| emerygt350 |
Jun 6 2025, 08:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,506 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
An insert for 275? What and why? Is it just rarity? Some strange one off design that no other car uses?
| chmillman |
Nov 1 2025, 02:59 PM
Member ![]() ![]() Group: Members Posts: 369 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Well, the car has had a 5 bolt conversion. So those might be 911 A arms, don’t know how to tell the difference.
| mepstein |
Nov 1 2025, 05:05 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,586 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| chmillman |
Nov 2 2025, 12:53 AM
How was the conversion done. With redrilled rotors or a switch to 911 struts? Does it have 914 brake calipers or 911. No it’s full 911 brakes with vented rotors on the front, so I guess the struts are also 911. So maybe the stiffness of the ride is coming not just from the shocks, but also the spring rate… When I get the car back up on the lift, I will try to see what diameter they are. Does that mean I need to be looking for 911 inserts for those? Is there a difference? Again, for the rear springs no idea what they are, they look newish, black paint perfect, no rust, but no markings I could find either. @wonkipop - I tacked my request to the end of this thread instead of starting a new one because it mentioned the Boge replacements made by AA. So the title is a bit OT relative to my issue, personally money spent is not an issue, getting a better ride is. |
| wonkipop |
Nov 2 2025, 11:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
How was the conversion done. With redrilled rotors or a switch to 911 struts? Does it have 914 brake calipers or 911. No it’s full 911 brakes with vented rotors on the front, so I guess the struts are also 911. So maybe the stiffness of the ride is coming not just from the shocks, but also the spring rate… When I get the car back up on the lift, I will try to see what diameter they are. Does that mean I need to be looking for 911 inserts for those? Is there a difference? Again, for the rear springs no idea what they are, they look newish, black paint perfect, no rust, but no markings I could find either. @wonkipop - I tacked my request to the end of this thread instead of starting a new one because it mentioned the Boge replacements made by AA. So the title is a bit OT relative to my issue, personally money spent is not an issue, getting a better ride is. was addressing OP (emery350gt) not you chmillman (IMG:style_emoticons/default/biggrin.gif) sorry for confusion. for emerygt350's interest i found my receipts for the billsteins back at end of 2019. B6 bills. front pair $847 AUD rear pair $770 AUD googling the AUD back then - 1.00AUD = 0.72 USD cost for pair of fronts $609.00 USD. or 300 each. same price as now by the looks of it. zero inflation? @chmillman - back in 2019 you could not get boges or boge replicas from mr atlanta. choice was between billsteines and konis. don't think even cheapos were an option for me in north antarctica. not even available. truthfully i would not have minded boges again (if they existed) as the car has factory sway bars. allow for the softer shocks in a kind of comfort/performance compromise. most of the time the B6 are not too bad comfort wise. but definitely a bit stiffer. re your springs. not sure 100 lb springs are original spec. others here know more. i have a vague recollection the originals were in the 50-60 ib range. there is some figure in the factory manual which is in kp. seem to remember something about three different strengths. but can't remember how that worked. someone here would know. i reused my original springs. seems to be working ok with the B6s i put in 5 years back. |
| chmillman |
Nov 2 2025, 02:24 PM
