| roundtwo |
Jun 13 2021, 06:48 PM
Member ![]() ![]() Group: Members Posts: 372 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California
Trying to get prepped for all my welding needs. Id like to Pre-fit the rear sway bar so I can determine exactly we’re to mount the bushing mount backing plates. I want to be sure they’re perpendicular to the sway bar in just the right spot
1. See first pick. Do I install the bushings in the drop links first and then install the ball ends? Or, do I install the ball cups on the balls and then have them pressed into the drop links? Any tips on how to get these hard bushings into the drop links? 2. Do I simply replace the new shock base metal rod labeled #1 with #2. See second pic I’ve read the rear sway bar mounts instructions on the Pelican Parts web site. Very helpful- He just doesn’t cover the actual sway bar assembly. Bar is 16mm. Installing on a 1970. Many thanks. |
| LefthandRev |
Dec 22 2021, 03:58 PM
Member ![]() ![]() Group: Members Posts: 87 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
I used a heat gun, a dull flat head screwdriver, and a bench vice to get them started.
Open-side of the bushing first. Hold the heat gun, warm up the bushing. No higher than 200F, or you start to bubble the silicone. Push the lip through the ring and work it in slowly until about 90% (or all if you can manage) is started through the ring. Pull the drop-arm out of the vice and with luck, the bushing will not pop off. Now, put the bushing into the vice along the thin portion and tighten it down. Using your screwdriver, inside it into the bushing and pull the lip of the bushing outward through the ring of the arm until it's fully seated. Rinse, wash, repeat, curse, repeat, curse, repeat, curse... |
| TRP |
Oct 18 2025, 11:19 PM
Member ![]() ![]() Group: Members Posts: 460 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
I used a heat gun, a dull flat head screwdriver, and a bench vice to get them started. Open-side of the bushing first. Hold the heat gun, warm up the bushing. No higher than 200F, or you start to bubble the silicone. Push the lip through the ring and work it in slowly until about 90% (or all if you can manage) is started through the ring. Pull the drop-arm out of the vice and with luck, the bushing will not pop off. Now, put the bushing into the vice along the thin portion and tighten it down. Using your screwdriver, inside it into the bushing and pull the lip of the bushing outward through the ring of the arm until it's fully seated. Rinse, wash, repeat, curse, repeat, curse, repeat, curse... This is a pretty old thread, but this worked like a charm. Thank you! Ted |
| wonkipop |
Oct 19 2025, 12:08 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,758 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
I used a heat gun, a dull flat head screwdriver, and a bench vice to get them started. Open-side of the bushing first. Hold the heat gun, warm up the bushing. No higher than 200F, or you start to bubble the silicone. Push the lip through the ring and work it in slowly until about 90% (or all if you can manage) is started through the ring. Pull the drop-arm out of the vice and with luck, the bushing will not pop off. Now, put the bushing into the vice along the thin portion and tighten it down. Using your screwdriver, inside it into the bushing and pull the lip of the bushing outward through the ring of the arm until it's fully seated. Rinse, wash, repeat, curse, repeat, curse, repeat, curse... This is a pretty old thread, but this worked like a charm. Thank you! Ted you wont regret a front and rear sway bar install on your 1.8 if thats what you have done. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) grins from ear to ear. after all its a 1.8 and going around corners insanely flat is just about it --------if you know what i mean -------but its grins and grins and more grins. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) i have a 1.8 with the factory sway bars original. the first owner knew what he (or was it she?) was doing when they ticked the box on a base spec 74 1.8. that and the obscure but very practical storage box. who needs a console with all those guages. they just make you worry you are about to blow the engine up or cause the fan belt to flick off. and time, well you got a wrist watch for worrying about that. but you got to have somewhere to chuck your cigs or your hand bag. (IMG:style_emoticons/default/biggrin.gif) seriously the original owners on mine sure had taste in spades ticking that one "performance" box. |
| TRP |
Oct 19 2025, 09:12 PM
Today I wrapped up the rear sway bar today. This week I will finish the front swaybar install. Should be awesome. (IMG:style_emoticons/default/smile.gif)
roundtwo Rear Sway bar install Jun 13 2021, 06:48 PM
roundtwo Adding sway bar on this build
Jun 13 2021, 06:50 PM
ClayPerrine The big bolt with the ball end replaces the lower ... Jun 13 2021, 07:07 PM
bkrantz I put the bushings into the drop links first (used... Jun 13 2021, 07:38 PM
barefoot
I put the bushings into the drop links first (use... Jun 14 2021, 11:12 AM
ClayPerrine
I put the bushings into the drop links first (use... Jun 14 2021, 12:21 PM
NARP74 I just went through this, mine had the mounting br... Jun 14 2021, 12:41 PM
roundtwo Appreciate all the secrets!
Able to get in th... Jun 14 2021, 07:39 PM
76-914 Do like Clay said. A giant pair of channel locks a... Jun 14 2021, 08:55 PM
roundtwo
Do like Clay said. A giant pair of channel locks ... Jun 14 2021, 10:43 PM
914werke . I used glycerin. I didn't need to heat them... Dec 22 2021, 04:53 PM
TonyA I used a pair of cabinet clamps from harbor freigh... Jul 28 2026, 03:58 PM
porschetub
I used a pair of cabinet clamps from harbor freig... Jul 28 2026, 06:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 12:57 AM |
