> Explain the 300 dollar shock to me, Thread on BOGE replacements and later on 5 lug 911 strut options
emerygt350
post Jun 6 2025, 08:08 PM
An insert for 275? What and why? Is it just rarity? Some strange one off design that no other car uses?
chmillman
post Nov 1 2025, 02:59 PM
Region Association: Europe
Well, the car has had a 5 bolt conversion. So those might be 911 A arms, don’t know how to tell the difference.
post Nov 1 2025, 05:05 PM
914-6 GT in waiting
QUOTE(chmillman @ Nov 1 2025, 04:59 PM) *
How was the conversion done. With redrilled rotors or a switch to 911 struts? Does it have 914 brake calipers or 911.
chmillman
post Nov 2 2025, 12:53 AM
QUOTE(mepstein @ Nov 2 2025, 12:05 AM) *
No it’s full 911 brakes with vented rotors on the front, so I guess the struts are also 911. So maybe the stiffness of the ride is coming not just from the shocks, but also the spring rate… When I get the car back up on the lift, I will try to see what diameter they are. Does that mean I need to be looking for 911 inserts for those? Is there a difference?
Again, for the rear springs no idea what they are, they look newish, black paint perfect, no rust, but no markings I could find either.
@wonkipop - I tacked my request to the end of this thread instead of starting a new one because it mentioned the Boge replacements made by AA. So the title is a bit OT relative to my issue, personally money spent is not an issue, getting a better ride is.
wonkipop
post Nov 2 2025, 11:40 AM
QUOTE(chmillman @ Nov 2 2025, 12:53 AM) *
was addressing OP (emery350gt) not you chmillman (IMG:style_emoticons/default/biggrin.gif) sorry for confusion.
for emerygt350's interest i found my receipts for the billsteins back at end of 2019.
B6 bills.
front pair $847 AUD
rear pair $770 AUD
googling the AUD back then - 1.00AUD = 0.72 USD
cost for pair of fronts $609.00 USD. or 300 each.
same price as now by the looks of it. zero inflation?
@chmillman - back in 2019 you could not get boges or boge replicas from mr atlanta.
choice was between billsteines and konis. don't think even cheapos were an option for me in north antarctica. not even available.
truthfully i would not have minded boges again (if they existed) as the car has factory sway bars. allow for the softer shocks in a kind of comfort/performance compromise.
most of the time the B6 are not too bad comfort wise.
but definitely a bit stiffer.
re your springs. not sure 100 lb springs are original spec.
others here know more.
i have a vague recollection the originals were in the 50-60 ib range.
there is some figure in the factory manual which is in kp.
seem to remember something about three different strengths.
but can't remember how that worked. someone here would know.
i reused my original springs. seems to be working ok with the B6s i put in 5 years back.
chmillman
post Nov 2 2025, 02:24 PM
QUOTE(wonkipop @ Nov 2 2025, 06:40 PM) *
Yes, the manual has 3 different values from 220-240 Kp - those are minor differences, possibly to keep springs matched due to manufacturing differences at the time.
60 pounds/inch is about right... Here is the calculation I infer from the manual info
Spring free length=471mm
The 220-240 Kp value is measured at L1=239 - from that I infer that the spring is compressed to that length to measure. That means a compression of 471-239 = 232mm or 9.13"
240Kp*2.2=528 lbs force at a compression of 9.13"
528/9.13 = 57.8 pounds per inch.
