| dlindzey |
Oct 22 2025, 09:54 AM
repeat offender ![]() ![]() Group: Members Posts: 51 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
I can't even find a shop willing to change my oil so I am going to have to crawl around on the floor for a while. I have all the parts and a creeper but get confused on where you can put a floor jack and where you should put a jack stand as seems like same point is best for both the jack and the stands.
I have located the 4 donuts at the corners of the cab/chasis juncture, they seem ok. I am tempted to just get two floor jacks and jack up the rear at the donuts and call it a day. Is it dangerous to use jacks for support rather than putting a jack stand under there somewhere? Ramps won't work as exhaust tip hits the ramp. How do most of you solve this issue? |
| dlindzey |
Oct 22 2025, 12:09 PM
thanks for all the feedback
when putting jackstands under do you jack the car up 12" and put a stand in place and then go the other side or do you go back and forth inch at a time or----any technique to minimize potential damage? |
| Superhawk996 |
Oct 22 2025, 12:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
thanks for all the feedback when putting jackstands under do you jack the car up 12" and put a stand in place and then go the other side or do you go back and forth inch at a time or----any technique to minimize potential damage? Ya. It all sort of depends on your jack and the stands you have. But as a general statement - lifting one side too high all at once can side load the jack stands which isn’t a good idea. Keep an eye on the opposite stand what lifting to make sure it isn’t side loading and/or getting tippy. |
dlindzey Is there a simple way to get a 914 jacked up enough to change oil Oct 22 2025, 09:54 AM
mepstein You absolutely need jack stands or at the very lea... Oct 22 2025, 10:04 AM
emerygt350 I wouldn't let a shop change my oil. Too much... Oct 22 2025, 10:19 AM
Superhawk996 Never . . . Ever . . . Get under a jacked up car w... Oct 22 2025, 11:22 AM
emerygt350
Never . . . Ever . . . Get under a jacked up car ... Oct 22 2025, 11:30 AM
rjames I had issues with the tailpipe hitting the ramps I... Oct 22 2025, 11:30 AM
gereed75 The cylindrical inner portion of the trailing arms... Oct 22 2025, 12:22 PM
Jack Standz
I can't even find a shop willing to change my... Oct 22 2025, 01:11 PM
Osnabruck914 Quote from Jack Standz - "Those "donuts... Oct 22 2025, 05:36 PM
emerygt350
Quote from Jack Standz - "Those "donuts... Oct 22 2025, 07:42 PM
Quote from Jack Standz - "Those "donut... Oct 22 2025, 08:06 PM
Jack Standz
Quote from Jack Standz - "Those "donuts... Oct 23 2025, 12:16 AM
wonkipop as a uni student i used to park my old type 3 vari... Oct 23 2025, 01:26 AM
914043 Is using the engine with a protective soft piece ... Oct 23 2025, 09:41 PM
rgalla9146
Is using the engine with a protective soft piece... Oct 24 2025, 06:38 AM
KELTY360
Is using the engine with a protective soft piec... Oct 24 2025, 09:15 AM
808 WRX I made ramps out of 2x10's: Oct 24 2025, 10:26 AM
rjames
Exactly what I ... Oct 24 2025, 12:10 PM
GBX0073 Low profile (Daytona harbor freight) jack Placed i... Oct 23 2025, 10:48 PM
L-Jet914 I used to use the old school metal drive on ramps.... Oct 23 2025, 11:36 PM
sixnotfour :beer2: Me too..since 1978 :beer1: :popcorn: Oct 24 2025, 07:59 AM
Ninja :agree:
I also put the front up as well. Don... Oct 24 2025, 08:59 AM
BillC RaceRamps makes very nice wheel cribs. I use two ... Oct 24 2025, 11:53 AM
Shivers I jack up on the passenger side and use a stand un... Oct 24 2025, 12:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:21 PM |
