| densible1 |
Oct 22 2025, 05:37 PM
Newbie ![]() Group: Members Posts: 47 Joined: 5-April 22 From: Hermosa Beach Member No.: 26,444 Region Association: Southern California |
Just reinstalled my type 4 engine back into car everything wired up as before, upon initial start engine fired right up pretty effortlessly and continued to do so after several starts starter motor kicks in and , a HiTorque IMF, it actuates solenoid and motor spins right up. After bout 1/2 dozen starts the starter only activates the solenoid but no spin. I can hear the solenoid engaging. This is an old starter but haven't had problems before the engine re-install. I removed starter and bench tested with 12 volt leads and jumper cable on solenoid and it engages and spins readily. What's going on?
| densible1 |
Oct 22 2025, 06:38 PM
Battery putting out 14 volts. Will test in car like I did bench test see if it spins up
| Lockwodo |
Oct 23 2025, 07:40 AM
Member ![]() ![]() Group: Members Posts: 237 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California
Battery putting out 14 volts. Will test in car like I did bench test see if it spins up Voltage of fully charged battery measured at the posts (not the clamps) with engine not running should be ~12.7v. A lower voltage means the battery is partially discharged, for example, a reading of ~12.3v means the battery is 50% discharged. Your reading of 14v would make sense with engine running and is what the alternator is putting out, not the battery. More here: https://ratwell.com/technical/ChargingSystem.html |
densible1 Starter Motor no work Oct 22 2025, 05:37 PM
burton73
Just reinstalled my type 4 engine back into car e... Oct 22 2025, 06:09 PM
densible1 That’s right the starter never seemed to get hot... Oct 22 2025, 06:17 PM
Lockwodo Ground problem or defective battery cable? And of... Oct 22 2025, 06:20 PM
emerygt350 I would bet on a ground issue. Run an extra groun... Oct 22 2025, 07:35 PM
fixer34 Chassis ground strap to transmission? Oct 22 2025, 07:45 PM
densible1 Yep Oct 22 2025, 07:50 PM
bdstone914
Yep
Measure the resistance from the transmissi... Oct 22 2025, 08:32 PM
densible1 will test that in the morning. Think the starter ... Oct 22 2025, 08:44 PM
porschetub
will test that in the morning. Think the starter... Oct 22 2025, 10:14 PM
Root_Werks Can you rotate the engine by hand?
And I second o... Oct 23 2025, 12:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2025 - 10:27 PM |
