| emerygt350 |
Oct 17 2025, 09:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,708 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
| Ishley |
Oct 23 2025, 10:51 AM
Member ![]() ![]() Group: Members Posts: 360 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Do you need a default routine that the code falls into after a specific amount to time that closes the valve... in the case where you you don't sense the temp? I'm not familiar with this language so perhaps it's there and I didn't get it.
| emerygt350 |
Oct 23 2025, 10:59 AM
Do you need a default routine that the code falls into after a specific amount to time that closes the valve... in the case where you you don't sense the temp? I'm not familiar with this language so perhaps it's there and I didn't get it. This is just a run once routine that would only execute the moment you start the car. no loop. There is an initial 4 sec open routine regardless of the temp. |
| Superhawk996 |
Oct 23 2025, 11:35 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,005 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
There is an initial 4 sec open routine regardless of the temp. What the thinking there? Example - car is hot to very hot. Shut down for let’s say two minutes. At restart it’s going to tend lean just based on temp. Why bleed in more air for 4 seconds when the AAR wouldn’t? Not being critical - think this is cool that your giving it a whirl and of course if it doesn’t work for whatever reason easy to change code. There are probably 5 good ways to do this with stepper motors or a solenoid that could be PMW controlled but you’ve actually done something and built something so my hats off to you!! (IMG:style_emoticons/default/smilie_pokal.gif) |
| emerygt350 |
Oct 23 2025, 11:47 AM
There is an initial 4 sec open routine regardless of the temp. What the thinking there? Example - car is hot to very hot. Shut down for let’s say two minutes. At restart it’s going to tend lean just based on temp. Why bleed in more air for 4 seconds when the AAR wouldn’t? That would be the sane thought here, but since this is djet... I think the logic behind the tough start is the heads cool faster than the cylinder and therefore the head temp isn't reflective of the actual temp ending up in a rich condition. I don't know if I believe that or not, considering how heat moves in these engines. Whatever the underlying cause, when hot in the condition you describe, my car idles low, so I am going to try bring that idle up for 14 seconds (4 seconds because it is a fresh start, and 10 added because the temp sensor sees a hot engine bay). That is the normal amount of time it takes for my car to recover a normal idle in a hot restart situation. I am not sure this will work, or if those are the right times, but it is a start. The stepper might be where I go next if this doesn't have the resolution needed. I was also looking at a multivalve system. I am afraid that most of the cheap valves of the right size and voltage just don't create a hole big enough for the airflow I need. If I had two valves in parallel, that would give me the ability to roughly alter air available. We will see. I have a PCA event this weekend so I don't think I will try it on the car till Sunday. sadly, if they had just added the 6cyl throttle lever to the 4 and dumped the stupid aar, we wouldn't need any of this. |
emerygt350 Aux air regulator prototype Oct 17 2025, 09:16 AM
Superhawk996 :popcorn:
Have considered the same approach.
... Oct 17 2025, 09:37 AM
Literati914 It'd be great if you guy could figure this stu... Oct 17 2025, 09:53 AM
FlacaProductions Very cool! Oct 17 2025, 11:19 AM
JamesJ
Well, it works on my desk and it works on 12v. ... Oct 17 2025, 12:37 PM
tomeric914 https://xwebforums.com/forum/index.php?thre...erna... Oct 17 2025, 01:05 PM
emerygt350 That looks a little like what I am up to but minus... Oct 17 2025, 02:38 PM
tomeric914 This is probably just a prototype, but I suggest y... Oct 23 2025, 07:02 PM
emerygt350
This is probably just a prototype, but I suggest ... Oct 24 2025, 04:40 AM
emerygt350 Progress
Oct 18 2025, 03:22 PM
emerygt350 More progress. Ready for a test run.
Oct 23 2025, 07:28 AM
emerygt350 Here are my routines so far. Anybody think of any... Oct 23 2025, 07:33 AM
emerygt350 dupe Oct 23 2025, 07:34 AM
Superhawk996 So it looks like Arduino is just controlling via h... Oct 23 2025, 09:06 AM
emerygt350
So it looks like Arduino is just controlling via ... Oct 23 2025, 10:58 AM
rjames Very cool and imporessive work!
When you fir... Oct 23 2025, 04:46 PM
emerygt350
When you fi... Oct 23 2025, 06:01 PM
VaccaRabite My old MS2 2056 had an ICV based on temps. It use... Oct 24 2025, 05:55 AM
emerygt350
My old MS2 2056 had an ICV based on temps. It us... Oct 24 2025, 09:28 AM
Literati914 While trying to decide if I want to keep d-jet for... Oct 24 2025, 12:06 PM
emerygt350
While trying to decide if I want to keep d-jet fo... Nov 6 2025, 03:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th August 2026 - 09:47 AM |
