| emerygt350 |
Jun 6 2025, 08:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,506 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
An insert for 275? What and why? Is it just rarity? Some strange one off design that no other car uses?
| mepstein |
Nov 2 2025, 11:20 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,586 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
It looks like the strut uses an early pinch bolt (large nut securing the bolt, split between the ends that secure the ball joint). If that’s correct, they are probably early 911T struts and probably Boge. Boge struts will have an embossed area halfway up the body with Boge name and part number. So long story short, if they are Boge 3” struts, Boge replacement inserts will drop right in. Easy to do at home. Jack up the side of the car, remove top nut on strut, drop the strut under the fender lip, pipe wrench to remove gland nut. Install is reverse but use a jack under the ball joint to raise the strut back into the strut retaining area on the car. Takes 15-20 minutes per side. No need to remove the entire strut from the suspension. Just be carrot the paint on the fender.
Personally, I would do the fronts and take it for a drive. You might not need the rears done. The front controls 75% of the feel of the car. I could be wrong but the 914-4 rear sway bars were 15mm and 914-6 were 16mm. Not a significant difference in feel but if it’s a bar for a six, it’s pretty valuable compared to one for a four. At least to an owner of a real six. You can also disengage the rear bar and see if you like the ride. Using a rear bar isn’t mandatory on a 914. Some guys control the roll with just springs. Maybe a bit more understeer but it’s a common setup to just use a front. Easy enough to try it and see if it works for you. |
| chmillman |
Nov 3 2025, 06:16 AM
Member ![]() ![]() Group: Members Posts: 369 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
I could be wrong but the 914-4 rear sway bars were 15mm and 914-6 were 16mm. Not a significant difference in feel but if it’s a bar for a six, it’s pretty valuable compared to one for a four. At least to an owner of a real six. You can also disengage the rear bar and see if you like the ride. Using a rear bar isn’t mandatory on a 914. Some guys control the roll with just springs. Maybe a bit more understeer but it’s a common setup to just use a front. Easy enough to try it and see if it works for you. As far as I can tel from what I have read and from the parts manual, 15 front / 16 rear was what was offered as the standard (optional) accessories for the '74's. Mine are in any case aftermarkets - my car didn't have either front or rear when I got it, so I had them put on. You may be right about the fronts only - back in the late '70s when I had my first one in CA (also a '74) it had a front stabilizer, but no rear one. And, OT - I wanted to add an aftermarket sway bar kit to my '57 T-Bird. The car was standard with a front ~5/8" sway bar and no rear (on a rigid rear axle), the aftermarket kit replaced the front with a 7/8" bar plus added a rear. But I could not for the life of me get the rear one mounted - it interfered with the exhaust. Someone suggested I just replace the front bar, that I wouldn't really miss the rear. They were right - the stiffer front bar really improves the handling and it doesn't really feel like it needs a rear one. OK, it handles like a boat anyway, but that's the nature of the beast. |
| Superhawk996 |
Nov 3 2025, 08:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Someone suggested I just replace the front bar, that I wouldn't really miss the rear. They were right - the stiffer front bar really improves the handling and it doesn't really feel like it needs a rear one. OK, it handles like a boat anyway, but that's the nature of the beast. While adding front bar stiffness will help control body roll, it will make the inherent understeer of the T-bird even worse. Highly recommended reading if you’re going to be undertaking suspension changes. |
emerygt350 Explain the 300 dollar shock to me Jun 6 2025, 08:08 PM
bkrantz
An insert for 275? What and why? Is it just rar... Jun 6 2025, 10:19 PM
emerygt350
[quote name='emerygt350' post='3209243' date='Jun... Jun 7 2025, 04:45 AM
dr914@autoatlanta.com we had the original boges duplicated by a suspensi... Jun 7 2025, 09:17 AM
Superhawk996
we had the original boges duplicated by a suspens... Jun 7 2025, 09:42 AM
jd74914
we had the original boges duplicated by a suspen... Nov 4 2025, 11:15 AM
Shivers I think I’ll see if they can rebuild mine. Price... Jun 7 2025, 05:04 AM
DennisV
I think I’ll see if they can rebuild mine. Pric... Jun 7 2025, 11:21 AM
Shivers
I think I’ll see if they can rebuild mine. Pri... Jun 7 2025, 12:01 PM
914Sixer Rebuilt shocks seem to be a thing of the past. I a... Jun 7 2025, 05:35 AM
Shivers
Rebuilt shocks seem to be a thing of the past. I ... Jun 7 2025, 07:32 AM
emerygt350 I think I might go with the reproduction from auto... Jun 7 2025, 07:06 AM
Superhawk996 Yup a terrible shame there aren’t Monro-matic or... Jun 7 2025, 07:51 AM
rick 918-S Same deal with 914-4 CV's. It totally baffles ... Jun 7 2025, 09:11 AM
Superhawk996
Same deal with 914-4 CV's. It totally baffles... Jun 7 2025, 09:40 AM
rick 918-S
Same deal with 914-4 CV's. It totally baffle... Jun 7 2025, 09:50 AM
Superhawk996
[quote name='Superhawk996' post='3209322' date='J... Jun 7 2025, 09:55 AM
emerygt350 Yeah, not necessary. Too bad the cheap option app... Jun 7 2025, 09:13 AM
rjames Buyer beware- I saw a post on Facebook where someo... Jun 7 2025, 09:17 AM
cgnj @dr914 @autoatlanta.com
I saw the post on the FB P... Jun 8 2025, 10:47 AM
emerygt350 Well. Always a surprise. Still leaking though...
