> Galley Plugs, Which ones?
Chad911sc
post Nov 1 2025, 10:09 AM
While I have my engine out to fix my crank, wanted to do all the things I didn’t do the first time. I want to make sure I do all the galley plugs that are necessary to prevent one popping out and losing my oil pressure. Several posts on this forum say just to do the five, and some other forums say, to do many more. I got the main five out, and they were really in there! It took many pulls on the slide hammer to remove them. Surprisingly enough, my galley’s were spotless! In the bottom 2 pictures, my question is, do I need to remove these smaller ones up by the oil cooler? And also, what about this big one to the bottom right of the oil pump housing? Do these need to be removed and tapped as well?
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Chad911sc
post Nov 3 2025, 09:36 AM
Sorry Cabman,
If you meant when I bought the car it was running…yes. I’m not sure if the crank was bent then though, because it had 10lbs at idle. But truthfully I never drove it more than 3 miles before I tore it all apart. I drove it from where the shipper dropped it off, to where I live. There is no way it was even close to hot temps by then. Hard to know. It might have gotten bent from it being dropped or mishandled at the machine shop when I took it to get checked. All I know is I’m on the right path now to put it back together for hopefully the last time.
930cabman
post Nov 3 2025, 12:40 PM
QUOTE(Chad911sc @ Nov 3 2025, 10:36 AM) *
Sorry Cabman,
Great, you took the crank (and maybe other precision parts) to the trusted machine shop and they returned a bent crank. How is this possible, these cranks are stout forgings (I'm quite sure) and they don't bend easily. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif)
- Lo-Fi Version Time is now: 4th November 2025 - 04:58 AM
