| Mike Fitton |
Nov 10 2025, 11:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 648 Joined: 13-May 11 From: Mount Prospect, IL Member No.: 13,069 Region Association: Upper MidWest
Does anyone know what the line item charge was for the Pepita inserts back in 1970. I have seen it also referred to as Hounds Tooth Check Fabric. Would be great if someone had a window stick with this option!
| wonkipop |
Nov 10 2025, 10:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
mike
don't have any sales print outs for 70 models. all my files are for L jets. 74 on. but i do have this detailed one for a tourist ordered 74. explains the black squares with an S beside them on the fabric chart for 70 that came from jeff's website. shows the corduroy option/choice had been ticked. was no charge. but you did have to tick and order one. standard fare was all leatherette unless you indicated one of the other standard choices. this is one of those black square w/S scenarios. was how it would have worked with the 914/6 back in 70 with its three possibilities. leatherette or corduroy or dogs tooth. you just had to say which one you wanted. sometimes on BAT if you search the 70s models you might see a window printout with the documentation. but it will be a rare 914/4 that shows up for sale that had metallic paint originally. let alone dogs tooth. (IMG:style_emoticons/default/biggrin.gif) i have not noticed many 70s on BAT researching the 74 L jets. the only stuff i have seen is the examples that jeff bowlsby has filed. |
Mike Fitton Pepita Checked Cloth or Hounds Tooth Check Fabric Nov 10 2025, 11:48 AM
wonkipop
Does anyone know what the line item charge was fo... Nov 10 2025, 03:59 PM
Mike Fitton Looks like it was free with the metallic paint opt... Nov 10 2025, 10:18 PM
wonkipop
Looks like it was free with the metallic paint op... Nov 10 2025, 10:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 06:53 AM |