... Jun 12 2025, 11:29 AM
emerygt350 Just took her through some twisty mountain roads, ... Jun 12 2025, 01:02 PM
mepstein At least on Bilsteins’ there is supposed to be a... Jun 12 2025, 01:20 PM
emerygt350 Ahh, well, I guess this is more like 5mm. It was ... Jun 12 2025, 02:51 PM
chmillman I'm tired of my bone-shaking Bilsteins... Rea... Nov 1 2025, 12:06 PM
I'm tired of my bone-shaking Bilsteins... Re... Nov 1 2025, 12:34 PM
chmillman Well, the car has had a 5 bolt conversion. So tho... Nov 1 2025, 02:59 PM
Well, the car has had a 5 bolt conversion. So th... Nov 1 2025, 05:05 PM
chmillman
How was the conversion done. With redrilled rotor... Nov 2 2025, 12:53 AM
wonkipop
How was the conversion done. With redrilled roto... Nov 2 2025, 11:40 AM
chmillman
i have a vague recollection the originals were i... Nov 2 2025, 02:24 PM
wonkipop
i have a vague recollection the originals were ... Nov 2 2025, 05:08 PM
wonkipop explanation?
you get what you pay for. (most tim... Nov 2 2025, 12:50 AM
mepstein If the struts have been switched out, you need to ... Nov 2 2025, 06:14 AM
chmillman
If the struts have been switched out, you need to... Nov 2 2025, 10:25 AM
chmillman
If the struts have been switched out, you need to... Nov 3 2025, 05:46 AM
wonkipop
[quote name='mepstein' post='3231015' date='Nov 2... Nov 3 2025, 06:04 AM
wonkipop
I could be wrong but the 914-4 rear sway bars w... Nov 3 2025, 06:32 AM
chmillman
While adding front bar stiffness will help contr... Nov 3 2025, 11:04 AM
emerygt350 If it makes any difference, I have been enjoying a... Nov 2 2025, 07:39 PM
carr914 @Paragon
Jason can answer all your question. He ... Nov 2 2025, 08:04 PM
mepstein Are the arms on the strut that secure the ball joi... Nov 3 2025, 06:04 AM
wonkipop @chmillman
part numbers for front struts.
yo... Nov 3 2025, 11:14 AM
chmillman
your struts have correct numbers for a 74
Well... Nov 3 2025, 11:55 AM
wonkipop @chmillman
interesting. i see what you are say... Nov 3 2025, 03:22 PM
sixnotfour More :beer2:
Nov 3 2025, 04:59 PM
wonkipop
More :beer2:
wow.
excellent document.
acco... Nov 3 2025, 05:25 PM
chmillman
More :beer2:
@sixnotfour - Wow, great info, th... Nov 4 2025, 02:53 AM
wonkipop had another good look at mine.
definitely a 4. st... Nov 3 2025, 05:07 PM
wonkipop i'm seeing something else interesting there to... Nov 3 2025, 05:35 PM
sixnotfour
BOGE manufacturer number ?
Looks like it in thi... Nov 3 2025, 05:36 PM
wonkipop
Looks like it in th... Nov 3 2025, 06:07 PM
wonkipop @chmillman
AASE bros ad you posted is up the cre... Nov 3 2025, 06:04 PM
sixnotfour OG BOGE ,,not exactly an insert..The strut housin... Nov 3 2025, 07:11 PM
wonkipop @chmillman
the parts page that [b]@[url=http://... Nov 4 2025, 02:53 PM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 4 2025, 04:58 PM
chmillman Back in here because the “Boge” front inserts ... Nov 7 2025, 03:02 AM
Back in here because the “Boge” front inserts... Nov 7 2025, 06:32 AM
Superhawk996
… supposedly OEM spec.
Welcome to the afterm... Nov 7 2025, 07:01 AM
Back in here because the “Boge” front inserts... Nov 7 2025, 07:30 AM
chmillman
KYB's are generally considered to be terrible... Nov 7 2025, 07:53 AM
mepstein In my experience, Koni’s can be adjusted much so... Nov 7 2025, 08:18 AM
wonkipop
In my experience, Koni’s can be adjusted much s... Nov 7 2025, 02:54 PM
Superhawk996 Seems you’re hooked into Boge as a brand.
Cons... Nov 7 2025, 08:18 AM
chmillman
Con... Nov 7 2025, 09:31 AM
Superhawk996
Co... Nov 7 2025, 10:51 AM
chmillman
Let’s go back to basics:
You say the ride is... Nov 7 2025, 11:50 AM
Superhawk996
Stiff(er) - compared to what it was like before... Nov 7 2025, 12:54 PM
rjames I went from kybs to koni adjustable shocks and str... Nov 7 2025, 09:41 AM
DRPHIL914 ive been reading thru the comments on your thread ... Nov 7 2025, 09:47 AM
ive been reading thru the comments on your thread... Nov 7 2025, 10:36 AM
DRPHIL914
ive been reading thru the comments on your threa... Nov 10 2025, 12:57 PM
wonkipop ps
this thread topic has been fantastic.
if nothi... Nov 7 2025, 03:06 PM
mepstein The six front end was basically a 911T suspension ... Nov 7 2025, 03:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 06:31 PM |
