| hndyhrr |
Oct 21 2025, 06:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 661 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
Got the MC installed, all lines attached.
Watched Ian Karr's video. Started to bleed, seeing old brake fluid and lots of bubbles, after about fifteen minutes of this I am not seeing a stream of fluid coming down the clear plastic tube. Yes the end is submerged in brake fluid. Checked for leaks at the MC and dry as a bone. Check inside car and dry also. I have never done this before so just wondering and asking for suggestions, ideas and don't do that. Thanks Renee (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/beer.gif) |
| Jack Standz |
Oct 22 2025, 12:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Except for DOT 5 (which is silicone-based), brake fluid is hygroscopic, meaning it absorbs moisture from the air over time. This property can lower the fluid’s boiling point, leading to issues like brake fade and reduced performance under high temperatures. Water in your brake fluid also promotes corrosion.
As a regular part of maintaining your 914, you should flush your brake fluid to address this issue. So, you should avoid recycling old brake fluid into the reservoir during the bleeding or flushing process as the water present in your brake fluid will not get purged. +1 on the Motive bleeder and there are YouTube videos that document how to use one. Works well and you can bleeder your 914's brake system without a second person. |
| rjames |
Oct 22 2025, 02:40 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,395 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Except for DOT 5 (which is silicone-based), brake fluid is hygroscopic, meaning it absorbs moisture from the air over time. This property can lower the fluid’s boiling point, leading to issues like brake fade and reduced performance under high temperatures. Water in your brake fluid also promotes corrosion. As a regular part of maintaining your 914, you should flush your brake fluid to address this issue. So, you should avoid recycling old brake fluid into the reservoir during the bleeding or flushing process as the water present in your brake fluid will not get purged. +1 on the Motive bleeder and there are YouTube videos that document how to use one. Works well and you can bleeder your 914's brake system without a second person. Agreed. My suggestion of connecting the bleeder hose back to the reservoir assumes all the old fluid has been removed first. Many a home mechanic like myself have wasted a decent amount of new fluid just trying to get the air out of the system. Routing the bled fluid back to the reservoir not only reduces waste, but also keeps you from having to refill the reservoir during the bleeding process. |
| porschetub |
Oct 22 2025, 09:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,945 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Except for DOT 5 (which is silicone-based), brake fluid is hygroscopic, meaning it absorbs moisture from the air over time. This property can lower the fluid’s boiling point, leading to issues like brake fade and reduced performance under high temperatures. Water in your brake fluid also promotes corrosion. As a regular part of maintaining your 914, you should flush your brake fluid to address this issue. So, you should avoid recycling old brake fluid into the reservoir during the bleeding or flushing process as the water present in your brake fluid will not get purged. +1 on the Motive bleeder and there are YouTube videos that document how to use one. Works well and you can bleeder your 914's brake system without a second person. Agreed. My suggestion of connecting the bleeder hose back to the reservoir assumes all the old fluid has been removed first. Many a home mechanic like myself have wasted a decent amount of new fluid just trying to get the air out of the system. Routing the bled fluid back to the reservoir not only reduces waste, but also keeps you from having to refill the reservoir during the bleeding process. (IMG:style_emoticons/default/agree.gif) bought a kit just for the job (not Motive ) and it is so good on my other cars also , cheers. |
hndyhrr Bleeding Mast Cylinder in the car Oct 21 2025, 06:40 PM
DennisV
I have never done this before so just wondering a... Oct 21 2025, 07:18 PM
hndyhrr
I have never done this before so just wondering ... Oct 21 2025, 08:32 PM
infraredcalvin Using a motive power bleeder? I’ve never had to... Oct 22 2025, 01:19 AM
rjames I couldn't get the air out until I replaced al... Oct 22 2025, 10:41 AM
flxzcat
Try the long hose method. Attach a hose at the b... Oct 22 2025, 12:52 PM
VaccaRabite I like to use a motive to keep the reservoir full.... Oct 23 2025, 10:49 AM
GeorgeKopf I just installed a completely new (and dry) brake ... Oct 23 2025, 01:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2025 - 03:04 AM |
