SteveNMaine |
Member ![]() ![]() Group: Members Posts: 87 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None ![]() |
I recently started a rebuild on a seized 1.8. I found that moisture has seized the rings and the exhaust valve on #2 cylinder. The piston is seized near the top of the exhaust stroke.
Any suggestions to free up the piston rings? I have heated the top of the piston, used penetrating oil, tapped with a mallet, etc. So far, no joy. |
Artfrombama |
Artfrombama ![]() ![]() Group: Members Posts: 379 Joined: 21-January 24 From: North Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Add some penetrating oil to that cylinder, put the car in 3rd and rock the car fwd/backward.
Don't pry on the fan blades, they break easily |
SteveNMaine |
Artfrombama |
Add some penetrating oil to that cylinder, put the car in 3rd and rock the car fwd/backward. Don't pry on the fan blades, they break easily Engine is on an engine stand with that head removed. OK... Fashion a pusher to attach to the head studs and push the piston out of the cylinder. IE., like a harmonic balancer remover |
SteveNMaine |
Add some penetrating oil to that cylinder, put the car in 3rd and rock the car fwd/backward. Don't pry on the fan blades, they break easily Engine is on an engine stand with that head removed. OK... Fashion a pusher to attach to the head studs and push the piston out of the cylinder. IE., like a harmonic balancer remover Thanks, I'll give that a try tomorrow. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,939 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
[quote name='SteveNMaine' date='Oct 14 2025, 12:37 PM' post='3228134']
[quote name='Artfrombama' post='3228075' date='Oct 13 2025, 02:47 PM'] [quote name='SteveNMaine' post='3228068' date='Oct 13 2025, 02:24 PM'] [quote name='Artfrombama' post='3228065' date='Oct 13 2025, 01:06 PM'] Add some penetrating oil to that cylinder, put the car in 3rd and rock the car fwd/backward. Don't pry on the fan blades, they break easily [/quote] Engine is on an engine stand with that head removed. [/quote] OK... Fashion a pusher to attach to the head studs and push the piston out of the cylinder. IE., like a harmonic balancer remover [/quote] Thanks, I'll give that a try tomorrow. [/quote Keep the engine vertical and put some diesel in there let it soak for a while ,after that apply heat around the barrel area were the rings would be,repeat over and over...try it cheers. |
Lo-Fi Version | Time is now: 14th October 2025 - 01:56 AM |
