| JeffBowlsby |
Apr 16 2025, 03:29 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,245 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
"Ignition switches are junk"
Regularly hear this and similar consternation. I have continuously owned one or more 914s since 1998...think I have replaced only 1 ignition switches over that time, in one car. My current primary car I have had for over twenty years, still on the original switch as far as I know, I have not replaced it during my ownership. None my cars have ever had the added relay although I'm not against it. For those switches removed and in other key ignition switches I have opened up, what I see is part of the housing is cracked in similar locations. Maybe from years of torquing the key over? Not sure. I don't see melted housings (believe they are nylon), no smoke residue or anything out of line, just the cracked housing. Suspect the cracked housing causes some internal misalignment of the internal contacts...i.e. the switch goes bad and needs replacement. I am thinking the problem is the switch housings that break, not anything to do with excessive current flow through the switch. Educate me please. |
| chmillman |
Oct 12 2025, 11:35 AM
Member ![]() ![]() Group: Members Posts: 370 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
IT'S FIXED...
OK, you guys are going to have a good laugh, but here goes... So after trying various things via the cockpit including trying both new switches etc; checking the terminals on the relay panel in the engine compartment, I finally decided to see what kind of voltage I was getting from the yellow wire actually at the solenoid... So I lifted the car. Here is what I found: (IMG:style_emoticons/default/lol-2.gif) The backstory is this - a couple of weeks ago on a Friday afternoon I went to pick up the car at my friend the FI specialist - which is almost two hours from here. I already had experienced already occasional problems with the ignition switch, sometimes it took two or three key turns to get the starter to run. But figured this was something to be looked into later. I was able to start the car and back out of his shop, I drove a block to a gas station to grab a snack for the two hour drive home. Back to the car, key in the ignition, no start. Many, many tries, no dice. Finally i called him - he was still in the shop. He came up in his car and tried to get it started, no dice. Went back to his shop and got a few tools and was able to temporarily hotwire the starter, we drove it back to the shop. It being late and not having a replacement ignition switch anyway he installed a fat red wire from the solenoid to the engine compartment and said, just touch the wire to the battery + and the starter will run, so you can get home. But I didn't see HOW he had installed the red wire. I assumed he had installed in parallel with the yellow wire. However, as you see above, he actually disconnected it. So of course, even after having changed out the ignition switch - twice - it would not start... (IMG:style_emoticons/default/headbang.gif) I really should have looked underneath first. This is what happens when you assume things. I didn't like the way the original connector looked so I made a temporary splice. Didn't have any 4mm2 wire either nor a good sized insulated terminal, so I used 2x 2.5mm2 and soldered it to an uninsulated one for the time being. ![]() Lowered the car, got in turned the key and... VROOM! (IMG:style_emoticons/default/driving.gif) |
JeffBowlsby Whats wrong with our ignition switches? Apr 16 2025, 03:29 PM
wonkipop
Regularly... Apr 16 2025, 03:51 PM
Root_Werks Similar here, replaced only one in a 914 over 35+ ... Apr 16 2025, 04:05 PM
wonkipop @JeffBowlsby
just asked mike#1.
