| Gplracer |
Oct 31 2025, 10:20 AM
Newbie ![]() Group: Members Posts: 19 Joined: 8-September 19 From: Evans GA Member No.: 23,442 Region Association: South East States |
I am restoring the 1973 914 my dad had when I was growing up. It has a 1.7L motor. I know I will need 2.0 liter heads. What do you recommend. There is a great price variance. I assume I will also need 2.0 headers among other things.
| davep |
Nov 1 2025, 10:00 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,332 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If you were to use 2.0 heads, then you would also need the 2.0 tin over the engine since the spark plugs are located differently; 2.0 tin is hard to find now. It also may be easier to find intake manifolds for the 4 stud 1.7/1.8 heads; 2.0 heads have significantly different manifold mounting. The 914 2.0 heads are uniquely Porsche; bus parts are not the same.
| Gplracer |
Nov 2 2025, 12:01 PM
Thanks for the info. I know about the tins. The spark plug holes are in a different place. I saw a guy online who sells a template to redrill 1.7 tins to match up.
If you were to use 2.0 heads, then you would also need the 2.0 tin over the engine since the spark plugs are located differently; 2.0 tin is hard to find now. It also may be easier to find intake manifolds for the 4 stud 1.7/1.8 heads; 2.0 heads have significantly different manifold mounting. The 914 2.0 heads are uniquely Porsche; bus parts are not the same. |
Gplracer 1.7 to 2056 - What heads should I consider/buy Oct 31 2025, 10:20 AM
Ishley Are you sticking with fuel injection?
I built a... Oct 31 2025, 11:20 AM
Gplracer I am probably going to go with dual carburetors. I... Oct 31 2025, 03:53 PM
rfinegan 1.8 heads will drop right on and have bigger valv... Oct 31 2025, 12:05 PM
cgnj Hit the easy button. http://www.914world.com/bbs2/... Oct 31 2025, 04:08 PM
Ishley I run DJet so I was constrained by that. I basical... Oct 31 2025, 04:14 PM
JamesJ "I am probably going to go with dual carburet... Oct 31 2025, 04:31 PM
Gplracer Stock fuel injection is long gone.
"I am p... Oct 31 2025, 09:15 PM
JamesJ Purchased these heads for my recent 2056 build and... Nov 1 2025, 03:47 PM
930cabman Or even easisr: https://pmbperformance.com/product... Nov 2 2025, 12:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2025 - 12:29 AM |
