> 914 Master Cylinder - question?
TRP
post Oct 31 2025, 04:29 PM
Hey Gang!
So, if you've been following my build notes/thread on the forum here, you may know that I was waffling back and forth on changing my master cylinder. The brake pedal never felt right from the day I picked it up on August 7th of this year. The pedal felt weak and I'd need to pump the brakes a few times to get a firm-ish pedal. Even with that, it never felt confidence inspiring
I tried bleeding the system 2 times with my motive power bleeder, and it got a little better but still not good enough. I had a few serious pucker moments in traffic where I though I was going to eat the car in front of me. (IMG:style_emoticons/default/barf.gif)
I was on the fence between trying to bleed them again or just swapping out the entire MC. Well, today I bit the bullet and did the swap. Everything went very easily because I had the tank out and everything already taken apart for the fuel line swap, sway bar install, and steering rack bellow replacement. In for a penny, in for a pound... right?
One thing I noticed when I pulled the existing MC out of the car, they previous owner didn't install the little silver washers into the inlet bores of the MC. He just had the rubber grommets/metal lines jammed in there. Could this have been part of the issue I was having with a weak pedal?
I installed the new 19mm MC with the silver washers in there and I am working on getting the system all blead nicely. So far everything is going well, I have already blead out about half of a big bottle of DOT4. I'm letting everything settle a bit and I'll go for one or two more rounds before I have my wife help with the final foot pump/open the bleeders dance.
Just wondering what you guys think about the necessity of those silver washers.
Thanks
Ted
post Oct 31 2025, 05:48 PM
914-6 GT in waiting
Maybe. I usually have my guys bleed the brakes, I go out and bed the pads and then they bleed them again. My feeling is the hard stops (down to 5mph, not completely stopped) works the air out of the nooks and crannies. It also heats up the whole system, expanding the air and giving you more air volume to bleed out.
Once the system is right, you will know it. Firm pedal, positive brake feel, will lock up the wheels if you really get on it.
Also, you must adjust the rear pad clearance on a 914. Ignore it and the brakes will never feel right.
- Lo-Fi Version Time is now: 3rd November 2025 - 12:29 AM