911 switches pro... Apr 16 2025, 04:25 PM
JeffBowlsby Without excessive current, then why the regular pr... Apr 16 2025, 04:37 PM
Superhawk996
Without excessive current, then why the regular p... Apr 16 2025, 04:56 PM
ctc911ctc Just thinking outloud.... there is no current limi... Apr 16 2025, 05:14 PM
Superhawk996
Not sure what the impulse current is on the Solin... Apr 16 2025, 08:13 PM
bdstone914
[quote name='ctc911ctc' post='3201402' date='Apr ... Apr 17 2025, 04:26 AM
Superhawk996
If it draws 25 amps you don't tonk it needs... Apr 17 2025, 07:14 AM
GregAmy
On the first point - I don’t think it’s fair ... Apr 17 2025, 07:27 AM
ctc911ctc I only have my personal experience
1970 1.7 - in... Apr 16 2025, 05:05 PM
bkrantz My car came with a relay added to the starter, a p... Apr 16 2025, 07:39 PM
Jgilliam914
My car came with a relay added to the starter, a ... Apr 17 2025, 03:28 PM
Dlee6205 Replacing ignition switches has become standard pr... Apr 16 2025, 07:50 PM
Superhawk996 Well know fact . . . When it doesn’t start if yo... Apr 16 2025, 08:08 PM
davep It was about 1975 that I purchased a used 73 914. ... Apr 16 2025, 08:22 PM
Justinp71 I added a relay because even after a new switch, o... Apr 16 2025, 09:40 PM
Superhawk996 Greg - You’re right about the roadside “relay... Apr 17 2025, 07:36 AM
GregAmy Far too often it is used to Band-Aid underlying is... Apr 17 2025, 08:34 AM
Dave97 I have another problem I’ve been chasing. 1975 ... Apr 17 2025, 08:26 AM
Superhawk996
I have another problem I’ve been chasing. 1975... Apr 17 2025, 09:18 AM
TheCabinetmaker
I have another problem I’ve been chasing. 1975... Oct 3 2025, 04:37 AM
JeffBowlsby I have not had the electrical portion of the switc... Apr 17 2025, 09:24 AM
Dave97 I tried jb weld, let it dry and then put it togeth... Apr 17 2025, 09:31 AM
Superhawk996
I tried jb weld, let it dry and then put it toget... Apr 17 2025, 10:05 AM
Ishley I’ m on my 3rd switch in 2 yrs. The first one th... Apr 17 2025, 08:51 PM
orthobiz When I bought my 1974 1.8 in 2007, the ignition sw... Apr 18 2025, 06:55 AM
ConeDodger
Regularly... Apr 18 2025, 07:46 AM
chmillman Mine went out yesterday... There are a bunch of r... Sep 30 2025, 08:52 AM
Ishley I've had several go out in 2 years...
The iss... Sep 30 2025, 10:32 AM
tomeric914
I spoke to George at Auto Atlanta to complain abo... Oct 11 2025, 06:39 AM
Olympic 914
About 10 years ago, my switch failed. I was... Oct 11 2025, 07:03 AM
Superhawk996
For those that have melted switches, one thing th... Oct 11 2025, 07:27 AM
tomeric914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 11 2025, 06:20 PM
Superhawk996
[b]@[url=http://www.914world.com/bbs2/index.php?... Oct 12 2025, 11:31 AM
chmillman Local Porsche dealer just called and said my repla... Oct 2 2025, 04:52 AM
JeffBowlsby Avoid cutting any wires. Just remove the 50 wire ... Oct 2 2025, 09:02 AM
chmillman Thanks @JeffBowlsby , will do...
Here is the par... Oct 2 2025, 11:31 AM
trojanhorsepower I'll add my experience. Hugh and I tried to s... Oct 2 2025, 05:41 PM
DRPHIL914 my 2cents worth and experience with my 15 years of... Oct 8 2025, 12:45 PM
chmillman So got the Partworks switch in a couple of days ag... Oct 9 2025, 02:50 AM
DRPHIL914
So got the Partworks switch in a couple of days a... Oct 9 2025, 06:10 AM
chmillman
so one difference that I see is that the top pic... Oct 9 2025, 08:20 AM
DRPHIL914
[quote name='DRPHIL914' post='3227384' date='Oct ... Oct 10 2025, 11:03 AM
chmillman So, following the excellent Pelican Parts instruct... Oct 11 2025, 02:41 AM
chmillman So, since I had everything mostly apart anyway, ju... Oct 11 2025, 11:33 AM
Superhawk996
Wondering if I shouldn’t wire a relay from batt... Oct 11 2025, 12:10 PM
chmillman
Your problem and symptoms are indicating you hav... Oct 11 2025, 03:12 PM
Dave_Darling Your car is a 74, I see. I didn't read throug... Oct 11 2025, 03:43 PM
Superhawk996
Your car is a 74, I see. I didn't read throu... Oct 12 2025, 11:32 AM
Superhawk996 Glad you’re back :driving: :Qarl: Oct 12 2025, 12:12 PM
StarBear Lesson learned and noted. Thanks!! Oct 12 2025, 02:23 PM
JamesJ So has it been determined that the $50 Porsch... Oct 20 2025, 07:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th April 2026 - 04:33 PM |
