> Low oil pressure when warm, Crushed. Finally get to drive the car and the idiot light comes on
trojanhorsepower
post Oct 13 2025, 04:09 PM
A bit of background.
My engine (short block) was assembled wrong by a "professional" about 23 years ago before I got it. When I got it I finished assembling the rest of the motor and found the cam timing was wrong. After several posts and help from Jake Raby we found the cam gear had been installed backwards and a new hole drilled to make it fit. At that point Jake had me split the case, mic the cam and crank and get the numbers off the bearings. All that checked out. I rereassembled the engine and everything went well. Now 23 years later I have the engine in the car and it runs pretty well. (using Brad Penn 30wt break in oil) Except the oil pressure idiot light comes on at idle after the engine warms up. Maybe 10 min of driving. Now based on the threads I have read and the books I have there are no components that affect the oil pressure once the oil is warm? The check valves are for cold oil correct? Hot oil should just bypass the oil pressure bypass valves?
So I will change the oil for 20w50 VR1, but really am I just grasping at straws? What can actually cause this other than bearing wear? An out of spec oil pump? Anything else?
Thanks for the help
Peter
trojanhorsepower
post Oct 15 2025, 04:39 PM
I haven't yet. Just got a gauge last night.
trojanhorsepower   Low oil pressure when warm   Oct 13 2025, 04:09 PM
FlacaProductions   Are you feeding the idiot light from the stock/oem...   Oct 13 2025, 04:44 PM
trojanhorsepower   Thanks for the reply. I think it is the stock swi...   Oct 13 2025, 04:50 PM
FlacaProductions   Here's what they say at that link: (but I...   Oct 13 2025, 04:55 PM
trojanhorsepower   Yeah, I didn't understand that. So basically t...   Oct 13 2025, 05:14 PM
porschetub   Yeah, I didn't understand that. So basically ...   Oct 13 2025, 08:51 PM
emerygt350   No just when below 8 psi. You should get an oil p...   Oct 13 2025, 05:37 PM
FlacaProductions   Stock comes on lower - two-pole idiot light sender...   Oct 13 2025, 05:41 PM
BillC   Perhaps the oil pressure regulator is worn or the ...   Oct 13 2025, 06:00 PM
flxzcat   In my car (new to me) the light would often come o...   Oct 14 2025, 11:01 AM
brant   Since you already know the bearings are good/not w...   Oct 14 2025, 12:52 PM
Superhawk996   Never forget about the POS undersized T1 oil pumps...   Oct 14 2025, 02:20 PM
trojanhorsepower   Thanks all! I ordered Tangerine Racing oil byp...   Oct 14 2025, 02:48 PM
Superhawk996   I guess at some point I will change the oil pump ...   Oct 14 2025, 03:29 PM
Jack Standz   How about option 3? If the type 1 oil pump has ex...   Oct 14 2025, 03:50 PM
trojanhorsepower   I like the idea of buying something new just becau...   Oct 15 2025, 12:20 PM
930cabman   have you confirmed the low oil pressure with a kno...   Oct 15 2025, 04:12 PM
trojanhorsepower   I haven't yet. Just got a gauge last night.   Oct 15 2025, 04:39 PM
Superhawk996   30 mm pump is out of the question unless you’re ...   Oct 15 2025, 06:48 PM
trojanhorsepower   Update: Removed the old switch and installed a te...   Oct 16 2025, 05:18 PM
FlacaProductions   Oooh - did you bump something during the messing a...   Oct 16 2025, 05:26 PM
trojanhorsepower   Maybe, but nothing obvious I've seen yet. The ...   Oct 16 2025, 05:41 PM
trojanhorsepower   Sweet! CHT was disconnected. Running better...   Oct 17 2025, 05:25 PM
FlacaProductions   Excellent. Now maybe a new idiot light sender?   Oct 17 2025, 07:10 PM
brant   This seems very concerning if it were me Not belo...   Oct 18 2025, 05:46 AM
emerygt350   I assume you mean didn't drop below 10 at idle...   Oct 18 2025, 09:33 AM
trojanhorsepower   Sorry, correct, not below 10 at idle (only a few m...   Oct 18 2025, 11:57 AM
ChrisFoley   Out of curiosity is reasonable to change the byp...   Oct 19 2025, 01:00 PM
emerygt350   I am not sure. I put the tangerine bit in there w...   Oct 18 2025, 03:18 PM
Geezer914   2056 with CMP 26mm T1 pump. Tangerine oil pressur...   Oct 19 2025, 06:29 AM
trojanhorsepower   The latest: reminder -fresh build 4 cyl 2056, tang...   Nov 24 2025, 03:46 PM
emerygt350   Do you have a pressure gauge? I would want to kno...   Nov 25 2025, 07:24 AM
brant   Not an in car job Motor pull It’s all about the...   Nov 25 2025, 07:36 AM
trojanhorsepower   I had a pressure gauge rigged up for testing and d...   Nov 25 2025, 07:45 AM
Chad911sc   I have been, and still going through the same thin...   Nov 25 2025, 10:56 AM
VaccaRabite   Do you know what your bearing clearances are? Low...   Nov 25 2025, 01:49 PM
trojanhorsepower   20w50 oil. Bearing to crank checked out right. Be...   Nov 25 2025, 02:04 PM
trojanhorsepower   RESOLUTION! Boy when Jake says check everythi...   Jan 6 2026, 07:32 PM
FlacaProductions   Good work sticking with it - congrats.   Jan 6 2026, 09:50 PM
930cabman   Those German boys (and girls) didn't include m...   Jan 7 2026, 11:01 AM
brant   Those German boys (and girls) didn't include ...   Jan 7 2026, 02:28 PM
trojanhorsepower   Those German boys (and girls) didn't include ...   Jan 7 2026, 06:13 PM
- Lo-Fi Version Time is now: 21st September 2026 - 08:18 AM
