> Whats wrong with our ignition switches?, What do we know?
JeffBowlsby
post Apr 16 2025, 03:29 PM
"Ignition switches are junk"
Regularly hear this and similar consternation.
I have continuously owned one or more 914s since 1998...think I have replaced only 1 ignition switches over that time, in one car. My current primary car I have had for over twenty years, still on the original switch as far as I know, I have not replaced it during my ownership.
None my cars have ever had the added relay although I'm not against it.
For those switches removed and in other key ignition switches I have opened up, what I see is part of the housing is cracked in similar locations. Maybe from years of torquing the key over? Not sure. I don't see melted housings (believe they are nylon), no smoke residue or anything out of line, just the cracked housing. Suspect the cracked housing causes some internal misalignment of the internal contacts...i.e. the switch goes bad and needs replacement.
I am thinking the problem is the switch housings that break, not anything to do with excessive current flow through the switch.
Educate me please.
chmillman
post Oct 11 2025, 11:33 AM
Region Association: Europe
So, since I had everything mostly apart anyway, just to double check I pulled out the new Porsche-supplied switch and put in the Partworks supplied one. No difference, I was already pretty sure. Odds of having two defective new switches, well, from reading above, I guess it’s possible. However, on the workbench, I was able to insert the key and turn it with an ohmmeter connected to 50 and 15 - contact was made. I even tried it with the old, original cracked switch and it actually still worked. So the switch is most likely not the problem.
I also checked the connectors on the relay board and they look good and uncorroded. So the problem may be at the solenoid/starter connection, tomorrow I will lift the car and start checking underneath. Wondering if I shouldn’t wire a relay from battery + directly to the solenoid, that is actuated by the wire from the starter switch in the cockpit, rather than having the relay in the cockpit near the ignition switch…
Superhawk996
post Oct 11 2025, 12:10 PM
QUOTE(chmillman @ Oct 11 2025, 01:33 PM) *
Your problem and symptoms are indicating you have problems with excessive voltage drop(s) somewhere. Could be in the yellow solenoid wire, the engine to transmission ground strap, or battery cables.
You need to measure voltage drops. Multimeter cannot directly measure resistance accurately enough.
The how to is beyond the scope of this thread. Let me find you a link.
https://www.fenderbender.com/running-a-shop...ircuits-part-11
If you need more assistance - suggest you start a separate thread specific to you car and we can go into detail and work though specific tests if necessary.
BTW - great posts here on the differences between the switches (IMG:style_emoticons/default/smilie_pokal.gif)
chmillman
post Oct 11 2025, 03:12 PM
QUOTE(Superhawk996 @ Oct 11 2025, 08:10 PM) *
Yep - and I am pretty sure it is the yellow wire somewhere along its long and winding road to the engine compartment. To and from I guess, because the battery voltage/current has to come up front from the engine compartment to the switch via the red wire connected to terminal 30 and thense back out to the starter via the yellow wire.
This because of two things - 1, the starter cranks like crazy if I hotwire from the battery+ to the terminal on the solenoid, and 2, we just cleaned all the anchor points and replaced all the ground cables including the engine-trans strap - plus added a couple of additional ground cables to the motor and also redid the + side cables from the battery. I'll post a couple of pictures tomorrow.
JeffBowlsby   Whats wrong with our ignition switches?   Apr 16 2025, 03:29 PM
wonkipop   "Ignition switches are junk" Regularly...   Apr 16 2025, 03:51 PM
Root_Werks   Similar here, replaced only one in a 914 over 35+ ...   Apr 16 2025, 04:05 PM
wonkipop   @JeffBowlsby just asked mike#1. 911 switches pro...   Apr 16 2025, 04:25 PM
JeffBowlsby   Without excessive current, then why the regular pr...   Apr 16 2025, 04:37 PM
Superhawk996   Without excessive current, then why the regular p...   Apr 16 2025, 04:56 PM
