| emerygt350 |
Oct 17 2025, 09:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,708 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
| emerygt350 |
Oct 23 2025, 07:33 AM
Here are my routines so far. Anybody think of any other things I can try to address with the AAR? The temp sensor is ambient temp, about 3 or 4 inches from the block.
#define ADC_VREF_mV 5000.0 // in millivolt #define ADC_RESOLUTION 6000.0 #define PIN_LM35 A0 // constants won't change const int RELAY_PIN = D8; // the Arduino pin, which connects to the IN pin of relay void setup() { Serial.begin(9600); // initialize digital pin as an output. pinMode(RELAY_PIN, OUTPUT); // get the ADC value from the temperature sensor int adcVal = analogRead(PIN_LM35); // convert the ADC value to voltage in millivolt float milliVolt = adcVal * (ADC_VREF_mV / ADC_RESOLUTION); // convert the voltage to the temperature in Celsius float tempC = milliVolt / 10; // convert the Celsius to Fahrenheit float tempF = tempC * 9 / 5 + 32; //High idle for ~4 seconds on every start up. delay is how long to wait before moving to the next instruction. Delay is in milliseconds digitalWrite(RELAY_PIN, HIGH); delay(4000); //Hot start routine to address low idle when restarting hot //will probably need to move that temp around to get this right if (tempF >99){ delay(10000); //hotstart 10 second additional high idle digitalWrite(RELAY_PIN, LOW); } //Warm start routine if (tempF <90 and tempF >70){ digitalWrite(RELAY_PIN, HIGH); delay(60000); digitalWrite(RELAY_PIN, LOW); } //Cool start routine if (tempF <70 and tempF >50){ digitalWrite(RELAY_PIN, HIGH); delay(120000); digitalWrite(RELAY_PIN, LOW); } //Cold start routine if (tempF <50) { digitalWrite(RELAY_PIN, HIGH); delay(240000); digitalWrite(RELAY_PIN, LOW); } } void loop() {} |
| emerygt350 |
Oct 23 2025, 07:34 AM
dupe
emerygt350 Aux air regulator prototype Oct 17 2025, 09:16 AM
Superhawk996 :popcorn:
Have considered the same approach.
... Oct 17 2025, 09:37 AM
Literati914 It'd be great if you guy could figure this stu... Oct 17 2025, 09:53 AM
FlacaProductions Very cool! Oct 17 2025, 11:19 AM
JamesJ
Well, it works on my desk and it works on 12v. ... Oct 17 2025, 12:37 PM
tomeric914 https://xwebforums.com/forum/index.php?thre...erna... Oct 17 2025, 01:05 PM
emerygt350 That looks a little like what I am up to but minus... Oct 17 2025, 02:38 PM
tomeric914 This is probably just a prototype, but I suggest y... Oct 23 2025, 07:02 PM
emerygt350
This is probably just a prototype, but I suggest ... Oct 24 2025, 04:40 AM
emerygt350 Progress
Oct 18 2025, 03:22 PM
emerygt350 More progress. Ready for a test run.
Oct 23 2025, 07:28 AM
Superhawk996 So it looks like Arduino is just controlling via h... Oct 23 2025, 09:06 AM
emerygt350
So it looks like Arduino is just controlling via ... Oct 23 2025, 10:58 AM
Ishley Do you need a default routine that the code falls ... Oct 23 2025, 10:51 AM
emerygt350
Do you need a default routine that the code falls... Oct 23 2025, 10:59 AM
Superhawk996
There is an initial 4 sec open routine regardles... Oct 23 2025, 11:35 AM
emerygt350
There is an initial 4 sec open routine regardle... Oct 23 2025, 11:47 AM
rjames Very cool and imporessive work!
When you fir... Oct 23 2025, 04:46 PM
emerygt350
When you fi... Oct 23 2025, 06:01 PM
VaccaRabite My old MS2 2056 had an ICV based on temps. It use... Oct 24 2025, 05:55 AM
emerygt350
My old MS2 2056 had an ICV based on temps. It us... Oct 24 2025, 09:28 AM
Literati914 While trying to decide if I want to keep d-jet for... Oct 24 2025, 12:06 PM
emerygt350
While trying to decide if I want to keep d-jet fo... Nov 6 2025, 03:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th August 2026 - 08:57 AM |