i have a vague recollection the originals were in the 50-60 ib range. there is some figure in the factory manual which is in kp. seem to remember something about three different strengths. . Yes, the manual has 3 different values from 220-240 Kp - those are minor differences, possibly to keep springs matched due to manufacturing differences at the time. 60 pounds/inch is about right... Here is the calculation I infer from the manual info Spring free length=471mm The 220-240 Kp value is measured at L1=239 - from that I infer that the spring is compressed to that length to measure. That means a compression of 471-239 = 232mm or 9.13" 240Kp*2.2=528 lbs force at a compression of 9.13" 528/9.13 = 57.8 pounds per inch. Hope i got that calculation correct. |
| wonkipop |
Nov 2 2025, 05:08 PM
i have a vague recollection the originals were in the 50-60 ib range. there is some figure in the factory manual which is in kp. seem to remember something about three different strengths. . Yes, the manual has 3 different values from 220-240 Kp - those are minor differences, possibly to keep springs matched due to manufacturing differences at the time. 60 pounds/inch is about right... Here is the calculation I infer from the manual info Spring free length=471mm The 220-240 Kp value is measured at L1=239 - from that I infer that the spring is compressed to that length to measure. That means a compression of 471-239 = 232mm or 9.13" 240Kp*2.2=528 lbs force at a compression of 9.13" 528/9.13 = 57.8 pounds per inch. Hope i got that calculation correct. thanks for translating my rubbish memory re rear springs into something factual. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) out of interest i just did a calculation on the rear boge shocks screen grab you posted above. 1 swiss francs currently = $1.90 aud. so cost would be $176 aud for each shock. + GST 10% payable when its landed in aus. good as $200 aud. + freight. thats a stab in the dark. but given its heavy-ish. wild guess. $50.00 aud. so i'd be looking at around $250 aud per rear boge shock. not too much different to billstein. maybe $100 cheaper but that depends of freight. though i have not checked bill prices in aus currently. |
emerygt350 Explain the 300 dollar shock to me Jun 6 2025, 08:08 PM
bkrantz
An insert for 275? What and why? Is it just rar... Jun 6 2025, 10:19 PM
emerygt350
[quote name='emerygt350' post='3209243' date='Jun... Jun 7 2025, 04:45 AM
dr914@autoatlanta.com we had the original boges duplicated by a suspensi... Jun 7 2025, 09:17 AM
Superhawk996
we had the original boges duplicated by a suspens... Jun 7 2025, 09:42 AM
jd74914
we had the original boges duplicated by a suspen... Nov 4 2025, 11:15 AM
Shivers I think I’ll see if they can rebuild mine. Price... Jun 7 2025, 05:04 AM
DennisV
I think I’ll see if they can rebuild mine. Pric... Jun 7 2025, 11:21 AM
Shivers
I think I’ll see if they can rebuild mine. Pri... Jun 7 2025, 12:01 PM
914Sixer Rebuilt shocks seem to be a thing of the past. I a... Jun 7 2025, 05:35 AM
Shivers
Rebuilt shocks seem to be a thing of the past. I ... Jun 7 2025, 07:32 AM
emerygt350 I think I might go with the reproduction from auto... Jun 7 2025, 07:06 AM
Superhawk996 Yup a terrible shame there aren’t Monro-matic or... Jun 7 2025, 07:51 AM
rick 918-S Same deal with 914-4 CV's. It totally baffles ... Jun 7 2025, 09:11 AM
Superhawk996
Same deal with 914-4 CV's. It totally baffles... Jun 7 2025, 09:40 AM
rick 918-S
Same deal with 914-4 CV's. It totally baffle... Jun 7 2025, 09:50 AM
Superhawk996
[quote name='Superhawk996' post='3209322' date='J... Jun 7 2025, 09:55 AM
emerygt350 Yeah, not necessary. Too bad the cheap option app... Jun 7 2025, 09:13 AM
rjames Buyer beware- I saw a post on Facebook where someo... Jun 7 2025, 09:17 AM
cgnj @dr914 @autoatlanta.com
I saw the post on the FB P... Jun 8 2025, 10:47 AM
emerygt350 Well. Always a surprise. Still leaking though...
... Jun 12 2025, 11:29 AM
emerygt350 Just took her through some twisty mountain roads, ... Jun 12 2025, 01:02 PM
mepstein At least on Bilsteins’ there is supposed to be a... Jun 12 2025, 01:20 PM
emerygt350 Ahh, well, I guess this is more like 5mm. It was ... Jun 12 2025, 02:51 PM
chmillman I'm tired of my bone-shaking Bilsteins... Rea... Nov 1 2025, 12:06 PM
I'm tired of my bone-shaking Bilsteins... Re... Nov 1 2025, 12:34 PM
wonkipop explanation?
