| GulfRacer |
Sep 20 2025, 01:48 PM
Newbie ![]() Group: Members Posts: 8 Joined: 19-April 25 From: NJ Member No.: 28,724 Region Association: North East States |
I'm hoping some collective wisdom can help me through a frustrating problem. I have 1974 Bumblebee that I've owned for about 6 months. The 2.0 was rebuilt to a 2056 shortly before I purchased it. It has a Raby 9590 camshaft, original D-Jet and 123 distributor. When I first got the car, it was running great. It has since developed an intermittent stutter/bucking. It occurs most commonly around 3000 RPM when cruising, but once it happens, it continues when applying throttle. It doesn't usually occur until the engine has warmed up - the first several minutes of the drive are usually good.
I replaced the throttle sensor board which did not solve the problem. I disconnected the throttle sensor, and the problem is still present. I replaced the fuel injection harnesss which did not help. The fuel injectors are all new with the engine rebuild, but cylinder 3 injector stopped firing a few months ago, and I replaced it with a new one. I'm at a loss as to where to go next. Any advice would be greatly appreciated. Jason |
| emerygt350 |
Nov 2 2025, 06:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,364 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I would try replacing the coil and verify it is wired correctly. I had an original Bosch that read perfect on the ohm meter but in the car it resulted in some real badness, much like you describe.
GulfRacer Engine Stuttering Sep 20 2025, 01:48 PM
Dave_Darling Wiggle all of the wiring in the engine bay while t... Sep 20 2025, 03:07 PM
emerygt350 Interesting. That is a spot where a lean miss is ... Sep 20 2025, 04:06 PM
Olympic 914 I was having a similar problem
On mine it was an ... Sep 20 2025, 05:21 PM
Lockwodo Would a faulty MPS cause the lean condition and mi... Sep 20 2025, 06:55 PM
emerygt350
Would a faulty MPS cause the lean condition and m... Sep 21 2025, 07:47 AM
emerygt350
Would a faulty MPS cause the lean condition and ... Sep 21 2025, 07:48 AM
GulfRacer
[quote name='emerygt350' post='3225097' date='Sep... Sep 21 2025, 11:37 AM
cgnj I'm thinking ignition coil. Sits on the tin ab... Sep 23 2025, 12:15 AM
Lockwodo Or perhaps a dodgy ground connection? Sep 23 2025, 09:59 AM
JP101 Thanks for additional suggestions. Coil may make s... Sep 23 2025, 08:22 PM
GulfRacer I still haven't sorted this problem out, and s... Nov 1 2025, 12:08 PM
Ishley Do you have a Bluetooth 123+? If you do you can c... Nov 1 2025, 03:18 PM
GulfRacer I have some additional information. Thank you for... Nov 2 2025, 10:58 AM
Lockwodo It does seem like the trigger point pulse from the... Nov 2 2025, 11:20 AM
GulfRacer
It does seem like the trigger point pulse from th... Nov 2 2025, 11:23 AM
emerygt350 I wonder if this could be one of those rare times ... Nov 2 2025, 11:32 AM
GulfRacer
I wonder if this could be one of those rare times... Nov 2 2025, 11:37 AM
emerygt350
I wonder if this could be one of those rare time... Nov 2 2025, 07:42 PM
Ishley I’m wondering if you should check the spray patt... Nov 2 2025, 02:45 PM
GulfRacer
I’m wondering if you should check the spray pat... Nov 2 2025, 04:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2025 - 08:19 AM |
