| jeff dodge |
Oct 10 2025, 04:37 PM
Newbie ![]() Group: Members Posts: 29 Joined: 5-September 24 From: middleton,WI Member No.: 28,332 Region Association: None |
I am having trouble with my left turn signal. Let me detail; ground tested and is good, replaced , replaced column switch, new relays, new bulbs, swapped housings from left to right, new fuses. noticed that when I clicked the emergency flashers it blew that fuse. Right works fine, the left turn filament is very dim and the read does not do anything. I have spent two weeks trying to track this down. I have built entire harnesses for vintage race cars and this has me baffled. Please help! Thanks, Jeff
| black73 |
Oct 31 2025, 03:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 519 Joined: 23-March 05 From: Nashville,TN Member No.: 3,801 Region Association: South East States |
Are the rear license plate lights in that circuit? Might check there for short or crossed wires.
jeff dodge left turn signal problems Oct 10 2025, 04:37 PM
jim_hoyland There’s a possibility the TS switch has a short ... Oct 10 2025, 06:33 PM
Dave_Darling A dim light says to me that you've got either ... Oct 11 2025, 01:49 AM
jeff dodge
A dim light says to me that you've got either... Oct 12 2025, 10:28 AM
Spoke
I am having trouble with my left turn signal. Let... Oct 12 2025, 06:21 PM
scallyk9
I am having trouble with my left turn signal. Le... Oct 16 2025, 03:10 PM
jeff dodge
[quote name='Spoke' post='3227996' date='Oct 12 2... Oct 17 2025, 11:46 AM
jeff dodge
[quote name='Spoke' post='3227996' date='Oct 12 ... Oct 20 2025, 03:02 PM
jeff dodge
[quote name='jeff dodge' post='3228695' date='Oct... Oct 21 2025, 04:13 PM
Spoke
All of the housings checked out. every light work... Oct 22 2025, 06:01 AM
jeff dodge
All of the housings checked out. every light wor... Oct 22 2025, 02:22 PM
jeff dodge
All of the housings checked out. every light wor... Oct 23 2025, 04:39 PM
jeff dodge
[quote name='Spoke' post='3229355' date='Oct 22 2... Oct 23 2025, 04:50 PM
NARP74 I had some stuff in my rear trunk hit the tail lig... Oct 16 2025, 04:34 PM
Spoke
OK, let me make sure I understand what's hap... Oct 23 2025, 07:53 PM
jeff dodge
OK, let me make sure I understand what's ha... Oct 25 2025, 08:23 PM
jeff dodge I appreciate all of the help that I am get from fo... Oct 24 2025, 08:17 PM
Ishley You might want to check all the bulbs and fixture.... Oct 25 2025, 09:01 PM
jeff dodge
You might want to check all the bulbs and fixture... Oct 30 2025, 10:22 AM
jeff dodge
You might want to check all the bulbs and fixtur... Oct 30 2025, 11:27 AM
Superhawk996 You’re going to have to work with a wiring diagr... Oct 30 2025, 11:44 AM
jeff dodge
Are the rear license plate lights in that circuit... Oct 31 2025, 09:42 AM
Spoke It might be useful to check the resistance in the ... Oct 31 2025, 10:02 AM
NARP74 @jeff dodge Did this ever get resolved? I am hav... Jul 20 2026, 11:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st July 2026 - 05:28 AM |
