| rfinegan |
Nov 9 2025, 08:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,136 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Any one use the compression fitted fuel line ends to adapt the pipette on the fuller tank to a PTFE 6AN fuel line?
Feed back and experience appreciated.... |
| jd74914 |
Nov 10 2025, 10:46 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,862 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Any one use the compression fitted fuel line ends to adapt the pipette on the fuller tank to a PTFE 6AN fuel line? Feed back and experience appreciated.... Seems like you have a better path now but just in case you have future need there is only one place I know of sells these metric compression to to 37 degree adapter fittings... FAV Fittings FCF/MCJF/5I-8T https://favfittings.com/instrument-fittings...onnector-jic-2/ They are a real company. (IMG:style_emoticons/default/laugh.gif) No idea on what the lead time for this kind of stuff is though. |
rfinegan Compression fitting on fuel tank pipette Nov 9 2025, 08:30 AM
bdstone914 You can tap the threaed nipples on the tank1/4 FPT... Nov 9 2025, 09:20 AM
Graydingo I did this. I converted 911 Carrera hardlines to t... Nov 9 2025, 10:02 AM
rfinegan great info thanks for the tips
yes the plan is a ... Nov 9 2025, 10:51 AM
Jack Standz Yes, did this using -6AN fittings from IIRC air-co... Nov 9 2025, 11:33 AM
Literati914 I wonder if one of these would work:
https://www2... Nov 9 2025, 06:37 PM
KSCarrera CB Performance sell 6AN (-6) and 8AN (-8) fittings... Nov 10 2025, 01:48 AM
rfinegan THANK YOU
I did not get the correct ends. I got t... Nov 10 2025, 06:18 AM
rfinegan CB Performance fittings for the Win! Perfect ... Nov 18 2025, 10:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2025 - 02:36 AM |
