| tpines |
Nov 11 2025, 12:15 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 12-November 08 From: San Diego Member No.: 9,745 Region Association: Southern California |
Hi guys,
Just to let you know I am heart broken as my rebuilt 2056 with only 6,000 miles seized last week. Apparently, I ran it low on oil. Now, I'm not the most mechanically inclined but I changed the oil in July after after putting 3,000 annual miles on it. Since it was a new motor I didn't think I needed to check the oil every couple of weeks like my mechanic told me. How often should you check the oil level with a new motor? And do you think it's going to need a full rebuild again? |
| GregAmy |
Nov 11 2025, 12:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Oof that sucks.
Honestly, I check my 914's oil level each time I use it. What were you doing at the time? Idling or cruising down the highway? Did the oil light come on? For reference, last year I forgot to open the dry sump valve on my 2056 racer and as I was idling away it seized. It had seized at the nose bearing, fortunately it did not spin, as I did not have much load on it. I asked to have to have it fully with new bearings all around. https://tgadrivel.blogspot.com/2024/09/an-i...sportation.html |
tpines 2056 seized Nov 11 2025, 12:15 PM
JamesM
Honestly, I check my 914's oil level each ti... Nov 11 2025, 09:06 PM
trojanhorsepower Oh man, so sorry about this. I have a new 2056 an... Nov 11 2025, 01:41 PM
JamesM
It is odd that it would have leaked down that mu... Nov 11 2025, 09:09 PM
Chad911sc I have a 2056 as well and it’s torn down for the... Nov 11 2025, 01:52 PM
trojanhorsepower Mine has lower oil pressure than I would like. Ap... Nov 11 2025, 02:35 PM
emerygt350 I was just looking through that porsche technical ... Nov 11 2025, 03:57 PM
wonkipop
I was just looking through that porsche technical... Nov 11 2025, 04:47 PM
JamesJ
I was just looking through that porsche technical... Nov 11 2025, 08:04 PM
Geezer914 I check my oil before each use. I just pulled the... Nov 11 2025, 05:25 PM
Front yard mechanic I change my oil every day ! A drip at a time i... Nov 11 2025, 05:50 PM
tpines Thanks for all of your input guys. The oil light n... Nov 11 2025, 10:16 PM
Jack Standz Very very sorry to hear about the engine failure, ... Nov 12 2025, 07:41 AM
Superhawk996 Story doesn’t add up
6000 miles total prior to... Nov 12 2025, 08:59 AM
Ninja :agree:
I consider a failure at this mileage as ... Nov 12 2025, 09:08 AM
VaccaRabite I agree. There was some sort of mechanical fault ... Nov 12 2025, 09:59 AM
Jack Standz
Story doesn’t add up.
I would not let whoever... Nov 12 2025, 10:03 AM
Superhawk996
I would not let whoeve... Nov 12 2025, 10:27 AM
emerygt350 what happens when you over-torque that oil screen? Nov 12 2025, 11:09 AM
Superhawk996
what happens when you over-torque that oil screen... Nov 12 2025, 12:56 PM
tpines So I went back over all my records:
Original 2.0 ... Nov 12 2025, 10:50 PM
mepstein You said you apparently ran low on oil. How low? H... Nov 13 2025, 06:08 AM
tpines There was probably half a quart to a quart left in... Nov 13 2025, 08:51 AM
There was probably half a quart to a quart left i... Nov 13 2025, 09:06 AM
sixnotfour somebody forgot to Add oil... Nov 13 2025, 09:08 AM
GregAmy
That’s a lot of oil loss in (if I read correctl... Nov 13 2025, 09:16 AM
That’s a lot of oil loss in (if I read correct... Nov 13 2025, 10:02 AM
GregAmy It happens...
Remember, you're replying to t... Nov 13 2025, 09:36 PM
davep I am very sorry to hear of your engine failure, an... Nov 13 2025, 09:24 AM
Ninja
Kept stock cam and fuel injection
Hydraulic lift... Nov 13 2025, 09:35 AM
emerygt350 I wonder if you filled it with penetrating oil, dr... Nov 13 2025, 09:49 AM
Geezer914 Who did the oil change? Nov 13 2025, 09:56 AM
Jack Standz
There was probably half a quart to a quart left ... Nov 13 2025, 10:27 AM
Artfrombama Since it was a new motor I didn't think I nee... Nov 13 2025, 10:31 AM
Ottomotion If the motor failed due to oil starvation, the oil... Nov 13 2025, 07:22 PM
wonkipop
If the motor failed due to oil starvation, the oi... Nov 13 2025, 11:51 PM
FlacaProductions I'm wondering if there was any in it to start ... Nov 13 2025, 09:15 PM
tpines Thank you all again for all of your advice.. I... Nov 13 2025, 10:44 PM
930cabman Losing an engine is never a good thing, and it rea... Nov 14 2025, 01:19 PM
porschetub
Losing an engine is never a good thing, and it re... Nov 14 2025, 05:31 PM
Jack Standz
Losing an engine is never a good thing, and it re... Nov 14 2025, 02:42 PM
Jack Standz
Losing an engine is never a good thing, and it r... Nov 14 2025, 06:30 PM
rick 918-S my guess.. dropped a valve seat. Nov 14 2025, 08:18 PM
930cabman Seized engine = will not turn over (spin)
Open i... Nov 15 2025, 02:41 PM
rbzymek So even with the oil filled to the top mark I used... Dec 5 2025, 08:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 01:54 AM |
