| Mike1981 |
Aug 21 2025, 05:03 PM
Member ![]() ![]() Group: Members Posts: 264 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: South East States |
Hello Everyone.
Finally getting back to working on my 1971 914. When I bought it the turn signals did not work. The headlights and taillights work. (When key is in ignition and in on position) I took it out for a ride, and parked it in my garage. The turn signal stalk was left in the right turn position. Later that night I checked on the car, and found the right turn signal was on steady. (Only when key is off car not running) So, both left and right turn signal light steady when key is off but not when key is on or car running. Apparently the wiring is not broken. Can someone help ID the relay for the turn signal flasher on this board its a 1971 If so, does anyone know where I could source one? Thanks everyone... Attached thumbnail(s) |
| Spoke |
Nov 4 2025, 01:40 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,266 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Great may I buy one from you please? Would I simply take a wire from C2 to Chassis ground? You can buy a modified EP26 from me. The link to my page is below in my sig. Or you can buy one yourself and modify. I show how to do it on my page. Or you can short the wires to ground for the tach turnsignal indicators. QUOTE Do you feel the missing relay I have in the board is tied to the turn signals? The missing relay is not the flasher relay. The flasher relay has flat spades to connect. Also the flasher relay has a square box so I don't think either of the relays on the panel are the flasher relay. @JeffBowlsby @Superhawk996 I'm a bit foggy on where the flasher relay socket is on your panel. Here's a diagram from Jeff Bowlsby's page showing the panel with 5 relays; the flasher is in the middle and is shown as a square box. You may want to investigate in the wiring if you can find a floating socket and/or square box relay behind the fuse panel. In one of the pictures you can see a socket w/o a relay and see the flat spade sockets. But yours does not have this relay arrangement. I did some searching and found several different layouts. Perhaps someone has the magic decoder ring to figure out each variation including yours. Some of these pictures may be duplicates so there might not be 5 variations. ![]() ![]() |
| Mike1981 |
Nov 4 2025, 03:20 PM
Great may I buy one from you please? Would I simply take a wire from C2 to Chassis ground? You can buy a modified EP26 from me. The link to my page is below in my sig. Or you can buy one yourself and modify. I show how to do it on my page. Or you can short the wires to ground for the tach turnsignal indicators. QUOTE Do you feel the missing relay I have in the board is tied to the turn signals? The missing relay is not the flasher relay. The flasher relay has flat spades to connect. Also the flasher relay has a square box so I don't think either of the relays on the panel are the flasher relay. @JeffBowlsby @Superhawk996 I'm a bit foggy on where the flasher relay socket is on your panel. Here's a diagram from Jeff Bowlsby's page showing the panel with 5 relays; the flasher is in the middle and is shown as a square box. You may want to investigate in the wiring if you can find a floating socket and/or square box relay behind the fuse panel. In one of the pictures you can see a socket w/o a relay and see the flat spade sockets. But yours does not have this relay arrangement. I did some searching and found several different layouts. Perhaps someone has the magic decoder ring to figure out each variation including yours. Some of these pictures may be duplicates so there might not be 5 variations. ![]() ![]() Thanks for these ideas. Yes, there are a few different boards. I was told my board does not have the turn signal relay/switch on it. This is why I'm assuming the relay I pulled out is the one controlling the turn signals. Not 100 percent on this open for advice.... |
Mike1981 1971 turn signal relay question Aug 21 2025, 05:03 PM
dtmehall what do you mean by the 'right turn signal was... Aug 21 2025, 05:49 PM
Mike1981
what do you mean by the 'right turn signal wa... Aug 21 2025, 05:53 PM
dtmehall leaving the turn signal arm to a right or left pos... Aug 21 2025, 06:01 PM
Mike1981
leaving the turn signal arm to a right or left po... Aug 21 2025, 06:19 PM
dtmehall http://www.914world.com/bbs2/uploads/post-...-1330... Aug 21 2025, 06:32 PM
Mike1981
http://www.914world.com/bbs2/uploads/post-...-133... Aug 21 2025, 06:49 PM
Mike1981
[quote name='dtmehall' post='3220503' date='Aug 2... Aug 21 2025, 07:28 PM
Spoke I think you have some custom wiring going on with ... Aug 21 2025, 08:32 PM
Mike1981 [quote name='Spoke' post='3220527... Aug 22 2025, 06:16 AM
Mike1981 [quote name='Spoke' post='3220527... Aug 22 2025, 06:18 AM
Spoke
Thanks but the pic you are referring to is not th... Aug 22 2025, 06:38 AM
jim_hoyland When key is in the off position and either left or... Aug 22 2025, 06:05 AM
Mike1981
When key is in the off position and either left o... Aug 22 2025, 06:19 AM
Mike1981 Hello Everyone
Well, my life has finally settled ... Nov 4 2025, 09:22 AM
Spoke Not sure what that relay is. It doesn't have t... Nov 4 2025, 09:54 AM
Mike1981
Not sure what that relay is. It doesn't have ... Nov 4 2025, 10:34 AM
Mike1981
Not sure what that relay is. It doesn't have... Nov 4 2025, 10:38 AM
Superhawk996 The only thing I can add is the photo in post #1 w... Nov 4 2025, 08:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2025 - 08:56 PM |
