| 75ninefourteen |
Oct 31 2025, 02:02 PM
Newbie ![]() Group: Members Posts: 22 Joined: 3-October 25 From: Austin, TX Member No.: 29,016 Region Association: Southwest Region |
I've been researching the 914 suspension (factory setup) due to the fact I noticed my car was lower on the driver side. I want to make adjustments prior to getting new tires an know this should be set before getting an alignment. Plus I would like to try and understand the modifications made by POs.
Details: * '75 914 with 1.8 * Springs/Shocks replaced on 6/23/00 at 45,881 miles (~68k miles now) * Springs changed to 100# * Bilstein Shocks (F4-B46-0179-H0 == 24-001793) * Shock is set to the top most groove (6 grooves total) As of right now, I've adjusted to get fender heights match side to side when comparing the front or the rears. I should also mention the rear fenders are about 1.5" from the top of the wheel rim. Taking a measurement from the "donuts" on the underside the front sits 1 inch higher than the rear. (Front == 6.75" and Rear == 5.75"). I still have some adjustment left in the front to lower, but not sure how low the car should be lowered. My understanding is the rear should be slightly higher. Center of the wheels measure right at 12" and the torsion cap is 7.5" (center to ground). Based on the manual I should technically need to raise the front to get back to within factory specs, but I know the car isn't running factory springs. From what I've gathered, this current setup might have been more for autoxing rather than street driving. All that said I am trying to get some clear answers about factory setup: * What is stock height and where should I get a measurement from? * To raise the rear suspension height, is to adjust the shocks and spring location? I have spare shims for the trailing arm, but if I am following correctly this is only for alignment purposes. * What's a good way to see if rear shocks/springs are wore out? Pushing on the front bumper. I feel like the fronts should be replaced. So my guess is the back is probably due to be replaced after 25 years. Thanks for the help in advance. |
| 75ninefourteen |
Oct 31 2025, 02:08 PM
75ninefourteen Suspension setup help Oct 31 2025, 02:02 PM
rjames IIRC, the stock height is taller than most like.
... Oct 31 2025, 03:53 PM
bkrantz You might know this, but the factory spec for fron... Oct 31 2025, 07:49 PM
Montreal914 Weren't the north american cars set higher in ... Oct 31 2025, 08:36 PM
IronHillRestorations The factory ride height is the difference between ... Nov 1 2025, 07:54 AM
75ninefourteen Thanks for the feedback. I know that the front sho... Nov 1 2025, 08:41 AM
75ninefourteen I was able to adjust the ride height in the front ... Nov 6 2025, 12:24 PM
Cairo94507 Hello @75ninefourteen - Just a word of caution, ... Nov 6 2025, 01:28 PM
75ninefourteen @Cairo94507 Thanks for that note about the front ... Nov 6 2025, 02:01 PM
75ninefourteen After a few test drives for the shifter and linkag... Nov 9 2025, 01:48 PM
75ninefourteen I've swapped out the rear shocks for new Bilst... Jan 19 2026, 01:51 PM
bkrantz Changing the pre-load does not change the spring r... Jan 19 2026, 08:48 PM
DennisV
I want to make adjustments prior to getting new t... Jan 20 2026, 08:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 07:33 AM |
