> troubles with ignition 123, Dead dizzy got me dizzy
wbgoggans
post Oct 21 2025, 12:15 PM
I purchased a 123 Tune-4-R-V-V distributor after hearing all the ranting and raving about it here (and on a few other forums). Using some of the detailed posts on this site, I was able to get my motor fired up on the stand with the 123 — but after less than five minutes of run time, while I was tweaking a fuel line, I suddenly heard the Bluetooth disconnect.
When I checked the distributor, there was no blue light and no green light under the rotor. I reached out to Ed at 123 Ignition, who was very helpful and suggested I send the distributor in for warranty repair.
Once Ed received it, he found that the board inside the distributor was completely dead. He replaced the board and shipped it back to me. I reinstalled it Sunday night and began statically timing the motor — and then after 10 minutes or so this time without even getting to hear my motor run my dizzy is dead with the same symptoms as before.
Ed has kindly offered to replace the board again, but after already spending $50 in shipping to and from Ohio and waiting two weeks, I’m not eager to repeat the process without knowing why this keeps happening. At this point, I have a $600 paperweight and no clear explanation and no hope that replacing the board again will give me a different result.
So, I’m hoping to tap into the collective brainpower of 914World to figure this out. I’ve already tested my coil and will be sending Ed photos of my run setup tomorrow.
If anyone has suggestions or ideas on what could be frying the dizzy, please let me know — I’m happy to provide any details or photos that might help diagnose the issue.
Thanks in advance for the help!
yeahmag
post Oct 22 2025, 02:43 PM
Just an idiot check. From the website:
wiring: red = +6V or +12V, black = '-' coil, blue = ground
I don't think it would survive wiring it wrong at all, but who knows. As far as voltage spikes, if you are on the battery only and the battery isn't on a charger it's pretty unlikely to be the problem. Certainly checking the voltage at different points and making sure the ground is good will go a long way to eliminating the possibilities. If the ground lifts, you may have issues. I did with my Mallory Unilite a few times...
wbgoggans   troubles with ignition 123   Oct 21 2025, 12:15 PM
Ishley   I have the same distributor and it works great aft...   Oct 21 2025, 01:09 PM
wbgoggans   I have the same distributor and it works great af...   Oct 21 2025, 01:37 PM
Ishley   That’s unfortunate. I have a folder called 123...   Oct 21 2025, 04:36 PM
wbgoggans   That’s unfortunate. I have a folder called 123...   Oct 21 2025, 05:26 PM
wbgoggans   [quote name='Ishley' post='3229266' date='Oct 21 ...   Oct 21 2025, 05:27 PM
emerygt350   Have you double checked your polarity? It's p...   Oct 21 2025, 06:38 PM
wbgoggans   Have you double checked your polarity? It's ...   Oct 22 2025, 10:51 AM
chmillman   I am running a Beru blue ignition coil purchased ...   Oct 22 2025, 02:14 PM
dtmehall   maybe i shouldn't state the obvious, but could...   Oct 21 2025, 07:37 PM
wbgoggans   maybe i shouldn't state the obvious, but coul...   Oct 22 2025, 11:06 AM
Superhawk996   If I’m reading correctly this is occurring on a ...   Oct 22 2025, 11:30 AM
wbgoggans   If I’m reading correctly this is occurring on a...   Oct 22 2025, 01:14 PM
wbgoggans   If I’m reading correctly this is occurring on a...   Oct 22 2025, 01:15 PM
yeahmag   Just an idiot check. From the website: wiring: re...   Oct 22 2025, 02:43 PM
FlacaProductions   123 site says Coil:"stock or High Energy coil...   Oct 22 2025, 03:17 PM
emerygt350   I don't have experience with the bluetooth ver...   Oct 22 2025, 03:45 PM
wbgoggans   Ed has said my coil should not be an issue. what m...   Oct 22 2025, 04:19 PM
mate914   Ed has said my coil should not be an issue. what ...   Oct 22 2025, 05:28 PM
Superhawk996   Ed has said my coil should not be an issue. what ...   Oct 22 2025, 06:52 PM
dtmehall   The Enshitification Of Everything As Seen In Commo...   Oct 22 2025, 06:59 PM
123ignitionusa   Hey guys, I am wondering, if the grounds are not s...   Oct 22 2025, 07:09 PM
Superhawk996   So I guess the question for the electrical engi...   Oct 22 2025, 08:44 PM
davep   Generally an ungrounded circuit has no reference, ...   Oct 22 2025, 08:58 PM
wbgoggans   I really appreciate the help everyone has provided...   Oct 23 2025, 05:04 PM
dtmehall   Superhawk996 you are correct in your description ...   Oct 23 2025, 07:43 PM
- Lo-Fi Version Time is now: 23rd October 2025 - 10:31 PM
