| John_914 |
Nov 5 2025, 02:53 PM
Newbie ![]() Group: Members Posts: 17 Joined: 4-March 09 From: Connecticut Member No.: 10,129 Region Association: None |
I've done a search but want to make sure I have it right. I'd like to replace all shift bushings on my 914-6 with what I believe is stock set up (see photos)
Starting up front at the shifter, Replace #9 and #10 as I would on early 911 using correct parts. I assume once I disconnect the U-joint just behind the firewall I can move the rod back to replace #10? Can I replace the bushing at firewall with design that has a split in it, or do I need to remove the rod? Then there's a bushing at the u-joint. I assume that's available and straightforward to replace? At the back, I assume I need to separate the rear section of shift rod and remove bracket to replace that bushing. Thanks in advance for any assistance. ![]() ![]() ![]() |
| John_914 |
Nov 6 2025, 02:52 PM
Thanks, I took the easy way out and it worked out. I only removed the rod at the back end, which was easy to do on a lift. I replaced the rear bushing, which I had in inventory from a 911.
Don't think it did much. Bit there was a lot of play in the u-joint/knuckle just behind the firewall. I was told the plastic part is NLA, replaced by a stainless steel unit. I noted some slop where the steel bushings fit into the plastic piece, so I wrapped the bushings with some teflon tape, which really took up the slack. Put it all together, adjusted the clutch and all works fine! Problem was that it would go into second when shifting in fourth. All gears engage the way they should now. Let's see if it holds up. |
John_914 914-6 shift rod Nov 5 2025, 02:53 PM
DennisV As I recall:
#10 is up near the shifter and the br... Nov 5 2025, 03:20 PM
John_914 Thanks, very helpful, also learned that bushing 91... Nov 5 2025, 04:26 PM
rgalla9146 You don't have to slide the tunnel rod back. T... Nov 5 2025, 11:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2025 - 06:09 PM |
