| John_914 |
Nov 5 2025, 02:53 PM
Newbie ![]() Group: Members Posts: 17 Joined: 4-March 09 From: Connecticut Member No.: 10,129 Region Association: None |
I've done a search but want to make sure I have it right. I'd like to replace all shift bushings on my 914-6 with what I believe is stock set up (see photos)
Starting up front at the shifter, Replace #9 and #10 as I would on early 911 using correct parts. I assume once I disconnect the U-joint just behind the firewall I can move the rod back to replace #10? Can I replace the bushing at firewall with design that has a split in it, or do I need to remove the rod? Then there's a bushing at the u-joint. I assume that's available and straightforward to replace? At the back, I assume I need to separate the rear section of shift rod and remove bracket to replace that bushing. Thanks in advance for any assistance. ![]() ![]() ![]() |
| rgalla9146 |
Nov 5 2025, 11:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,846 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
You don't have to slide the tunnel rod back. The hanging bracket that the bushing is pressed into can slide forward. If you can replace the firewall bushing without loosening the splined adjustment collar...do it that way. Then tell us how you did it (IMG:style_emoticons/default/smile.gif) If you have to loosen the collar, mark its orientation and depth any way you can before loosening. This will save a very tedious adjustment process. The socket bushing at the bottom of the shifter is pushed (with high effort)over the ball then inserted in the socket. Mind the throttle handle when reassembling. |
John_914 914-6 shift rod Nov 5 2025, 02:53 PM
DennisV As I recall:
#10 is up near the shifter and the br... Nov 5 2025, 03:20 PM
John_914 Thanks, very helpful, also learned that bushing 91... Nov 5 2025, 04:26 PM
John_914 Thanks, I took the easy way out and it worked out.... Nov 6 2025, 02:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2025 - 06:09 PM |
