| scrz914 |
Oct 27 2025, 11:04 AM
Member ![]() ![]() Group: Members Posts: 439 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
I have a recently rebuilt flat six engine that I’m going to install in my 914. I built a run stand so that I could do the initial break in and then address any other issues. Start up went well with the expected popping through the Weber IDAs and some backfires through the exhaust. Once warm it ran better. One of the first checks I did was to make sure all plugs were firing by using a temperature gun directed at the exhaust coming off each cylinder. This is where I discovered a huge disparity between the two banks. One side, 1,2,3 cylinders had readings over 500 degrees whereas 4,5,6 was a little over 100 degrees.
My first check was fuel pressure. 3 psi on both sides which is good. Then I sprayed brake cleaner around the manifolds. Good. When I sprayed points on the throttle shaft on 1,2,3 there was a noticeable change in idle. It became smoother and increased a little. My question: could a vacuum leak at the throttle shaft account for the high exhaust temperature? If so, what are my options? I don’t have much carburetor experience so any expert advice would be appreciated. Thanks all. |
| gereed75 |
Oct 27 2025, 11:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,400 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
That seems like a huge disparity on an engine that is running even reasonably well
Be sure that you are measuring both sides at exactly the same distance from the cylinder head on both sides. EGT drops quickly in relation to distance from the cylinder head. Beyond that, the first thing I would check is carb float levels. High float levels on the cold cylinders will prevent any fuel from entering the carbs once the engine is running. |
| scrz914 |
Oct 27 2025, 11:38 AM
Beyond that, the first thing I would check is carb float levels. High float levels on the cold cylinders will prevent any fuel from entering the carbs once the engine is running. Interesting, I didn’t know that. I’ll check the float levels next. Regarding the temperature readings, i did use a 6 inch distance on all exhaust pipes. |
scrz914 Rebuilt 3.0 engine issue Oct 27 2025, 11:04 AM
scrz914 Here’s a pic of my setup. MSD 6AL ignition.
Oct 27 2025, 01:24 PM
emerygt350 Truthfully it should be titled "low temps on... Oct 27 2025, 02:01 PM
930cabman :popcorn:
yes, it appears to point to the carb, ... Oct 27 2025, 02:34 PM
VaccaRabite Have you gone through the whole carb adjustment pr... Oct 27 2025, 02:35 PM
scrz914 It did seem to me that both sides could be extreme... Oct 27 2025, 03:22 PM
fixer34
It did seem to me that both sides could be extrem... Oct 27 2025, 03:41 PM
scrz914
It did seem to me that both sides could be extre... Oct 27 2025, 03:50 PM
930cabman
[quote name='fixer34' post='3230254' date='Oct 27... Oct 27 2025, 04:30 PM
mb911 Cam timing is always my go too in this situation Oct 27 2025, 03:35 PM
scrz914 Always good to check the basics. I DID have 4 and ... Oct 27 2025, 04:33 PM
Luke M A far reach but did you install all of the cooling... Oct 27 2025, 05:43 PM
scrz914
A far reach but did you install all of the coolin... Oct 27 2025, 06:06 PM
sixnotfour TDC #1 valves loose, #4 valves tight.. is what you... Oct 27 2025, 05:53 PM
Root_Werks
TDC #1 valves loose, #4 valves tight.. is what yo... Oct 27 2025, 05:59 PM
scrz914
TDC #1 valves loose, #4 valves tight.. is what yo... Oct 27 2025, 06:23 PM
brant Agree with jeff and all
Not working one bank
Spar... Oct 27 2025, 06:05 PM
sixnotfour turn engine TDC #1 ...hold right carb, wide open,... Oct 27 2025, 06:33 PM
gereed75 Agree with all -you need correctly timed spark, fu... Oct 27 2025, 08:43 PM
930cabman
Agree with all -you need correctly timed spark, f... Oct 28 2025, 10:33 AM
Retroracer Joining this a little late, some good recommendati... Oct 28 2025, 12:38 PM
scrz914
Joining this a little late, some good recommendat... Oct 28 2025, 02:08 PM
Retroracer And:
"...would a bad MSD unit cause one ban... Oct 28 2025, 12:44 PM
scrz914 I did have some progress today. Needless to say, g... Oct 28 2025, 02:21 PM
porschetub
I did have some progress today. Needless to say, ... Oct 29 2025, 11:33 PM
scrz914
Don't continue running your engine unless you... Oct 30 2025, 11:23 AM
Root_Werks Sounds like you are getting closer to a solution. ... Oct 28 2025, 05:43 PM
scrz914
Sounds like you are getting closer to a solution.... Oct 28 2025, 06:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2025 - 06:50 AM |