ctc911ctc   Just thinking outloud.... there is no current limi...   Apr 16 2025, 05:14 PM
Superhawk996   Not sure what the impulse current is on the Solin...   Apr 16 2025, 08:13 PM
bdstone914   [quote name='ctc911ctc' post='3201402' date='Apr ...   Apr 17 2025, 04:26 AM
Superhawk996   If it draws 25 amps you don't tonk it needs...   Apr 17 2025, 07:14 AM
GregAmy   On the first point - I don’t think it’s fair ...   Apr 17 2025, 07:27 AM
ctc911ctc   I only have my personal experience 1970 1.7 - in...   Apr 16 2025, 05:05 PM
bkrantz   My car came with a relay added to the starter, a p...   Apr 16 2025, 07:39 PM
Jgilliam914   My car came with a relay added to the starter, a ...   Apr 17 2025, 03:28 PM
Dlee6205   Replacing ignition switches has become standard pr...   Apr 16 2025, 07:50 PM
Superhawk996   Well know fact . . . When it doesn’t start if yo...   Apr 16 2025, 08:08 PM
davep   It was about 1975 that I purchased a used 73 914. ...   Apr 16 2025, 08:22 PM
Justinp71   I added a relay because even after a new switch, o...   Apr 16 2025, 09:40 PM
Superhawk996   Greg - You’re right about the roadside “relay...   Apr 17 2025, 07:36 AM
GregAmy   Far too often it is used to Band-Aid underlying is...   Apr 17 2025, 08:34 AM
Dave97   I have another problem I’ve been chasing. 1975 ...   Apr 17 2025, 08:26 AM
Superhawk996   I have another problem I’ve been chasing. 1975...   Apr 17 2025, 09:18 AM
TheCabinetmaker   I have another problem I’ve been chasing. 1975...   Oct 3 2025, 04:37 AM
JeffBowlsby   I have not had the electrical portion of the switc...   Apr 17 2025, 09:24 AM
Dave97   I tried jb weld, let it dry and then put it togeth...   Apr 17 2025, 09:31 AM
Superhawk996   I tried jb weld, let it dry and then put it toget...   Apr 17 2025, 10:05 AM
Ishley   I’ m on my 3rd switch in 2 yrs. The first one th...   Apr 17 2025, 08:51 PM
orthobiz   When I bought my 1974 1.8 in 2007, the ignition sw...   Apr 18 2025, 06:55 AM
ConeDodger   "Ignition switches are junk" Regularly...   Apr 18 2025, 07:46 AM
chmillman   Mine went out yesterday... There are a bunch of r...   Sep 30 2025, 08:52 AM
Ishley   I've had several go out in 2 years... The iss...   Sep 30 2025, 10:32 AM
tomeric914   I spoke to George at Auto Atlanta to complain abo...   Oct 11 2025, 06:39 AM
Olympic 914   About 10 years ago, my switch failed. I was...   Oct 11 2025, 07:03 AM
Superhawk996   For those that have melted switches, one thing th...   Oct 11 2025, 07:27 AM
tomeric914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 11 2025, 06:20 PM
Superhawk996   [b]@[url=http://www.914world.com/bbs2/index.php?...   Oct 12 2025, 11:31 AM
chmillman   Local Porsche dealer just called and said my repla...   Oct 2 2025, 04:52 AM
JeffBowlsby   Avoid cutting any wires. Just remove the 50 wire ...   Oct 2 2025, 09:02 AM
chmillman   Thanks @JeffBowlsby , will do... Here is the par...   Oct 2 2025, 11:31 AM
trojanhorsepower   I'll add my experience. Hugh and I tried to s...   Oct 2 2025, 05:41 PM
DRPHIL914   my 2cents worth and experience with my 15 years of...   Oct 8 2025, 12:45 PM
chmillman   So got the Partworks switch in a couple of days ag...   Oct 9 2025, 02:50 AM
DRPHIL914   So got the Partworks switch in a couple of days a...   Oct 9 2025, 06:10 AM
chmillman   so one difference that I see is that the top pic...   Oct 9 2025, 08:20 AM
DRPHIL914   [quote name='DRPHIL914' post='3227384' date='Oct ...   Oct 10 2025, 11:03 AM
chmillman   So, following the excellent Pelican Parts instruct...   Oct 11 2025, 02:41 AM
chmillman   So, since I had everything mostly apart anyway, ju...   Oct 11 2025, 11:33 AM
Superhawk996   Wondering if I shouldn’t wire a relay from batt...   Oct 11 2025, 12:10 PM
chmillman   Your problem and symptoms are indicating you hav...   Oct 11 2025, 03:12 PM
Dave_Darling   Your car is a 74, I see. I didn't read throug...   Oct 11 2025, 03:43 PM
Superhawk996   Your car is a 74, I see. I didn't read throu...   Oct 12 2025, 11:32 AM
chmillman   IT'S FIXED... OK, you guys are going to have ...   Oct 12 2025, 11:35 AM
Superhawk996   Glad you’re back :driving: :Qarl:   Oct 12 2025, 12:12 PM
StarBear   Lesson learned and noted. Thanks!!   Oct 12 2025, 02:23 PM
JamesJ   So has it been determined that the $50 Porsch...   Oct 20 2025, 07:39 PM
- Lo-Fi Version Time is now: 28th April 2026 - 04:30 PM