Hope i got that calculation correct.
emerygt350   Explain the 300 dollar shock to me   Jun 6 2025, 08:08 PM
bkrantz   An insert for 275? What and why? Is it just rar...   Jun 6 2025, 10:19 PM
emerygt350   [quote name='emerygt350' post='3209243' date='Jun...   Jun 7 2025, 04:45 AM
dr914@autoatlanta.com   we had the original boges duplicated by a suspensi...   Jun 7 2025, 09:17 AM
Superhawk996   we had the original boges duplicated by a suspens...   Jun 7 2025, 09:42 AM
jd74914   we had the original boges duplicated by a suspen...   Nov 4 2025, 11:15 AM
Shivers   I think I’ll see if they can rebuild mine. Price...   Jun 7 2025, 05:04 AM
DennisV   I think I’ll see if they can rebuild mine. Pric...   Jun 7 2025, 11:21 AM
Shivers   I think I’ll see if they can rebuild mine. Pri...   Jun 7 2025, 12:01 PM
914Sixer   Rebuilt shocks seem to be a thing of the past. I a...   Jun 7 2025, 05:35 AM
Shivers   Rebuilt shocks seem to be a thing of the past. I ...   Jun 7 2025, 07:32 AM
emerygt350   I think I might go with the reproduction from auto...   Jun 7 2025, 07:06 AM
Superhawk996   Yup a terrible shame there aren’t Monro-matic or...   Jun 7 2025, 07:51 AM
rick 918-S   Same deal with 914-4 CV's. It totally baffles ...   Jun 7 2025, 09:11 AM
Superhawk996   Same deal with 914-4 CV's. It totally baffles...   Jun 7 2025, 09:40 AM
rick 918-S   Same deal with 914-4 CV's. It totally baffle...   Jun 7 2025, 09:50 AM
Superhawk996   [quote name='Superhawk996' post='3209322' date='J...   Jun 7 2025, 09:55 AM
emerygt350   Yeah, not necessary. Too bad the cheap option app...   Jun 7 2025, 09:13 AM
rjames   Buyer beware- I saw a post on Facebook where someo...   Jun 7 2025, 09:17 AM
cgnj   @dr914 @autoatlanta.com I saw the post on the FB P...   Jun 8 2025, 10:47 AM
emerygt350   Well. Always a surprise. Still leaking though... ...   Jun 12 2025, 11:29 AM
emerygt350   Just took her through some twisty mountain roads, ...   Jun 12 2025, 01:02 PM
mepstein   At least on Bilsteins’ there is supposed to be a...   Jun 12 2025, 01:20 PM
emerygt350   Ahh, well, I guess this is more like 5mm. It was ...   Jun 12 2025, 02:51 PM
chmillman   I'm tired of my bone-shaking Bilsteins... Rea...   Nov 1 2025, 12:06 PM
mepstein   I'm tired of my bone-shaking Bilsteins... Re...   Nov 1 2025, 12:34 PM
chmillman   Well, the car has had a 5 bolt conversion. So tho...   Nov 1 2025, 02:59 PM
mepstein   Well, the car has had a 5 bolt conversion. So th...   Nov 1 2025, 05:05 PM
chmillman   How was the conversion done. With redrilled rotor...   Nov 2 2025, 12:53 AM
wonkipop   How was the conversion done. With redrilled roto...   Nov 2 2025, 11:40 AM
chmillman   i have a vague recollection the originals were i...   Nov 2 2025, 02:24 PM
wonkipop   i have a vague recollection the originals were ...   Nov 2 2025, 05:08 PM
wonkipop   explanation? you get what you pay for. (most tim...   Nov 2 2025, 12:50 AM
mepstein   If the struts have been switched out, you need to ...   Nov 2 2025, 06:14 AM
chmillman   If the struts have been switched out, you need to...   Nov 2 2025, 10:25 AM
chmillman   If the struts have been switched out, you need to...   Nov 3 2025, 05:46 AM
wonkipop   [quote name='mepstein' post='3231015' date='Nov 2...   Nov 3 2025, 06:04 AM
mepstein   It looks like the strut uses an early pinch bolt (...   Nov 2 2025, 11:20 AM
