| densible1 |
Oct 22 2025, 05:37 PM
Newbie ![]() Group: Members Posts: 47 Joined: 5-April 22 From: Hermosa Beach Member No.: 26,444 Region Association: Southern California |
Just reinstalled my type 4 engine back into car everything wired up as before, upon initial start engine fired right up pretty effortlessly and continued to do so after several starts starter motor kicks in and , a HiTorque IMF, it actuates solenoid and motor spins right up. After bout 1/2 dozen starts the starter only activates the solenoid but no spin. I can hear the solenoid engaging. This is an old starter but haven't had problems before the engine re-install. I removed starter and bench tested with 12 volt leads and jumper cable on solenoid and it engages and spins readily. What's going on?
| fixer34 |
Oct 22 2025, 07:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,349 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Chassis ground strap to transmission?
densible1 Starter Motor no work Oct 22 2025, 05:37 PM
burton73
Just reinstalled my type 4 engine back into car e... Oct 22 2025, 06:09 PM
densible1 That’s right the starter never seemed to get hot... Oct 22 2025, 06:17 PM
Lockwodo Ground problem or defective battery cable? And of... Oct 22 2025, 06:20 PM
densible1 Battery putting out 14 volts. Will test in car ... Oct 22 2025, 06:38 PM
Lockwodo
Battery putting out 14 volts. Will test in car... Oct 23 2025, 07:40 AM
emerygt350 I would bet on a ground issue. Run an extra groun... Oct 22 2025, 07:35 PM
densible1 Yep Oct 22 2025, 07:50 PM
bdstone914
Yep
Measure the resistance from the transmissi... Oct 22 2025, 08:32 PM
densible1 will test that in the morning. Think the starter ... Oct 22 2025, 08:44 PM
porschetub
will test that in the morning. Think the starter... Oct 22 2025, 10:14 PM
Root_Werks Can you rotate the engine by hand?
And I second o... Oct 23 2025, 12:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2025 - 10:32 PM |
