> 123ignition to signal ecu?, or do I need a cranck trigger?
barkamatic
post Oct 16 2025, 03:36 PM
Purchased a 123 ignition for a D-Jet but due to the difficulty of finding D-Jet parts I have decided to go with an aftermarket system. Probably a silly question, but could I use the FI firing triggers from the distributor for a crank position signal? Thanks in advance.
JeffBowlsby
post Oct 18 2025, 01:39 AM
I have no predisposition about custom aftermarket FI (or carbs for that matter), they can be made to be all the things one hopes them to be, given enough time, and $.
One good thing about stock D-Jet is that it is out of the box plug N play. All parts are available still and that should continue to be the case well into the future. Replacing worn out parts is maintenance of a known system which may have challenges these days, but those are not insurmountable.
Consider that custom aftermarket FI opens up a wide variety of unknowns. Correct me if I am wrong, but I am not aware of any aftermarket FI system that is plug N play for our 914s, and that is their Achilles heel. Many of us wish that was not the current situation. They use components that are either generic, or from other vehicles, or are universal in design where they need to be adapted to the 914.
Some of the components may need custom mounts to fit the 914. Some of the electrical hardware does not use waterproof connections, and should not be exposed to our open engine bays. The harness is a major custom component that is very expensive in time and materials to develop and build, to adapt the generic FI to the 914. Once all the hardware is assembled and mounted, the task is to adjust and calibrate the ECU to the needs of the engine. Dyno time or similar efforts. Many who pursue the custom aftermarket FI path also change the engine from stock - displacement, valve timing (cam), ignition. None of this is wrong, but know that the effort and cost required to complete this successfully can be significant, much more than maintaining the stock system, especially if ones time has any value. And once it is complete, then this custom system needs maintenance from time to time, and as it is custom, who has the skills to do that other than the original builder? That can be an enormous devaluation when its time to sell the car. For the right person custom aftermarket FI is the right and maybe the only realistic solution. Just know what you are getting into.
barkamatic   123ignition to signal ecu?   Oct 16 2025, 03:36 PM
dtmehall   dude; you have left the reservation! keep yo...   Oct 16 2025, 08:17 PM
JeffBowlsby   Gotta ask, what djet parts are you missing? Your ...   Oct 16 2025, 08:27 PM
barkamatic   the car is a '73 2.0. Stock. I received the ca...   Oct 17 2025, 02:02 PM
barkamatic   By the way, I have read pretty much everything you...   Oct 17 2025, 02:05 PM
chmillman   Bought a D-Jet system off the internet but it was...   Oct 17 2025, 03:45 PM
barkamatic   Bought a D-Jet system off the internet but it wa...   Oct 17 2025, 06:22 PM
emerygt350   I think it would be great to document how you do i...   Oct 17 2025, 07:05 PM
barkamatic   I think it would be great to document how you do ...   Oct 17 2025, 08:05 PM
emerygt350   I think it would be great to document how you do...   Oct 17 2025, 08:10 PM
dtmehall   the trigger points on the old D* systems were neve...   Oct 17 2025, 08:48 PM
Superhawk996   Probably a silly question, but could I use the F...   Oct 17 2025, 08:51 PM
barkamatic   Probably a silly question, but could I use the ...   Oct 17 2025, 09:26 PM
Superhawk996   Bottom line: D-jet injectors are bank fired and sh...   Oct 17 2025, 09:47 PM
barkamatic   Bottom line: D-jet injectors are bank fired and s...   Oct 17 2025, 10:23 PM
JeffBowlsby   I have no predisposition about custom aftermarket ...   Oct 18 2025, 01:39 AM
chmillman   I agree 100% with @jeffbowlsby about the downsid...   Oct 18 2025, 03:49 AM
barkamatic   I agree 100% with [b]@[url=http://www.914world.c...   Oct 18 2025, 10:00 AM
JeffBowlsby   With all due respect, evidently our reasons for o...   Oct 18 2025, 10:26 AM
emerygt350   My mustangs tbi could care less about position of ...   Oct 18 2025, 09:42 AM
Superhawk996   My mustangs tbi could care less about position of...   Oct 18 2025, 10:11 AM
barkamatic   My mustangs tbi could care less about position o...   Oct 18 2025, 11:23 AM
- Lo-Fi Version Time is now: 27th July 2026 - 12:53 AM