chmillman   I could be wrong but the 914-4 rear sway bars we...   Nov 3 2025, 06:16 AM
wonkipop   I could be wrong but the 914-4 rear sway bars w...   Nov 3 2025, 06:32 AM
Superhawk996   Someone suggested I just replace the front bar, t...   Nov 3 2025, 08:39 AM
chmillman   While adding front bar stiffness will help contr...   Nov 3 2025, 11:04 AM
emerygt350   If it makes any difference, I have been enjoying a...   Nov 2 2025, 07:39 PM
carr914   @Paragon Jason can answer all your question. He ...   Nov 2 2025, 08:04 PM
mepstein   Are the arms on the strut that secure the ball joi...   Nov 3 2025, 06:04 AM
wonkipop   @chmillman part numbers for front struts. yo...   Nov 3 2025, 11:14 AM
chmillman   your struts have correct numbers for a 74 Well...   Nov 3 2025, 11:55 AM
wonkipop   @chmillman interesting. i see what you are say...   Nov 3 2025, 03:22 PM
sixnotfour   More :beer2:   Nov 3 2025, 04:59 PM
wonkipop   More :beer2: wow. excellent document. acco...   Nov 3 2025, 05:25 PM
chmillman   More :beer2: @sixnotfour - Wow, great info, th...   Nov 4 2025, 02:53 AM
wonkipop   had another good look at mine. definitely a 4. st...   Nov 3 2025, 05:07 PM
wonkipop   i'm seeing something else interesting there to...   Nov 3 2025, 05:35 PM
sixnotfour   BOGE manufacturer number ? Looks like it in thi...   Nov 3 2025, 05:36 PM
wonkipop   BOGE manufacturer number ? Looks like it in th...   Nov 3 2025, 06:07 PM
wonkipop   @chmillman AASE bros ad you posted is up the cre...   Nov 3 2025, 06:04 PM
sixnotfour   OG BOGE ,,not exactly an insert..The strut housin...   Nov 3 2025, 07:11 PM
wonkipop   @chmillman the parts page that [b]@[url=http://...   Nov 4 2025, 02:53 PM
mepstein   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 4 2025, 04:58 PM
chmillman   Back in here because the “Boge” front inserts ...   Nov 7 2025, 03:02 AM
mepstein   Back in here because the “Boge” front inserts...   Nov 7 2025, 06:32 AM
Superhawk996   … supposedly OEM spec. Welcome to the afterm...   Nov 7 2025, 07:01 AM
mepstein   Back in here because the “Boge” front inserts...   Nov 7 2025, 07:30 AM
chmillman   KYB's are generally considered to be terrible...   Nov 7 2025, 07:53 AM
mepstein   In my experience, Koni’s can be adjusted much so...   Nov 7 2025, 08:18 AM
wonkipop   In my experience, Koni’s can be adjusted much s...   Nov 7 2025, 02:54 PM
Superhawk996   Seems you’re hooked into Boge as a brand. Cons...   Nov 7 2025, 08:18 AM
chmillman   Seems you’re hooked into Boge as a brand. Con...   Nov 7 2025, 09:31 AM
Superhawk996   Seems you’re hooked into Boge as a brand. Co...   Nov 7 2025, 10:51 AM
chmillman   Let’s go back to basics: You say the ride is...   Nov 7 2025, 11:50 AM
Superhawk996   Stiff(er) - compared to what it was like before...   Nov 7 2025, 12:54 PM
rjames   I went from kybs to koni adjustable shocks and str...   Nov 7 2025, 09:41 AM
DRPHIL914   ive been reading thru the comments on your thread ...   Nov 7 2025, 09:47 AM
mepstein   ive been reading thru the comments on your thread...   Nov 7 2025, 10:36 AM
DRPHIL914   ive been reading thru the comments on your threa...   Nov 10 2025, 12:57 PM
wonkipop   ps this thread topic has been fantastic. if nothi...   Nov 7 2025, 03:06 PM
mepstein   The six front end was basically a 911T suspension ...   Nov 7 2025, 03:19 PM
- Lo-Fi Version Time is now: 1st April 2026 - 06:31 PM
