> Engine Stuttering
GulfRacer
post Sep 20 2025, 01:48 PM
I'm hoping some collective wisdom can help me through a frustrating problem. I have 1974 Bumblebee that I've owned for about 6 months. The 2.0 was rebuilt to a 2056 shortly before I purchased it. It has a Raby 9590 camshaft, original D-Jet and 123 distributor. When I first got the car, it was running great. It has since developed an intermittent stutter/bucking. It occurs most commonly around 3000 RPM when cruising, but once it happens, it continues when applying throttle. It doesn't usually occur until the engine has warmed up - the first several minutes of the drive are usually good.
I replaced the throttle sensor board which did not solve the problem. I disconnected the throttle sensor, and the problem is still present. I replaced the fuel injection harnesss which did not help. The fuel injectors are all new with the engine rebuild, but cylinder 3 injector stopped firing a few months ago, and I replaced it with a new one.
I'm at a loss as to where to go next. Any advice would be greatly appreciated.
Jason
Ishley
post Nov 2 2025, 02:45 PM
I’m wondering if you should check the spray pattern on the fuel injectors. It’s a
No cost item. I do 2 at a time on the same side. Disconnect the coil (no sparks during this operation) take out the 10mm nut and pull the injectors out. I use 2 small dishes to place the injectors in… have a helper crank the motor and watch how the injector sprays. It should be a nice fine pattern.
I had one that would dribble somewhat and that was the cause of my intermittent problem. It’s an easy fix and it’s free to check.
Just a thought.
GulfRacer
post Nov 2 2025, 04:24 PM
QUOTE(Ishley @ Nov 2 2025, 03:45 PM) *
Just a thought.
I initially considered the possibility of a failed injector, but I don't believe this would explain the erratic behavior I'm seeing in the noid light.
GulfRacer   Engine Stuttering   Sep 20 2025, 01:48 PM
Dave_Darling   Wiggle all of the wiring in the engine bay while t...   Sep 20 2025, 03:07 PM
emerygt350   Interesting. That is a spot where a lean miss is ...   Sep 20 2025, 04:06 PM
Olympic 914   I was having a similar problem On mine it was an ...   Sep 20 2025, 05:21 PM
Lockwodo   Would a faulty MPS cause the lean condition and mi...   Sep 20 2025, 06:55 PM
emerygt350   Would a faulty MPS cause the lean condition and m...   Sep 21 2025, 07:47 AM
emerygt350   Would a faulty MPS cause the lean condition and ...   Sep 21 2025, 07:48 AM
GulfRacer   [quote name='emerygt350' post='3225097' date='Sep...   Sep 21 2025, 11:37 AM
cgnj   I'm thinking ignition coil. Sits on the tin ab...   Sep 23 2025, 12:15 AM
Lockwodo   Or perhaps a dodgy ground connection?   Sep 23 2025, 09:59 AM
JP101   Thanks for additional suggestions. Coil may make s...   Sep 23 2025, 08:22 PM
GulfRacer   I still haven't sorted this problem out, and s...   Nov 1 2025, 12:08 PM
Ishley   Do you have a Bluetooth 123+? If you do you can c...   Nov 1 2025, 03:18 PM
emerygt350   I would try replacing the coil and verify it is wi...   Nov 2 2025, 06:52 AM
GulfRacer   I have some additional information. Thank you for...   Nov 2 2025, 10:58 AM
Lockwodo   It does seem like the trigger point pulse from the...   Nov 2 2025, 11:20 AM
GulfRacer   It does seem like the trigger point pulse from th...   Nov 2 2025, 11:23 AM
emerygt350   I wonder if this could be one of those rare times ...   Nov 2 2025, 11:32 AM
GulfRacer   I wonder if this could be one of those rare times...   Nov 2 2025, 11:37 AM
emerygt350   I wonder if this could be one of those rare time...   Nov 2 2025, 07:42 PM
Ishley   I’m wondering if you should check the spray patt...   Nov 2 2025, 02:45 PM
GulfRacer   I’m wondering if you should check the spray pat...   Nov 2 2025, 04:24 PM
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: shag
- Lo-Fi Version Time is now: 3rd November 2025 - 08:21 AM
