| Literati914 |
Oct 28 2025, 09:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,121 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I know these conical set screws at the shift linkage are supposed to be one-time use items and should be replaced every time .. but I reused a couple that I had on hand when assembling my restoration. So I added a dab of loctite blue to them and snugged them down. I was going to go back and change them out when most of the kinks had been worked out of the car. So, this whole time I've been worried that they'd loosen and drop out while out running the car.
So now's the time, I set out to do this yesterday and the rear one was stubborn but I was able to remove it.. then on to the front one, and an absolute refusal to move! The stupid internal hex stripped (of course), then I tried 4-5 techniques to remove it but none worked, only made things worse - so I guess it's a matter of drilling and trying an ease out now? I actually tried one already without drilling because the hex is so chewed up. It probably was not the optimal size either though. Don't suppose anyone's done it recently and can remember the drill and ease-out size specifics they used? I hate small internal hex key bolts, they always seem to tend towards stripping - anyone know if a 356 set screw would work? https://www.stoddard.com/pcg711189a.html |
| SirAndy |
Oct 28 2025, 10:05 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,351 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So I added a dab of loctite blue to them and snugged them down. Blue Loctite is the correct one to use! Sounds like drilling is your only option at this point. Is there anything left sticking out that you could weld something onto? (IMG:style_emoticons/default/idea.gif) |
Literati914 Stripped Conical Set Screw Oct 28 2025, 09:25 AM
brant That forward knuckle will likely need to be reweld... Oct 28 2025, 10:08 AM
930cabman
That forward knuckle will likely need to be rewel... Oct 28 2025, 12:22 PM
Rusty The previous owner of my car had an interesting so... Oct 28 2025, 10:19 AM
emerygt350 a little application of heat will loosen that loct... Oct 28 2025, 11:08 AM
Literati914
So I added a dab of loctite [b]blue to them and s... Oct 28 2025, 12:48 PM
SirAndy [quote name='Literati914' post='3230342' date='Oct... Oct 28 2025, 02:33 PM
Literati914
a little application of heat will loosen that loc... Oct 28 2025, 12:51 PM
mb911 Ok folks to clarify 271 red loctite is permanent a... Oct 28 2025, 01:02 PM
dr914@autoatlanta.com how about some heat?
I know these conical set s... Oct 28 2025, 01:14 PM
bzettner Is there a similar sized (a little bigger) TORX th... Oct 28 2025, 01:57 PM
GregAmy I've re-used those screws many times on both m... Oct 28 2025, 02:41 PM
SirAndy There's really nothing unique about new ones v... Oct 28 2025, 03:16 PM
GregAmy That might be true for aftermarket screws but the ... Oct 28 2025, 03:52 PM
ChrisFoley
... the factory screws have a metal tab inside th... Oct 28 2025, 05:28 PM
... the factory screws have a metal tab inside th... Oct 28 2025, 05:34 PM
GregAmy
The newer OEM ones do (have the Teflon)...But the... Oct 29 2025, 06:21 AM
emerygt350 I used a torch on mine, no problem. You don't... Oct 28 2025, 03:41 PM
Literati914 Update - I used a torch with no luck .. I stopped ... Oct 28 2025, 03:56 PM
SirAndy PS - I'd still like to know if the 356 equival... Oct 28 2025, 05:36 PM
914Sixer Stoddard part is TOO short. Tried VW screw and it... Oct 28 2025, 04:05 PM
ChrisFoley A small amount of heat will soften blue loctite ni... Oct 28 2025, 05:31 PM
Literati914
.. Best one is the early 911 one that is NLA.
... Oct 28 2025, 09:25 PM
bdstone914
Try driving in torx hex bit if there is any ma... Oct 29 2025, 07:13 AM
Literati914
Try driving in torx hex bit if there is any mate... Oct 29 2025, 07:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th October 2025 - 12:34 PM |
