> left turn signal problems, feel like i have tried everything
jeff dodge
post Oct 10 2025, 04:37 PM
I am having trouble with my left turn signal. Let me detail; ground tested and is good, replaced , replaced column switch, new relays, new bulbs, swapped housings from left to right, new fuses. noticed that when I clicked the emergency flashers it blew that fuse. Right works fine, the left turn filament is very dim and the read does not do anything. I have spent two weeks trying to track this down. I have built entire harnesses for vintage race cars and this has me baffled. Please help! Thanks, Jeff
Spoke
post Oct 31 2025, 10:02 AM
Jerry
It might be useful to check the resistance in the left side turnsignal wiring with nothing powered.
To do this, pull the flasher relay and connect your ohm meter between pins 49a and 31 (ground). You may want to disconnect the NEG wire from the battery before dropping the fuse panel.
Connect the ohm meter so you don't have to hold the leads. You may have to jam a wire or a thin piece of metal into the socket for pins 49a and 31. It will be too difficult to hold the probes by hand when doing this testing.
With the turnsignal stalk not selecting R or L you should read infinite resistance.
When you select the L turnsignals you will read a very low resistance which normally would be the resistance of the bulbs.
Pull both front and rear bulbs on the left side and check the resistance. You should measure infinite resistance. If you don't there is a wiring issue somewhere. I would start by removing the wires to the light housings front and rear.
If you're still seeing low resistance that means you have a short somewhere. You can pull the L wires off of the hazard switch to eliminate that.
jeff dodge   left turn signal problems   Oct 10 2025, 04:37 PM
jim_hoyland   There’s a possibility the TS switch has a short ...   Oct 10 2025, 06:33 PM
Dave_Darling   A dim light says to me that you've got either ...   Oct 11 2025, 01:49 AM
jeff dodge   A dim light says to me that you've got either...   Oct 12 2025, 10:28 AM
Spoke   I am having trouble with my left turn signal. Let...   Oct 12 2025, 06:21 PM
scallyk9   I am having trouble with my left turn signal. Le...   Oct 16 2025, 03:10 PM
jeff dodge   [quote name='Spoke' post='3227996' date='Oct 12 2...   Oct 17 2025, 11:46 AM
jeff dodge   [quote name='Spoke' post='3227996' date='Oct 12 ...   Oct 20 2025, 03:02 PM
jeff dodge   [quote name='jeff dodge' post='3228695' date='Oct...   Oct 21 2025, 04:13 PM
Spoke   All of the housings checked out. every light work...   Oct 22 2025, 06:01 AM
jeff dodge   All of the housings checked out. every light wor...   Oct 22 2025, 02:22 PM
jeff dodge   All of the housings checked out. every light wor...   Oct 23 2025, 04:39 PM
jeff dodge   [quote name='Spoke' post='3229355' date='Oct 22 2...   Oct 23 2025, 04:50 PM
NARP74   I had some stuff in my rear trunk hit the tail lig...   Oct 16 2025, 04:34 PM
Spoke   OK, let me make sure I understand what's hap...   Oct 23 2025, 07:53 PM
jeff dodge   OK, let me make sure I understand what's ha...   Oct 25 2025, 08:23 PM
jeff dodge   I appreciate all of the help that I am get from fo...   Oct 24 2025, 08:17 PM
Ishley   You might want to check all the bulbs and fixture....   Oct 25 2025, 09:01 PM
jeff dodge   You might want to check all the bulbs and fixture...   Oct 30 2025, 10:22 AM
jeff dodge   You might want to check all the bulbs and fixtur...   Oct 30 2025, 11:27 AM
Superhawk996   You’re going to have to work with a wiring diagr...   Oct 30 2025, 11:44 AM
black73   Are the rear license plate lights in that circuit?...   Oct 31 2025, 03:40 AM
jeff dodge   Are the rear license plate lights in that circuit...   Oct 31 2025, 09:42 AM
Spoke   It might be useful to check the resistance in the ...   Oct 31 2025, 10:02 AM
NARP74   @jeff dodge Did this ever get resolved? I am hav...   Jul 20 2026, 11:55 AM
- Lo-Fi Version Time is now: 21st July 2026 - 05:28 AM
