy to get to the alternator ,I installed it when motor was out of car . Do I need to remove the motor for access?
The way it burned it seem likely a short to ground occurred but hard to tell after the fact what caused this . I think my car is possessed , can't believe this just happened when I was so close.
Some photos :
JeffBowlsby
post Oct 8 2025, 06:27 PM
Ron,You have the patience of Job! Sometimes it ay seem like these cars are jinxed, but you are eliminating problems one at a time.
Where the big red alternator cable passes through the tin, both at the engine shot and at the rear wall is where this harness typically fails. Heat builds up at these points and eventually deteriorates the casing and wire insulation creating a short to the tin. It’s the common failure of these harnesses. Recommend inspecting these penetration points annually.
I have new alternator harnesses built and ready to ship if you want one, and I use updated cable sizes for greater ampacity. No core charge.
Ron914
post Oct 11 2025, 12:28 PM
QUOTE(JeffBowlsby @ Oct 8 2025, 07:27 PM) *
Hi Jeff , @JeffBowlsby
Why don't you go ahead and send me a new harness . Can I send you a check ? Message me the total and I'll send a check if that's ok with you.
Thanks
Ron
Ron914   Finally running great and then   Oct 8 2025, 02:30 PM
Spoke   That happens from a dead short. Likely VR and star...   Oct 8 2025, 02:59 PM
Ron914   That happens from a dead short. Likely VR and sta...   Oct 10 2025, 02:58 PM
emerygt350   Did it short the sheet metal? That is an area tha...   Oct 8 2025, 06:14 PM
JeffBowlsby   Ron,You have the patience of Job! Sometimes i...   Oct 8 2025, 06:27 PM
Ron914   Ron,You have the patience of Job! Sometimes ...   Oct 11 2025, 12:28 PM
fiacra   Ron, you may have already seen it but here's a...   Oct 9 2025, 12:04 AM
Ron914   Ron, you may have already seen it but here's ...   Oct 10 2025, 03:01 PM
thomasotten   Also make sure the new or rebuilt alternator's...   Oct 9 2025, 01:49 AM
Ron914   Also make sure the new or rebuilt alternator...   Oct 10 2025, 03:17 PM
DC_neun_vierzehn   Also make sure the new or rebuilt alternator...   Oct 13 2025, 03:04 PM
Ron914   [quote name='thomasotten' post='3227367' date='Oc...   Oct 13 2025, 03:21 PM
emerygt350   Go for it. If you are watching you will see where...   Oct 10 2025, 03:10 PM
Ron914   Go for it. If you are watching you will see wher...   Oct 10 2025, 03:20 PM
JeffBowlsby   @Ron914 Will do Ron, will follow up with you Sun...   Oct 11 2025, 01:42 PM
Ron914   So I was able to remove the old alternator and wir...   Oct 13 2025, 02:13 PM
DC_neun_vierzehn   @Ron914 sorry you had this issue. I applaud your ...   Oct 13 2025, 03:16 PM
emerygt350   Is that original or remanufactured? It must be a ...   Oct 13 2025, 05:41 PM
Ron914   Is that original or remanufactured? It must be a...   Oct 13 2025, 07:45 PM
bandjoey   Years ago a member here sold a fuse bank for all t...   Oct 13 2025, 07:56 PM
- Lo-Fi Version Time is now: 13th October 2025 - 10:56 PM
