| ctc911ctc |
Oct 19 2025, 06:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,266 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1974, 2.0 all stock and original
Teeners I rebuilt the front end , bushings, hardware, brakes, everything powder coated and also stock bilstien inserts 2 years ago http://www.914world.com/bbs2/index.php?sho...7&hl=Powder On the right front when the suspension is unloaded, it clanks - loud I inspected for safety today and will take the suspension apart to inspect the insert asap Any guidance as to what it could be? Thank you teeners! |
| L-Jet914 |
Oct 19 2025, 06:46 PM
Member ![]() ![]() Group: Members Posts: 365 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
The torque spec from Bilstein was 95ft lbs + or - 7ft lbs (little paper instruction insert that comes with the inserts) for the strut insert retaining nut. I had a clunk from the left front on my father's 914 before I replaced the strut inserts. Found the left front strut insert retaining nut was finger tight from the person who installed them in a repair shop many years ago before I started to go through my father's 914. I torqued the retaining nuts to spec with the Bilstein tool adapter when I put the new strut inserts in. No more clunk.
ctc911ctc Bilstien strut Noise Oct 19 2025, 06:03 PM
rjames Check to see if the gland nut is tight. Torque spe... Oct 19 2025, 06:12 PM
ctc911ctc Gland-nut? Well my mind went there, will figure o... Oct 19 2025, 06:26 PM
ctc911ctc
The torque spec from Bilstein was 90ft lbs (littl... Oct 19 2025, 06:51 PM
L-Jet914
The torque spec from Bilstein was 90ft lbs (litt... Oct 19 2025, 09:52 PM
914Sixer Tool is $8+shipping a Sierra Madre Corp Oct 20 2025, 05:48 AM
mepstein A locking tool used for bicycle bottom brackets wo... Oct 20 2025, 07:21 AM
ctc911ctc Don't tell anyone - I may use the pipe wrench ... Oct 20 2025, 09:34 AM
Don't tell anyone - I may use the pipe wrench... Oct 20 2025, 11:43 AM
ctc911ctc Used the pipe wrench method, car back together and... Nov 4 2025, 12:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2025 - 08:33 PM |
