> left turn signal problems, feel like i have tried everything
jeff dodge
post Oct 10 2025, 04:37 PM
I am having trouble with my left turn signal. Let me detail; ground tested and is good, replaced , replaced column switch, new relays, new bulbs, swapped housings from left to right, new fuses. noticed that when I clicked the emergency flashers it blew that fuse. Right works fine, the left turn filament is very dim and the read does not do anything. I have spent two weeks trying to track this down. I have built entire harnesses for vintage race cars and this has me baffled. Please help! Thanks, Jeff
Spoke
post Oct 12 2025, 06:21 PM
Jerry
QUOTE(jeff dodge @ Oct 10 2025, 06:37 PM) *
What was changed before this issue came up?
You may want to completely disconnect the front and rear light housings and test. At a minimum, remove both left side bulbs.
' the left turn filament is very dim and the read does not do anything.'
The left side might have a near short which would allow just a little voltage to the bulb. Is the front dim and the rear out completely? The short may be in the rear housing wiring. Again it might be prudent to remove all wires from the rear and see if the fuse blows.
A guy brought his 911 to me where he had to put a 25A fuse in the left side turnsignal to keep it from blowing. The front turnsignal was dim and the rear was out. The fuse was getting hot. We disconnected the rear wire at the fuse panel and the front turnsignal got bright as expected and the fuse was cool. There was some short in the rear housing.
scallyk9
post Oct 16 2025, 03:10 PM
QUOTE(Spoke @ Oct 12 2025, 05:21 PM) *
That fellow's 911 experience is what happened to my 914 but on the right side. Dim right turn signal and the right rear was out, plus rear taillight was dim. It took time to diagnose but turned out that the right front fender side indicator light was wired in reverse causing a short. It took me time to realize the front electrical short's effect on the rear lights until i noticed the side light functioning as a dim turn signal.
jeff dodge
post Oct 17 2025, 11:46 AM
QUOTE(scallyk9 @ Oct 16 2025, 04:10 PM) *
Thanks for the info! I will check the front and rear housings. It will probably be something really simple and I will be kicking myself.
jeff dodge
post Oct 20 2025, 03:02 PM
QUOTE(jeff dodge @ Oct 17 2025, 12:46 PM) *
I sent a post which apparently did not go through so I will send the pertinent info. All of the housings checked out. every light works, (left front works, but dim. left rear turn does not). The wiring that I have checked good with the exception of the bk/wt at left rear. all bulbs and turn switch replaced.relays replaced. Could it be the emergency flasher switch? Thanks, Jeff
Spoke
post Oct 22 2025, 06:01 AM
Jerry
QUOTE(jeff dodge @ Oct 20 2025, 05:02 PM) *
Please detail what you mean with 'every light works' but then you say the left front is dim and rear is out.
Are you using incandescent bulbs or LEDs. Shouldn't matter, just want to check.
At this point I'd remove every wire on the rear housing and see if the front becomes bright.
The front and rear turnsignals are powered in parallel although the rear has a lot more wire between the source (flasher relay + hazard switch) and ground.
Doubtful if the switch is at fault as all the turnsignal wires start at the switch. The front is getting some voltage but the rear is getting no voltage. Kinda points to the rear having some short circuit. It's easy to pull the wires from the rear housing to eliminate wiring to the housing and the housing from the equation.
jeff dodge   left turn signal problems   Oct 10 2025, 04:37 PM
jim_hoyland   There’s a possibility the TS switch has a short ...   Oct 10 2025, 06:33 PM
Dave_Darling   A dim light says to me that you've got either ...   Oct 11 2025, 01:49 AM
jeff dodge   A dim light says to me that you've got either...   Oct 12 2025, 10:28 AM
Spoke   I am having trouble with my left turn signal. Let...   Oct 12 2025, 06:21 PM
scallyk9   I am having trouble with my left turn signal. Le...   Oct 16 2025, 03:10 PM
jeff dodge   [quote name='Spoke' post='3227996' date='Oct 12 2...   Oct 17 2025, 11:46 AM
jeff dodge   [quote name='Spoke' post='3227996' date='Oct 12 ...   Oct 20 2025, 03:02 PM
jeff dodge   [quote name='jeff dodge' post='3228695' date='Oct...   Oct 21 2025, 04:13 PM
Spoke   All of the housings checked out. every light work...   Oct 22 2025, 06:01 AM
jeff dodge   All of the housings checked out. every light wor...   Oct 22 2025, 02:22 PM
jeff dodge   All of the housings checked out. every light wor...   Oct 23 2025, 04:39 PM
jeff dodge   [quote name='Spoke' post='3229355' date='Oct 22 2...   Oct 23 2025, 04:50 PM
NARP74   I had some stuff in my rear trunk hit the tail lig...   Oct 16 2025, 04:34 PM
Spoke   OK, let me make sure I understand what's hap...   Oct 23 2025, 07:53 PM
jeff dodge   OK, let me make sure I understand what's ha...   Oct 25 2025, 08:23 PM
jeff dodge   I appreciate all of the help that I am get from fo...   Oct 24 2025, 08:17 PM
Ishley   You might want to check all the bulbs and fixture....   Oct 25 2025, 09:01 PM
jeff dodge   You might want to check all the bulbs and fixture...   Oct 30 2025, 10:22 AM
jeff dodge   You might want to check all the bulbs and fixtur...   Oct 30 2025, 11:27 AM
Superhawk996   You’re going to have to work with a wiring diagr...   Oct 30 2025, 11:44 AM
black73   Are the rear license plate lights in that circuit?...   Oct 31 2025, 03:40 AM
jeff dodge   Are the rear license plate lights in that circuit...   Oct 31 2025, 09:42 AM
Spoke   It might be useful to check the resistance in the ...   Oct 31 2025, 10:02 AM
NARP74   @jeff dodge Did this ever get resolved? I am hav...   Jul 20 2026, 11:55 AM
- Lo-Fi Version Time is now: 21st July 2026 - 05:28 AM
