> Rear Trunk Oddball Features?
DennisV
post Oct 22 2025, 07:49 PM
I ran across three things in our rear trunk that seem unusual. Perhaps they are DAPO mods. Can anyone confirm?
1. What appears to be a ground strap
2. A clip at the bottom of the trunk lid
3. Small rubber grommet from the firewall.
Thank you.
nivekdodge
post Oct 22 2025, 08:24 PM
Could 1. be a ground to eliminate noise on a cb radio? and 3 be the cable passthru
Kevin
fixer34
post Oct 23 2025, 07:55 AM
QUOTE(nivekdodge @ Oct 22 2025, 09:24 PM) *
Kevin
None of those are 'stock', but this could be a likely explanation.
#1 provides a better ground connection/plane for the back trunk lid.
#2 clips the antenna cable when the lid is opened
#3 is the antenna cable passthru from the engine compartment. Cable likely run thru the tunnel into the cockpit.
Antenna probably a clamp on, or even magnetic base that attached to rear lid. Pretty common 30+ years ago,
Unless you are going for full factory stock/concours, I would leave them alone. Shows that PO put some effort into it.
DennisV   Rear Trunk Oddball Features?   Oct 22 2025, 07:49 PM
Montreal914   Doesn’t look stock.   Oct 22 2025, 08:01 PM
fixer34   None of those are on mine.   Oct 22 2025, 08:21 PM
nivekdodge   Could 1. be a ground to eliminate noise on a cb ra...   Oct 22 2025, 08:24 PM
DennisV   Could 1. be a ground to eliminate noise on a cb r...   Oct 23 2025, 05:03 AM
fixer34   Could 1. be a ground to eliminate noise on a cb r...   Oct 23 2025, 07:55 AM
dtmehall   not on my 73   Oct 22 2025, 08:25 PM
rgalla9146   All goofy DAPO mods   Oct 23 2025, 06:06 AM
Root_Werks   All goofy DAPO mods :agree:   Oct 23 2025, 10:44 AM
NARP74   And you need to put the witches hat back on.   Oct 23 2025, 09:57 AM
BillJ   I think he wants full on total original based on e...   Oct 23 2025, 10:07 AM
- Lo-Fi Version Time is now: 24th October 2025 - 02:52 AM