you get what you pay for. (most tim... Nov 2 2025, 12:50 AM
mepstein If the struts have been switched out, you need to ... Nov 2 2025, 06:14 AM
chmillman
If the struts have been switched out, you need to... Nov 2 2025, 10:25 AM
chmillman
If the struts have been switched out, you need to... Nov 3 2025, 05:46 AM
wonkipop
[quote name='mepstein' post='3231015' date='Nov 2... Nov 3 2025, 06:04 AM
mepstein It looks like the strut uses an early pinch bolt (... Nov 2 2025, 11:20 AM
chmillman
I could be wrong but the 914-4 rear sway bars we... Nov 3 2025, 06:16 AM
wonkipop
I could be wrong but the 914-4 rear sway bars w... Nov 3 2025, 06:32 AM
Superhawk996
Someone suggested I just replace the front bar, t... Nov 3 2025, 08:39 AM
chmillman
While adding front bar stiffness will help contr... Nov 3 2025, 11:04 AM
emerygt350 If it makes any difference, I have been enjoying a... Nov 2 2025, 07:39 PM
carr914 @Paragon
Jason can answer all your question. He ... Nov 2 2025, 08:04 PM
mepstein Are the arms on the strut that secure the ball joi... Nov 3 2025, 06:04 AM
wonkipop @chmillman
part numbers for front struts.
yo... Nov 3 2025, 11:14 AM
chmillman
your struts have correct numbers for a 74
Well... Nov 3 2025, 11:55 AM
wonkipop @chmillman
interesting. i see what you are say... Nov 3 2025, 03:22 PM
sixnotfour More :beer2:
Nov 3 2025, 04:59 PM
wonkipop
More :beer2:
wow.
excellent document.
acco... Nov 3 2025, 05:25 PM
chmillman
More :beer2:
@sixnotfour - Wow, great info, th... Nov 4 2025, 02:53 AM
wonkipop had another good look at mine.
definitely a 4. st... Nov 3 2025, 05:07 PM
wonkipop i'm seeing something else interesting there to... Nov 3 2025, 05:35 PM
sixnotfour
BOGE manufacturer number ?
Looks like it in thi... Nov 3 2025, 05:36 PM
wonkipop
Looks like it in th... Nov 3 2025, 06:07 PM
wonkipop @chmillman
AASE bros ad you posted is up the cre... Nov 3 2025, 06:04 PM
sixnotfour OG BOGE ,,not exactly an insert..The strut housin... Nov 3 2025, 07:11 PM
wonkipop @chmillman
the parts page that [b]@[url=http://... Nov 4 2025, 02:53 PM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 4 2025, 04:58 PM
chmillman Back in here because the “Boge” front inserts ... Nov 7 2025, 03:02 AM
Back in here because the “Boge” front inserts... Nov 7 2025, 06:32 AM
Superhawk996
… supposedly OEM spec.
Welcome to the afterm... Nov 7 2025, 07:01 AM
Back in here because the “Boge” front inserts... Nov 7 2025, 07:30 AM
chmillman
KYB's are generally considered to be terrible... Nov 7 2025, 07:53 AM
mepstein In my experience, Koni’s can be adjusted much so... Nov 7 2025, 08:18 AM
wonkipop
In my experience, Koni’s can be adjusted much s... Nov 7 2025, 02:54 PM
Superhawk996 Seems you’re hooked into Boge as a brand.
Cons... Nov 7 2025, 08:18 AM
chmillman
Con... Nov 7 2025, 09:31 AM
Superhawk996
Co... Nov 7 2025, 10:51 AM
chmillman
Let’s go back to basics:
You say the ride is... Nov 7 2025, 11:50 AM
Superhawk996
Stiff(er) - compared to what it was like before... Nov 7 2025, 12:54 PM
rjames I went from kybs to koni adjustable shocks and str... Nov 7 2025, 09:41 AM
DRPHIL914 ive been reading thru the comments on your thread ... Nov 7 2025, 09:47 AM
ive been reading thru the comments on your thread... Nov 7 2025, 10:36 AM
DRPHIL914
ive been reading thru the comments on your threa... Nov 10 2025, 12:57 PM
wonkipop ps
this thread topic has been fantastic.
if nothi... Nov 7 2025, 03:06 PM
mepstein The six front end was basically a 911T suspension ... Nov 7 2025, 03:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 06:29 PM |
