> More Questions - Rough running, What am I missing?
NotLance
post Nov 12 2025, 09:09 PM
My new engine is in, but I continue to have issues with rough running - and its gotta be something that was retained when i swapped the short blocks, as the behievor is similar to what I witnessed with the other engine too. Engine is good above 3000rpm, so I think the main circuit of the dual webers is good, but at lower rpm it surges on light-med acceleration, consistent on foot down acceleration. backfires out of exhaust on decel and at idle. All of that said, when I pulled one plug after 300 miles, it was very carbon fouled so leaned out that one to hopefully fix... it did not. Resyched and tried tuning carbs per factory weber procedure but still cant get it happy. I also can't verify running conditions at higher than 3500 rpm becuase I'm still breaking in the brand new block.
Fresh plugs and ignition coil, advance on 123 distributor set properly, theoretically timing set to the mark on the fan housing (27* i think), I do not suspect vacuum leaks due to the engine not picking up speed after spraying everywhere with starting fluid... STE reads synchronous airflows on all carbs
Plugs I pulled seemed out seemed okay, not super carbon, oily, or anything.
Maybe I just can't tune dual carbs to save my life? Or they need a rebuild or something (IMG:style_emoticons/default/confused24.gif) I've got it going to a shop friday just to attempt to tune the carbs for me becuase I don't know what else to do...
Consulting the 914think tank to see if there is something obvious I'm missing because despite pretending to know a bit about fixing my car, im just a kid (IMG:style_emoticons/default/biggrin.gif)
I dont have a timing light, can you rent one from somewhere so I could verify timing? I trust the people who installed my engine but starting to pull out my hair so trying to eliminate any variables possible
Its a -4 cyl GA case, dual weber 40 idf carbs and a 123 distributor set to curve 1. BR6ES spark plugs
Superhawk996
post Nov 13 2025, 12:41 PM
Based on story above. - continues to point to carbs
NotLance   More Questions - Rough running   Nov 12 2025, 09:09 PM
emerygt350   My new engine is in, but I continue to have issue...   Nov 13 2025, 07:40 AM
Superhawk996   Need info on all carb components: Venturi size (...   Nov 13 2025, 08:08 AM
NotLance   Heres some more info - Venturi Size: 30 Main Jet:...   Nov 13 2025, 11:36 AM
NotLance   Also, do you need a timing light to set timing or ...   Nov 13 2025, 12:04 PM
fiacra   Lance, not everyone tuning in right now knows the ...   Nov 13 2025, 12:08 PM
Jack Standz   Find and mark TDC on your fan (or flywheel if you ...   Nov 13 2025, 12:10 PM
Superhawk996   Timing needs to be set with a light. Guessing won...   Nov 13 2025, 12:12 PM
Jack Standz   :agree: 1/4 turn out on mixture points towards t...   Nov 13 2025, 12:18 PM
NotLance   Good call fiacra - so to recap the story, My eng...   Nov 13 2025, 12:32 PM
NotLance   Thanks for the advice so far guys! Going to bu...   Nov 13 2025, 12:35 PM
Superhawk996   Based on story above. - continues to point to carb...   Nov 13 2025, 12:41 PM
emerygt350   Yeah, carbs but do get a timing light. Super easy...   Nov 13 2025, 12:59 PM
NotLance   update - AND ALSO MY 100th POST!!! :c...   Nov 13 2025, 02:43 PM
emerygt350   update - AND ALSO MY 100th POST!!! :...   Nov 13 2025, 03:04 PM
NotLance   Also new stroke of paranoia has hit - if my fan is...   Nov 13 2025, 03:05 PM
Jack Standz   VW produced several different fans with various ti...   Nov 13 2025, 04:21 PM
emerygt350   That area right there is where you want to look...   Nov 13 2025, 04:54 PM
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: emerygt350
- Lo-Fi Version Time is now: 13th November 2025 - 05:31 PM
