| chmillman |
Nov 5 2025, 09:48 AM
Member ![]() ![]() Group: Members Posts: 369 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
As per previous threads, my car has had a 5-lug conversion - I think correctly done. The front hubs/rotors/calipers are 914-6/early 911 ones as far as I can tell (ATE calipers), I therefore assume the rear hubs/rotors/calipers might also 914-6 or similar? Can someone confirm? TIA
Just for laughs, Google's Ai analysis of the photo tells me it's from a Nissan Primera P12... (IMG:style_emoticons/default/lol-2.gif) |
| Montreal914 |
Nov 6 2025, 08:13 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,071 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Here you go. (IMG:style_emoticons/default/smile.gif)
914 Rear rotor: solid diameter: 282mm thickness: 9.4 (or 9.5?)mm caliper piston dia: 33mm 914-6 Rear rotor: solid diameter: 286mm thickness: 10.4mm caliper piston dia: 38mm 914-6 GT Rear rotor: vented diameter: 286mm thickness: ? caliper piston dia: 38mm (same caliper as 914-6 with a spacer) No longer available but there are ways around |
chmillman Rear 5-lug rotor and caliper - identify? Nov 5 2025, 09:48 AM
peteyd those are 4 cylinder calipers. later ones with the... Nov 5 2025, 11:27 AM
chmillman OK, so they changed the hubs and rotors for 5-lugā... Nov 5 2025, 04:12 PM
brant
OK, so they changed the hubs and rotors for 5-lug... Nov 5 2025, 04:21 PM
chmillman
pretty close...
if you stay with non vented rotor... Nov 6 2025, 05:53 AM
mate914 914-6 = 911T same rear rotor until the rear vente... Nov 6 2025, 05:58 AM
chmillman
Here you go. :)
914 Rear rotor:
solid
diamete... Nov 6 2025, 09:49 AM
chmillman So, I'm thinking at some point I will just wan... Nov 10 2025, 10:24 AM
brant
So, I'm thinking at some point I will just wa... Nov 10 2025, 10:50 AM
chmillman
just the same difficulty.
the bleeding challenge... Nov 10 2025, 04:09 PM
chmillman Well, not quite square one as it seems. As a foll... Nov 12 2025, 12:46 AM
chmillman So I measured mine today the best I could - access... Nov 14 2025, 11:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 10:25 PM |
