> Aux air regulator prototype
emerygt350
post Oct 17 2025, 09:16 AM
Well, it works on my desk and it works on 12v. Might get around to trying it in the car today.
emerygt350
post Oct 23 2025, 07:33 AM
Here are my routines so far. Anybody think of any other things I can try to address with the AAR? The temp sensor is ambient temp, about 3 or 4 inches from the block.
#define ADC_VREF_mV 5000.0 // in millivolt
#define ADC_RESOLUTION 6000.0
#define PIN_LM35 A0
// constants won't change
const int RELAY_PIN = D8; // the Arduino pin, which connects to the IN pin of relay
void setup() {
Serial.begin(9600);
// initialize digital pin as an output.
pinMode(RELAY_PIN, OUTPUT);
// get the ADC value from the temperature sensor
int adcVal = analogRead(PIN_LM35);
// convert the ADC value to voltage in millivolt
float milliVolt = adcVal * (ADC_VREF_mV / ADC_RESOLUTION);
// convert the voltage to the temperature in Celsius
float tempC = milliVolt / 10;
// convert the Celsius to Fahrenheit
float tempF = tempC * 9 / 5 + 32;
//High idle for ~4 seconds on every start up. delay is how long to wait before moving to the next instruction. Delay is in milliseconds
digitalWrite(RELAY_PIN, HIGH);
delay(4000);
//Hot start routine to address low idle when restarting hot
//will probably need to move that temp around to get this right
if (tempF >99){
delay(10000); //hotstart 10 second additional high idle
digitalWrite(RELAY_PIN, LOW);
//Warm start routine
if (tempF <90 and tempF >70){
delay(60000);
//Cool start routine
if (tempF <70 and tempF >50){
delay(120000);
//Cold start routine
if (tempF <50) {
delay(240000);
void loop() {}
emerygt350   Aux air regulator prototype   Oct 17 2025, 09:16 AM
Superhawk996   :popcorn: Have considered the same approach. ...   Oct 17 2025, 09:37 AM
Literati914   It'd be great if you guy could figure this stu...   Oct 17 2025, 09:53 AM
FlacaProductions   Very cool!   Oct 17 2025, 11:19 AM
JamesJ   Well, it works on my desk and it works on 12v. ...   Oct 17 2025, 12:37 PM
tomeric914   https://xwebforums.com/forum/index.php?thre...erna...   Oct 17 2025, 01:05 PM
emerygt350   That looks a little like what I am up to but minus...   Oct 17 2025, 02:38 PM
tomeric914   This is probably just a prototype, but I suggest y...   Oct 23 2025, 07:02 PM
emerygt350   This is probably just a prototype, but I suggest ...   Oct 24 2025, 04:40 AM
emerygt350   Progress   Oct 18 2025, 03:22 PM
emerygt350   More progress. Ready for a test run.   Oct 23 2025, 07:28 AM
emerygt350   Here are my routines so far. Anybody think of any...   Oct 23 2025, 07:33 AM
emerygt350   dupe   Oct 23 2025, 07:34 AM
Superhawk996   So it looks like Arduino is just controlling via h...   Oct 23 2025, 09:06 AM
emerygt350   So it looks like Arduino is just controlling via ...   Oct 23 2025, 10:58 AM
Ishley   Do you need a default routine that the code falls ...   Oct 23 2025, 10:51 AM
emerygt350   Do you need a default routine that the code falls...   Oct 23 2025, 10:59 AM
Superhawk996   There is an initial 4 sec open routine regardles...   Oct 23 2025, 11:35 AM
emerygt350   There is an initial 4 sec open routine regardle...   Oct 23 2025, 11:47 AM
rjames   Very cool and imporessive work! When you fir...   Oct 23 2025, 04:46 PM
emerygt350   Very cool and imporessive work! When you fi...   Oct 23 2025, 06:01 PM
VaccaRabite   My old MS2 2056 had an ICV based on temps. It use...   Oct 24 2025, 05:55 AM
emerygt350   My old MS2 2056 had an ICV based on temps. It us...   Oct 24 2025, 09:28 AM
Literati914   While trying to decide if I want to keep d-jet for...   Oct 24 2025, 12:06 PM
emerygt350   While trying to decide if I want to keep d-jet fo...   Nov 6 2025, 03:06 PM
- Lo-Fi Version Time is now: 25th August 2026 - 09:49 AM
