> 2056 seized
tpines
post Nov 11 2025, 12:15 PM
Hi guys,
Just to let you know I am heart broken as my rebuilt 2056 with only 6,000 miles seized last week. Apparently, I ran it low on oil.
Now, I'm not the most mechanically inclined but I changed the oil in July after after putting 3,000 annual miles on it. Since it was a new motor I didn't think I needed to check the oil every couple of weeks like my mechanic told me.
How often should you check the oil level with a new motor? And do you think it's going to need a full rebuild again?
Jack Standz
post Nov 13 2025, 10:27 AM
QUOTE(mepstein @ Nov 13 2025, 10:06 PM) *
QUOTE(tpines @ Nov 13 2025, 09:51 AM) *
There was probably half a quart to a quart left in the engine when we checked for any metal shavings. Which there were not thankfully.
That’s a lot of oil loss in (if I read correctly) 800 miles.
Please don't take this as "piling on", just trying to understand the cause from the limited information we have read here.
The statement that there was only 1/2 to 1 quart left in the motor and the oil pressure light never came on cannot be reconciled unless the oil pressure light was not working properly. Strongly urge that a mechanical oil pressure gauge is installed for startup of the rebuilt motor and use a working cockpit gauge.
In addition, since the builder of your motor installed hydraulic lifters (with a used FI cam) in a 914 motor, this indicates yet another reason you should question their competency.
tpines   2056 seized   Nov 11 2025, 12:15 PM
GregAmy   Oof that sucks. Honestly, I check my 914's oi...   Nov 11 2025, 12:20 PM
JamesM   Honestly, I check my 914's oil level each ti...   Nov 11 2025, 09:06 PM
trojanhorsepower   Oh man, so sorry about this. I have a new 2056 an...   Nov 11 2025, 01:41 PM
JamesM   It is odd that it would have leaked down that mu...   Nov 11 2025, 09:09 PM
Chad911sc   I have a 2056 as well and it’s torn down for the...   Nov 11 2025, 01:52 PM
trojanhorsepower   Mine has lower oil pressure than I would like. Ap...   Nov 11 2025, 02:35 PM
emerygt350   I was just looking through that porsche technical ...   Nov 11 2025, 03:57 PM
wonkipop   I was just looking through that porsche technical...   Nov 11 2025, 04:47 PM
JamesJ   I was just looking through that porsche technical...   Nov 11 2025, 08:04 PM
Geezer914   I check my oil before each use. I just pulled the...   Nov 11 2025, 05:25 PM
Front yard mechanic   I change my oil every day ! A drip at a time i...   Nov 11 2025, 05:50 PM
tpines   Thanks for all of your input guys. The oil light n...   Nov 11 2025, 10:16 PM
Jack Standz   Very very sorry to hear about the engine failure, ...   Nov 12 2025, 07:41 AM
Superhawk996   Story doesn’t add up 6000 miles total prior to...   Nov 12 2025, 08:59 AM
Ninja   :agree: I consider a failure at this mileage as ...   Nov 12 2025, 09:08 AM
VaccaRabite   I agree. There was some sort of mechanical fault ...   Nov 12 2025, 09:59 AM
Jack Standz   Story doesn’t add up. I would not let whoever...   Nov 12 2025, 10:03 AM
Superhawk996   Story doesn’t add up. I would not let whoeve...   Nov 12 2025, 10:27 AM
emerygt350   what happens when you over-torque that oil screen?   Nov 12 2025, 11:09 AM
Superhawk996   what happens when you over-torque that oil screen...   Nov 12 2025, 12:56 PM
tpines   So I went back over all my records: Original 2.0 ...   Nov 12 2025, 10:50 PM
mepstein   You said you apparently ran low on oil. How low? H...   Nov 13 2025, 06:08 AM
tpines   There was probably half a quart to a quart left in...   Nov 13 2025, 08:51 AM
mepstein   There was probably half a quart to a quart left i...   Nov 13 2025, 09:06 AM
sixnotfour   somebody forgot to Add oil...   Nov 13 2025, 09:08 AM
GregAmy   That’s a lot of oil loss in (if I read correctl...   Nov 13 2025, 09:16 AM
mepstein   That’s a lot of oil loss in (if I read correct...   Nov 13 2025, 10:02 AM
GregAmy   It happens... Remember, you're replying to t...   Nov 13 2025, 09:36 PM
davep   I am very sorry to hear of your engine failure, an...   Nov 13 2025, 09:24 AM
Ninja   Kept stock cam and fuel injection Hydraulic lift...   Nov 13 2025, 09:35 AM
emerygt350   I wonder if you filled it with penetrating oil, dr...   Nov 13 2025, 09:49 AM
Geezer914   Who did the oil change?   Nov 13 2025, 09:56 AM
Jack Standz   There was probably half a quart to a quart left ...   Nov 13 2025, 10:27 AM
Artfrombama   Since it was a new motor I didn't think I nee...   Nov 13 2025, 10:31 AM
Ottomotion   If the motor failed due to oil starvation, the oil...   Nov 13 2025, 07:22 PM
wonkipop   If the motor failed due to oil starvation, the oi...   Nov 13 2025, 11:51 PM
FlacaProductions   I'm wondering if there was any in it to start ...   Nov 13 2025, 09:15 PM
tpines   Thank you all again for all of your advice.. I...   Nov 13 2025, 10:44 PM
930cabman   Losing an engine is never a good thing, and it rea...   Nov 14 2025, 01:19 PM
porschetub   Losing an engine is never a good thing, and it re...   Nov 14 2025, 05:31 PM
Jack Standz   Losing an engine is never a good thing, and it re...   Nov 14 2025, 02:42 PM
Jack Standz   Losing an engine is never a good thing, and it r...   Nov 14 2025, 06:30 PM
rick 918-S   my guess.. dropped a valve seat.   Nov 14 2025, 08:18 PM
930cabman   Seized engine = will not turn over (spin) Open i...   Nov 15 2025, 02:41 PM
rbzymek   So even with the oil filled to the top mark I used...   Dec 5 2025, 08:35 AM
- Lo-Fi Version Time is now: 14th March 2026 - 01:46 AM
