| Chad911sc |
Oct 28 2025, 09:46 AM
Member ![]() ![]() Group: Members Posts: 204 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
So when I built my engine, I took the crank to a local central Florida machine shop. I asked for it to be checked in every way and turn it down .010 if needed. They called me back up a week later for pickup, and said it was all good and my mains were well within spec for standard bearings. All they did was micro polish it. Before putting it in the case, I checked with a set of micrometers that I had purchased and it was in spec. The car had 85lbs of oil pressure on start up, but would fall to 5lbs after up to 220. I tried everything from different oil pump to the tangerine oil pressure valve, but nothing helped, so I tore it all back apart and started over. The bearings on the ends of the crank looked perfect, but the middle bearing was wiping on both thrust sides. So I bought a bore gauge and checked my case after torquing it back together, and it checked out perfectly. I thought I was going to need a line bore of the case due to stretching, but that wasn’t the issue. So I took my crank to another shop to get it checked out and he put it on the machine right in front of me, and wouldn’t you know the crank was out of round on the middle bearing by .008 ! So I see now why the middle bearing had such extreme wear and my oil pressure was disappearing. They are going to turn it down .010 on the mains and straighten it for me.
I am also putting an o-ringed oil pump back in as well to solve the improper fit issue with the type 1 pump. When I checked the bore of the case and the oil pump that came out of it, they were the exact same size. So the press fit was lacking a bit. Hopefully will be putting back together in a couple weeks once the parts are back in and the machine work is done. |
| Superhawk996 |
Oct 28 2025, 11:25 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,493 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Good find
(IMG:style_emoticons/default/smilie_pokal.gif) for doing the deep dive to get to root cause |
| 930cabman |
Oct 28 2025, 12:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,311 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Good find (IMG:style_emoticons/default/smilie_pokal.gif) for doing the deep dive to get to root cause the best way to go, otherwise you are picking up the (probably broken) pieces and mucho $$ " crank was out of round .008" with the precision required here thats a mile |
| stownsen914 |
Oct 28 2025, 12:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 968 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Yikes what a story. Good you figured it out, you should be on the right path now.
To get .008" out of round, the machine shop must have done some righteous polishing job ... |
| porschetub |
Oct 28 2025, 02:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yikes what a story. Good you figured it out, you should be on the right path now. To get .008" out of round, the machine shop must have done some righteous polishing job ... (IMG:style_emoticons/default/agree.gif) you would think the machinist would have checked for runout BEFORE anything more was done ?? pretty much standard proceedure ...strange . |
Chad911sc Found oil pressure problem Oct 28 2025, 09:46 AM
Chad911sc Main bearings Oct 28 2025, 09:48 AM
friethmiller That sucks but it makes sense. At least you know a... Oct 28 2025, 09:55 AM
930cabman Do you recall when assembling the case of the smoo... Oct 28 2025, 10:32 AM
Chad911sc No not really…everything felt smooth and normal... Oct 28 2025, 11:23 AM
Chad911sc Exactly!
Or dropped it off of the counter and ... Oct 28 2025, 01:48 PM
trojanhorsepower Glad you figured it out.
Sorry you had to deal wi... Oct 28 2025, 06:24 PM
Chad911sc The “machine shops” around central Florida hav... Oct 28 2025, 07:01 PM
bkrantz
The “machine shops” around central Florida ha... Oct 28 2025, 09:29 PM
930cabman
The “machine shops” around central Florida h... Oct 29 2025, 04:59 AM
Chad911sc You are exactly right..
I’ve worked with Drs in ... Oct 29 2025, 05:55 AM
burton73
I’ve worked with Drs in... Oct 29 2025, 02:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th October 2025 - 09:47 PM |
