| neyen14 |
Nov 6 2025, 07:42 PM
Member ![]() ![]() Group: Members Posts: 85 Joined: 2-December 07 From: New York Member No.: 8,408 Region Association: North East States |
I am using dual Weber 40 IDF's. 96mm cylinders c35 scat cam
#1 The Original "velocity stack" is a straight shot down the throat of the carb. #2 Shorter shinier velocity stack is for 40 - 48 IDF and leaves about a 1/8" lip at the top plate of the carb #3 The taller less shiny velocity stack says it is for DRLA & IDF 36 - 40mm but leaves about a 1/16" lip at the top plate of the carb I started to widen the inside of the #1 Original and thought it better to have a straight shot down the throat then it would be to have any bit of a lip.... however, I was recommended to use the non original velocity stacks and don't worry about the lip, they've "found it doesn't affect performance".... which seems counterintuitive to the ideas of porting, polishing, and general flow etc 1. Do you think opening up the original velocity stack and having the straight shot is worth it? 2. Should I not worry about the lip? 3. Is there a stack that would fit the 40 IDF specifically without covering a range? Attached thumbnail(s) |
| Front yard mechanic |
Nov 6 2025, 09:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Can’t you get taller air cleaners and use the tall stacks
neyen14 Velocity Stacks Nov 6 2025, 07:42 PM
neyen14 Here's an above view with each Nov 6 2025, 08:53 PM
Jamie
The flow dyna... Nov 7 2025, 07:42 AM
stownsen914 You don't want to have a ledge/lip at the velo... Nov 7 2025, 09:01 AM
neyen14
You don't want to have a ledge/lip at the vel... Nov 7 2025, 09:42 AM
neyen14
The flow dyn... Nov 7 2025, 09:35 AM
neyen14
Can’t you get taller air cleaners and use the t... Nov 7 2025, 01:40 AM
Jack Standz There are at least two different diameters on vent... Nov 7 2025, 03:24 AM
neyen14
There are at least two different diameters on ven... Nov 7 2025, 05:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2025 - 01:22 AM |
