> Rocker panel rivets, (Again)
chmillman
post Oct 16 2025, 04:56 AM
Region Association: Europe
Thinking about pulling my rocker panels and having them repainted - they are looking a bit dingy and grayish. Plus all the discussions here about looking underneath…
They are currently held on by the plastic rivets - I think - they don’t look great and probably not salvageable. I thought I would put the panels back on with pop rivets, which seem like a more solid solution - black ones are available - I don’t mind having to drill them out if I want to remove the panels again at a later date. I don’t anticipate doing it often. Is there anything that argues strongly against this?
Front yard mechanic
post Oct 17 2025, 06:22 AM
Black screws easy on and off ( stupid little plastic rivets are for people with little fingers)Attached Image
bdstone914
post Oct 17 2025, 07:19 AM
bdstone914
QUOTE(Front yard mechanic @ Oct 17 2025, 05:22 AM) *
Those take screws. He is talking about the rocker panels not the carpet strips
chmillman   Rocker panel rivets   Oct 16 2025, 04:56 AM
emerygt350   I use aluminum rivets, drill out real easy. I hav...   Oct 16 2025, 05:12 AM
bdstone914   I just installed a set with aluminum pop rivets. I...   Oct 16 2025, 05:14 AM
Millerwelds   I am in the process of replacing all the miss mat...   Oct 16 2025, 06:06 AM
cassmcentee   I used Rivnuts and stainless hex bolts (same bolts...   Oct 16 2025, 06:04 AM
930cabman   I use aluminum pop rivets, a dab of black paint on...   Oct 16 2025, 02:38 PM
chmillman   OK, thanks all, I can easily get black ones here a...   Oct 16 2025, 02:47 PM
Front yard mechanic   Black screws easy on and off ( stupid little plast...   Oct 17 2025, 06:22 AM
bdstone914   Black screws easy on and off ( stupid little plas...   Oct 17 2025, 07:19 AM
rick 918-S   914 Rubber has the plastic Rivets   Oct 17 2025, 06:33 AM
Root_Werks   Dunno if this helps, I'm using SS rockers whic...   Oct 17 2025, 09:31 AM
FlacaProductions   @Root_Werks - did the stainless come pre-drilled ...   Oct 17 2025, 09:53 AM
Root_Werks   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 17 2025, 10:12 AM
Literati914   Black screws easy on and off ( stupid little pla...   Oct 17 2025, 11:02 AM
bkrantz   [quote name='bdstone914' post='3228657' date='Oct...   Oct 17 2025, 08:04 PM
Montreal914   @chmillman Not sure you got your answer on the h...   Oct 17 2025, 11:10 AM
FlacaProductions   @Root_Werks - thanks - that's helpful.   Oct 17 2025, 11:15 AM
chmillman   In the end I went with screws - because I found th...   Dec 8 2025, 05:26 AM
Aayala   In the end I went with screws - because I found t...   Dec 8 2025, 10:40 AM
chmillman   Do you mind taking a picture of where you install...   Dec 9 2025, 04:17 AM
rgalla9146   Depends on your car and how strict you are. M...   Dec 8 2025, 02:45 PM
DennisV   My 1970 has white plastic rivets as origina...   Dec 9 2025, 08:19 AM
914werke   When the rocker & sill are in good condition t...   Dec 11 2025, 06:59 PM
- Lo-Fi Version Time is now: 25th November 2026 - 04:22 AM
