> Rebuilt 3.0 engine issue, Hi temps on one side
scrz914
post Oct 27 2025, 11:04 AM
I have a recently rebuilt flat six engine that I’m going to install in my 914. I built a run stand so that I could do the initial break in and then address any other issues. Start up went well with the expected popping through the Weber IDAs and some backfires through the exhaust. Once warm it ran better. One of the first checks I did was to make sure all plugs were firing by using a temperature gun directed at the exhaust coming off each cylinder. This is where I discovered a huge disparity between the two banks. One side, 1,2,3 cylinders had readings over 500 degrees whereas 4,5,6 was a little over 100 degrees.
My first check was fuel pressure. 3 psi on both sides which is good.
Then I sprayed brake cleaner around the manifolds. Good.
When I sprayed points on the throttle shaft on 1,2,3 there was a noticeable change in idle. It became smoother and increased a little.
My question: could a vacuum leak at the throttle shaft account for the high exhaust temperature? If so, what are my options?
I don’t have much carburetor experience so any expert advice would be appreciated.
Thanks all.
sixnotfour
post Oct 27 2025, 05:53 PM
TDC #1 valves loose, #4 valves tight.. is what you should have..
Cam timing.. right side is prob. loose at the wrong time ..
scrz914   Rebuilt 3.0 engine issue   Oct 27 2025, 11:04 AM
gereed75   That seems like a huge disparity on an engine that...   Oct 27 2025, 11:24 AM
scrz914   Beyond that, the first thing I would check is ca...   Oct 27 2025, 11:38 AM
scrz914   Here’s a pic of my setup. MSD 6AL ignition.   Oct 27 2025, 01:24 PM
emerygt350   Truthfully it should be titled "low temps on...   Oct 27 2025, 02:01 PM
930cabman   :popcorn: yes, it appears to point to the carb, ...   Oct 27 2025, 02:34 PM
VaccaRabite   Have you gone through the whole carb adjustment pr...   Oct 27 2025, 02:35 PM
scrz914   It did seem to me that both sides could be extreme...   Oct 27 2025, 03:22 PM
fixer34   It did seem to me that both sides could be extrem...   Oct 27 2025, 03:41 PM
scrz914   It did seem to me that both sides could be extre...   Oct 27 2025, 03:50 PM
930cabman   [quote name='fixer34' post='3230254' date='Oct 27...   Oct 27 2025, 04:30 PM
mb911   Cam timing is always my go too in this situation   Oct 27 2025, 03:35 PM
scrz914   Always good to check the basics. I DID have 4 and ...   Oct 27 2025, 04:33 PM
Luke M   A far reach but did you install all of the cooling...   Oct 27 2025, 05:43 PM
scrz914   A far reach but did you install all of the coolin...   Oct 27 2025, 06:06 PM
sixnotfour   TDC #1 valves loose, #4 valves tight.. is what you...   Oct 27 2025, 05:53 PM
Root_Werks   TDC #1 valves loose, #4 valves tight.. is what yo...   Oct 27 2025, 05:59 PM
scrz914   TDC #1 valves loose, #4 valves tight.. is what yo...   Oct 27 2025, 06:23 PM
brant   Agree with jeff and all Not working one bank Spar...   Oct 27 2025, 06:05 PM
sixnotfour   turn engine TDC #1 ...hold right carb, wide open,...   Oct 27 2025, 06:33 PM
gereed75   Agree with all -you need correctly timed spark, fu...   Oct 27 2025, 08:43 PM
930cabman   Agree with all -you need correctly timed spark, f...   Oct 28 2025, 10:33 AM
Retroracer   Joining this a little late, some good recommendati...   Oct 28 2025, 12:38 PM
scrz914   Joining this a little late, some good recommendat...   Oct 28 2025, 02:08 PM
Retroracer   And: "...would a bad MSD unit cause one ban...   Oct 28 2025, 12:44 PM
scrz914   I did have some progress today. Needless to say, g...   Oct 28 2025, 02:21 PM
porschetub   I did have some progress today. Needless to say, ...   Oct 29 2025, 11:33 PM
scrz914   Don't continue running your engine unless you...   Oct 30 2025, 11:23 AM
Root_Werks   Sounds like you are getting closer to a solution. ...   Oct 28 2025, 05:43 PM
scrz914   Sounds like you are getting closer to a solution....   Oct 28 2025, 06:14 PM
- Lo-Fi Version Time is now: 1st November 2025 - 06:50 AM
