| dlindzey |
Oct 22 2025, 09:54 AM
repeat offender ![]() ![]() Group: Members Posts: 51 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
I can't even find a shop willing to change my oil so I am going to have to crawl around on the floor for a while. I have all the parts and a creeper but get confused on where you can put a floor jack and where you should put a jack stand as seems like same point is best for both the jack and the stands.
I have located the 4 donuts at the corners of the cab/chasis juncture, they seem ok. I am tempted to just get two floor jacks and jack up the rear at the donuts and call it a day. Is it dangerous to use jacks for support rather than putting a jack stand under there somewhere? Ramps won't work as exhaust tip hits the ramp. How do most of you solve this issue? |
| Jack Standz |
Oct 22 2025, 01:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
I can't even find a shop willing to change my oil so I am going to have to crawl around on the floor for a while. I have all the parts and a creeper but get confused on where you can put a floor jack and where you should put a jack stand as seems like same point is best for both the jack and the stands. I have located the 4 donuts at the corners of the cab/chasis juncture, they seem ok. I am tempted to just get two floor jacks and jack up the rear at the donuts and call it a day. Is it dangerous to use jacks for support rather than putting a jack stand under there somewhere? Ramps won't work as exhaust tip hits the ramp. How do most of you solve this issue? Those "donuts" are not designed to jack up your 914. They will bend/deform. Use a jack plate inserted into the jack point Porsche designed for jacking up your 914. Here is a diagram showing where you can place stands. Although it shows the "donuts" in the diagram, those are not good/safe locations for jacking up your 914. You decide where its safe and less prone to damage your 914. When we don't jack up the 914 using the jacking point, we use a 4x4 (maybe it's 6x6?) piece of hardwood that goes almost the entire width of the car and is placed under the firewall when jacking up the rear and under the area behind the front cross member when jacking up the front. Since we use a 4 post lift and two tall stands, it is very quick. One stand on each side of the 4x4 and then lower the lift and lock the safety catches and we're ready to work. Best wishes for a safe oil change. One final comment. It is very very dangerous to have an incompetent shop/mechanic change the oil on a 914. If the bolt that fastens the strainer cover is tightened with too much torque, you can end up with "type iv syndrome ". This is where the internal part of your engine case breaks and pretty much destroys the engine. At a minimum it's a very expensive repair. Attached image(s)
dlindzey Is there a simple way to get a 914 jacked up enough to change oil Oct 22 2025, 09:54 AM
mepstein You absolutely need jack stands or at the very lea... Oct 22 2025, 10:04 AM
emerygt350 I wouldn't let a shop change my oil. Too much... Oct 22 2025, 10:19 AM
Superhawk996 Never . . . Ever . . . Get under a jacked up car w... Oct 22 2025, 11:22 AM
emerygt350
Never . . . Ever . . . Get under a jacked up car ... Oct 22 2025, 11:30 AM
rjames I had issues with the tailpipe hitting the ramps I... Oct 22 2025, 11:30 AM
dlindzey thanks for all the feedback
when putting jackstand... Oct 22 2025, 12:09 PM
Superhawk996
when putting jackstan... Oct 22 2025, 12:25 PM
gereed75 The cylindrical inner portion of the trailing arms... Oct 22 2025, 12:22 PM
Osnabruck914 Quote from Jack Standz - "Those "donuts... Oct 22 2025, 05:36 PM
emerygt350
Quote from Jack Standz - "Those "donuts... Oct 22 2025, 07:42 PM
Quote from Jack Standz - "Those "donut... Oct 22 2025, 08:06 PM
Jack Standz
Quote from Jack Standz - "Those "donuts... Oct 23 2025, 12:16 AM
wonkipop as a uni student i used to park my old type 3 vari... Oct 23 2025, 01:26 AM
914043 Is using the engine with a protective soft piece ... Oct 23 2025, 09:41 PM
rgalla9146
Is using the engine with a protective soft piece... Oct 24 2025, 06:38 AM
KELTY360
Is using the engine with a protective soft piec... Oct 24 2025, 09:15 AM
808 WRX I made ramps out of 2x10's: Oct 24 2025, 10:26 AM
rjames
Exactly what I ... Oct 24 2025, 12:10 PM
GBX0073 Low profile (Daytona harbor freight) jack Placed i... Oct 23 2025, 10:48 PM
L-Jet914 I used to use the old school metal drive on ramps.... Oct 23 2025, 11:36 PM
sixnotfour :beer2: Me too..since 1978 :beer1: :popcorn: Oct 24 2025, 07:59 AM
Ninja :agree:
I also put the front up as well. Don... Oct 24 2025, 08:59 AM
BillC RaceRamps makes very nice wheel cribs. I use two ... Oct 24 2025, 11:53 AM
Shivers I jack up on the passenger side and use a stand un... Oct 24 2025, 12:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:51 PM |
